Commit 0d61af0d authored by Nicolas Bellot's avatar Nicolas Bellot Committed by hhakim
test src modification multiply_compare_time.cpp.in
parent f885c19d
#include "faust_constraint_generic.h"
#include "faust_constraint_int.h"
#include "faust_constraint_real.h"
#include "faust_constraint_mat.h"
#include <string>
#include <sstream>
#include <vector>
#include <iostream>
#include <iomanip>
/** \brief An example of using the hierarchical factorization of a dense matrix. from .mat file.
* An dense matrix is loaded from "@FAUST_TESTDATA_SRC_DIR@
* \param config_filename : a .mat (MATLAB file) configuration file which contains the parameter of the hierarchical algorithm (default launch with a predefined configuration called hier_fact)
* \param expected_lambda (optionnal) : compared the expected scalar of the factorisation with the computed one in the precision defined with epsilon
*\param epsilon : precision for the test of equality (default value 0.0001)
typedef @TEST_FPP@ FPP;
int main(int argc, char* argv[])
if (typeid(FPP) == typeid(double))
cout<<"floating point precision == double"<<endl;
if (typeid(FPP) == typeid(float))
cout<<"floating point precision == float"<<endl;
std::cout<<"debut"<<std::endl; std::vector<faust_constraint_generic<FPP>*> list_constraint;
int dim1 = 5,dim2 = 9;
faust_mat<FPP> mat_tmp(dim1,dim2);
for (int i=0;i<dim1*dim2;i++)
mat_tmp[i]=i;
faust_mat<FPP> const mat=mat_tmp;
faust_constraint_int<FPP> constraint_sp(CONSTRAINT_NAME_SP,6,dim1,dim2);
std::cout<<"1"<<std::endl;
list_constraint.push_back((faust_constraint_generic<FPP>*) new faust_constraint_int<FPP>(CONSTRAINT_NAME_SP,6,dim1,dim2));
std::cout<<"2"<<std::endl;
faust_mat<FPP> mat2project;
for (int i=0;i< list_constraint.size();i++)
mat2project=mat;
list_constraint[i]->project(mat2project);
std::cout<<"dimension mat"<<std::endl;
std::cout<<mat2project.getNbRow()<<" "<<mat2project.getNbCol();
mat2project.Display();
return 0;
...@@ -2,7 +2,7 @@ ...@@ -2,7 +2,7 @@
#include "faust_init_from_matio_core.h" #include "faust_init_from_matio_core.h"
#include "faust_init_from_matio_mat.h" #include "faust_init_from_matio_mat.h"
#include "faust_Timer.h" #include "faust_Timer.h"
#include "linear_algebra.h" #include "faust_linear_algebra.h"
#include <iostream> #include <iostream>
#include <cstdlib> #include <cstdlib>
#include <ctime> #include <ctime>
