Commit 077340df authored by hhakim's avatar hhakim
Modify svdtj c++ step mode to stop when the singular values become worse...
Modify svdtj c++ step mode to stop when the singular values become worse (error increases of one order of magnitude or more).
parent 92a68a0f
...@@ -31,9 +31,6 @@ namespace Faust ...@@ -31,9 +31,6 @@ namespace Faust
MatDense<FPP, DEVICE> dM_M, dMM_; // M'*M, M*M' MatDense<FPP, DEVICE> dM_M, dMM_; // M'*M, M*M'
// MatDense<FPP, DEVICE> sM_M, sMM_; // M'*M, M*M' // MatDense<FPP, DEVICE> sM_M, sMM_; // M'*M, M*M'
GivensFGFT<FPP, DEVICE, FPP2>* algoW1;
GivensFGFT<FPP, DEVICE, FPP2>* algoW2;
dM = sM; dM = sM;
spgemm(sM, dM, dM_M, FPP(1.0), FPP(0.0), 'H', 'N'); spgemm(sM, dM, dM_M, FPP(1.0), FPP(0.0), 'H', 'N');
spgemm(sM, dM, dMM_, FPP(1.0), FPP(0.0), 'N', 'H'); spgemm(sM, dM, dMM_, FPP(1.0), FPP(0.0), 'N', 'H');
...@@ -52,9 +49,7 @@ namespace Faust ...@@ -52,9 +49,7 @@ namespace Faust
gemm(dM, dM, dMM_, FPP(1.0), FPP(0.0), 'N', 'H'); gemm(dM, dM, dMM_, FPP(1.0), FPP(0.0), 'N', 'H');
M = &dM; M = &dM;
// svdtj_core_cplx(M, dM, dM_M, dMM_, J1, J2, t1, t2, tol, verbosity, relErr, order, enable_large_Faust, U, V, S_);
svdtj_core_gen<FPP,DEVICE,FPP2>(M, dM, dM_M, dMM_, J1, J2, t1, t2, tol, verbosity, relErr, order, enable_large_Faust, U, V, S_, err_period); svdtj_core_gen<FPP,DEVICE,FPP2>(M, dM, dM_M, dMM_, J1, J2, t1, t2, tol, verbosity, relErr, order, enable_large_Faust, U, V, S_, err_period);
template<typename FPP, FDevice DEVICE, typename FPP2> template<typename FPP, FDevice DEVICE, typename FPP2>
...@@ -332,10 +327,12 @@ namespace Faust ...@@ -332,10 +327,12 @@ namespace Faust
auto min_mn = m > n?n:m; auto min_mn = m > n?n:m;
Vect<FPP,DEVICE> S(min_mn); // zero-initialized Vect<FPP,DEVICE> S(min_mn); // zero-initialized
Vect<FPP,DEVICE> prev_S(min_mn); // zero-initialized
int k1 = 0, k2 = 0; // k counts the number of Givens built (t per factor) on each side (for U (W1) and V (W2)) int k1 = 0, k2 = 0; // k counts the number of Givens built (t per factor) on each side (for U (W1) and V (W2))
auto M_norm = dM.norm(); auto M_norm = dM.norm();
bool dM_adj = false; //cf. svdtj_compute_W1H_M_W2_meth1 bool dM_adj = false; //cf. svdtj_compute_W1H_M_W2_meth1
Real<FPP> err = 1; // relative error of the SVDTJ on norms Real<FPP> err = 1; // relative error of the SVDTJ on norms
Real<FPP> prev_err = -1;
Transform<FPP, DEVICE> tW1, tW2; Transform<FPP, DEVICE> tW1, tW2;
bool loop = true; bool loop = true;
MatDense<FPP, DEVICE> W1_MW2_; // previous computation of W1' M W2 (initialization at M; no Givens yet, in svdtj_compute_W1H_M_W2_meth3) MatDense<FPP, DEVICE> W1_MW2_; // previous computation of W1' M W2 (initialization at M; no Givens yet, in svdtj_compute_W1H_M_W2_meth3)
...@@ -343,6 +340,8 @@ namespace Faust ...@@ -343,6 +340,8 @@ namespace Faust
bool better_W1 = true, better_W2 = true; bool better_W1 = true, better_W2 = true;
bool better_S = true;
auto W1_last_err = FPP2(-1); auto W1_last_err = FPP2(-1);
auto W2_last_err = FPP2(-1); auto W2_last_err = FPP2(-1);
...@@ -400,7 +399,6 @@ namespace Faust ...@@ -400,7 +399,6 @@ namespace Faust
bool verif_err_ite = ! (k1 % (err_period * t1)) && k1 >= 2 * t1; bool verif_err_ite = ! (k1 % (err_period * t1)) && k1 >= 2 * t1;
if(verif_err_ite) if(verif_err_ite)
if(better_W1) if(better_W1)
...@@ -413,15 +411,15 @@ namespace Faust ...@@ -413,15 +411,15 @@ namespace Faust
if(better_W1 && W1_last_err >= 0) if(better_W1 && W1_last_err >= 0)
better_W1 = W1_last_err > W1_err; better_W1 = W1_last_err > W1_err;
if(verbosity > 0 && ! better_W1) if(verbosity > 0 && ! better_W1 && ! W1_too_long)
std::cout << "Warning: U approximate accuracy is not increasing anymore, stopped eigtj tunning for U." << std::endl; std::cerr << "Warning: U approximate accuracy is not increasing anymore, stopped eigtj tunning for U." << std::endl;
