Commit 0b037e09 authored by hhakim's avatar hhakim
Fix bug in Faust::Transform<FPP,Cpu>::updateNonZeros().
If the function were called several times in a row the value would have been as many times too bigger. Use rather the temporary variable (previously not used, just declared) to calculate the non-zeros count and then override the totalNonZeros attribute. This bug is minor because normally we don't have to call it several times if a Transform is immutable.
parent 63bb1f16
Pipeline #833838 skipped
...@@ -325,7 +325,8 @@ void Faust::Transform<FPP,Cpu>::updateNonZeros() ...@@ -325,7 +325,8 @@ void Faust::Transform<FPP,Cpu>::updateNonZeros()
int totalNonZeros_tmp=0; int totalNonZeros_tmp=0;
for (int i=0;i<size();i++) for (int i=0;i<size();i++)
totalNonZeros+=data[i].getNonZeros(); totalNonZeros_tmp+=data[i].getNonZeros();
totalNonZeros = totalNonZeros_tmp;
