GitLab
Explore
Primary navigation
Search or go to…
faust
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
faust group
faust
0e73f415
0e73f415
8 years ago
Adrien Leman
Committed by
hhakim
2 years ago
Downloads
Patches
debug mode cmake liste
ea9a42d2
Branches containing commit
CMakeLists.txt
+4
-3
4 additions, 3 deletions
CMakeLists.txt
4 additions
3 deletions
CMakeLists.txt
4
3
0e73f415
@@ -180,7 +180,7 @@ option(BUILD_TESTING "Build Tests" ON)
#Allows generating the doc:
option
BUILD_DOCUMENTATION
"Generating the doxygen documentation."
OFF
# Allows multithreading:
option
BUILD_MULTITHREAD
"Enable multithread with OpenMP Multithreading."
O
FF
option
BUILD_MULTITHREAD
O
N
# Allows verbose:
option
BUILD_VERBOSE
"Enable verbose option when compile (-v)."
OFF
# Allows MPTK Debug:
@@ -512,7 +512,8 @@ set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${FAUST_BIN_DIR} CACHE STRING "" FORCE)
# adding compiler flags
set
CMAKE_CXX_FLAGS
if
CMAKE_BUILD_TYPE MATCHES
"Debug"
OR
"debug"
OR
"DEBUG"
#if( (CMAKE_BUILD_TYPE MATCHES "Debug") OR (CMAKE_BUILD_TYPE MATCHES "debug") OR (CMAKE_BUILD_TYPE MATCHES "DEBUG") )
if
BUILD_DEBUG
if
UNIX
set
CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS_DEBUG
-O1"
elseif
WIN32
@@ -521,7 +522,7 @@ if( (CMAKE_BUILD_TYPE MATCHES "Debug") OR (CMAKE_BUILD_TYPE MATCHES "debug") OR
message
WARNING
"Unknown type of plateform for CMAKE_CXX_FLAGS"
endif
message
STATUS
"**********DEBUG mode************"
else
else
BUILD_DEBUG
if
UNIX
if
BUILD_MULTITHREAD
set
CMAKE_CXX_FLAGS
CMAKE_CXX_FLAGS
-fopenmp "
CACHE STRING
"compile flags"
FORCE
This diff is collapsed.
Loading
Save comment