if(better_W2 && W2_last_err >= 0) if(better_W2 && W2_last_err >= 0)
better_W2 = W2_last_err > W2_err; better_W2 = W2_last_err > W2_err;
if(verbosity > 0 && ! better_W2) if(verbosity > 0 && ! better_W2 && ! W2_too_long)
std::cout << "Warning: V approximate accuracy is not increasing anymore, stopped eigtj tunning for V." << std::endl; std::cerr << "Warning: V approximate accuracy is not increasing anymore, stopped eigtj tunning for V." << std::endl;
...@@ -452,29 +450,51 @@ namespace Faust ...@@ -452,29 +450,51 @@ namespace Faust
// // method 2 // // method 2
// auto W1_MW2 = svdtj_compute_W1H_M_W2_meth2(dM, tW1, tW2); // auto W1_MW2 = svdtj_compute_W1H_M_W2_meth2(dM, tW1, tW2);
// method 3 // method 3
if(new_W1 || new_W2 || ! W1_MW2_.getNbRow()) if(new_W1 || new_W2 || ! W1_MW2_.getNbRow())
W1_MW2 = svdtj_compute_W1H_M_W2_meth3(dM, tW1, tW2, W1_MW2_, err_period, k1, k2, t1, t2, new_W1, new_W2); W1_MW2 = svdtj_compute_W1H_M_W2_meth3(dM, tW1, tW2, W1_MW2_, err_period, k1, k2, t1, t2, new_W1, new_W2);
prev_S = S; //TODO: shouldn't be store be recomputed if needed (when better_S becomes false which is rare)
// extract S from W1_MW2
if(order < 0) if(order < 0)
for(int i=0;i<min_mn;i++) //TODO: OpenMP? for(int i=0;i<min_mn;i++)
S[i] = W1_MW2(i,i); S[i] = W1_MW2(i,i);
else if (order >= 0) else if (order >= 0)
S[i] = W1_MW2(m - min_mn + i,n - min_mn + i); S[i] = W1_MW2(m - min_mn + i,n - min_mn + i);
// compute error // compute error
auto Sd_norm = S.norm(); auto Sd_norm = S.norm();
err = (M_norm - Sd_norm); err = (M_norm - Sd_norm);
if(relErr) err /= M_norm; if(relErr) err /= M_norm;
// erase permuted factors because algoW1/W2 doesn't keep account for them (cf. GivensFGFTGen::get_transform with ord == true and copy == false
if(verbosity) if(verbosity)
std::cout << "computing the error at iteration k: " << int(k1 / t1) << " t1, t2: " << t1 << ", " << t2 << std::endl; std::cout << "computing the error at iteration k: " << int(k1 / t1) << " t1, t2: " << t1 << ", " << t2 << std::endl;
std::cout << "norm err: " << err << std::endl; std::cout << "norm err: " << err << std::endl;
if(prev_err > 0 && err > prev_err && err / prev_err >= 10)
// too bad, S has not enhanced
// stop the algorithm with the last best result
better_S = false;
if(verbosity)
std::cerr << "Singular values has stopped to improve, rollback the algorithm to previous iteration and stop." << std::endl;
S = prev_S;
err = prev_err;
break;
prev_err = err;
if(order) if(order)
...@@ -487,9 +507,9 @@ namespace Faust ...@@ -487,9 +507,9 @@ namespace Faust
// don't use tW1 and tW2 here because we want an independent copy (not linked to algoW1 and algoW2 internal data) // don't use tW1 and tW2 here because we want an independent copy (not linked to algoW1 and algoW2 internal data)
Transform<FPP,DEVICE> transW1 = std::move(algoW1->get_transform(/*order*/ order, /*copy*/ true, /*nfacts*/ better_W1?-1:algoW1->nfacts() - err_period)); Transform<FPP,DEVICE> transW1 = std::move(algoW1->get_transform(/*order*/ order, /*copy*/ true, /*nfacts*/ better_W1 && better_S?-1:algoW1->nfacts() - err_period));
Transform<FPP,DEVICE> transW2 = std::move(algoW2->get_transform(/*order*/ order, /*copy*/ true, /*nfacts*/ better_W2?-1:algoW2->nfacts() - err_period)); Transform<FPP,DEVICE> transW2 = std::move(algoW2->get_transform(/*order*/ order, /*copy*/ true, /*nfacts*/ better_W2 && better_S?-1:algoW2->nfacts() - err_period));
TransformHelper<FPP,DEVICE> *thW1 = new TransformHelper<FPP,DEVICE>(transW1, true); // true is for moving and not copying the Transform object into TransformHelper (optimization possible cause we know the original object won't be used later) TransformHelper<FPP,DEVICE> *thW1 = new TransformHelper<FPP,DEVICE>(transW1, true); // true is for moving and not copying the Transform object into TransformHelper (optimization possible cause we know the original object won't be used later)
