Commit 0ebd7e2e authored by hhakim's avatar hhakim
Add matlab and python basic tests of resp. matfaust and pyfaust after macos...
Add matlab and python basic tests of resp. matfaust and pyfaust after macos pkg installation in the test_macos_pkg_release gitlab ci job.
parent 2e01e8b7
Pipeline #833797 skipped
...@@ -489,6 +489,8 @@ test_macos_pkg_release: ...@@ -489,6 +489,8 @@ test_macos_pkg_release:
script: script:
- find ./ - find ./
- echo $MACOS_PASS | sudo -S installer -pkg build/faust-$CI_COMMIT_TAG.pkg -target / - echo $MACOS_PASS | sudo -S installer -pkg build/faust-$CI_COMMIT_TAG.pkg -target /
- matlab -nojvm -nodisplay -r "disp(matfaust.version());disp(full(matfaust.rand(5,5))); exit;"
- python -c "import pyfaust; print(pyfaust.version()); print(pyfaust.rand(5,5).toarray());"
only: only:
- tags - tags
tags: tags:
