Commit 05feacb6 authored by hhakim's avatar hhakim
Integrate the GPU batched SVD in butterfly balanced factorization C++ impl.
parent 5ded8fa1
...@@ -188,45 +188,116 @@ namespace Faust ...@@ -188,45 +188,116 @@ namespace Faust
X.setZeros(); X.setZeros();
Y.setZeros(); Y.setZeros();
std::vector<MatDense<FPP, Cpu>> U(r), V(r); bool svd_on_gpu = false;
std::vector<std::vector<int>> rows(r), cols(r); std::vector<std::vector<int>> rows(r), cols(r);
#pragma omp parallel for schedule(dynamic) private(subA)
for(int t=0;t<r;t++) for(int t=0;t<r;t++)
rows[t] = s1.col_nonzero_inds(t); rows[t] = s1.col_nonzero_inds(t);
cols[t] = s2.row_nonzero_inds(t); cols[t] = s2.row_nonzero_inds(t);
if(dsA) }
dsA->submatrix(rows[t], cols[t], subA);
else
spA->submatrix(rows[t], cols[t], subA); if(svd_on_gpu && rows[0].size() <= 32 && rows[1].size() <= 32) // GPU batched svd is limited to 32 nrows/ncols max
//#define BUTTERFLY_APPROX_RANK1 {
#ifdef USE_GPU_MOD
compute_XY_on_gpu(A, s1, s2, X, Y, rows, cols);
#else
throw std::runtime_error("GPU SVD is not enabled in this version of FAµST.");
#endif
else
if(dsA)
else
#ifdef BUTTERFLY_APPROX_RANK1 #ifdef BUTTERFLY_APPROX_RANK1
subA.approx_rank1(U[t], V[t]); subA.approx_rank1(U[t], V[t]);
#else #else
if(A.getNbRow() >= (1 << 14) && (std::is_same<FPP, double>::value || std::is_same<FPP, std::complex<double>>::value)) if(A.getNbRow() >= (1 << 14) && (std::is_same<FPP, double>::value || std::is_same<FPP, std::complex<double>>::value))
// use jacobi svd as a workaround to this bug https://gitlab.com/libeigen/eigen/-/issues/1723
// TODO: remove when it'll be fixed
Eigen::JacobiSVD<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>> svd;
subA.initJacobiSVD(svd);
subA.best_low_rank(1, U[t], V[t], svd);
else
subA.best_low_rank(1, U[t], V[t]);
#endif
std::vector<Eigen::Triplet<FPP>> XtripletList;
std::vector<Eigen::Triplet<FPP>> YtripletList;
// use jacobi svd as a workaround to this bug https://gitlab.com/libeigen/eigen/-/issues/1723 for(int i=0;i<rows[t].size();i++)
// TODO: remove when it'll be fixed XtripletList.push_back(Eigen::Triplet<FPP>(rows[t][i], t, U[t].getData()[i]));
Eigen::JacobiSVD<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>> svd; for(int i=0;i<cols[t].size();i++)
subA.initJacobiSVD(svd); YtripletList.push_back(Eigen::Triplet<FPP>(t, cols[t][i], V[t](0,i)));
X = MatSparse<FPP, Cpu>(XtripletList, s1.getNbRow(), s1.getNbCol());
Y = MatSparse<FPP, Cpu>(YtripletList, s2.getNbRow(), s2.getNbCol());
#ifdef USE_GPU_MOD
template<typename FPP>
void compute_XY_on_gpu(const Faust::MatGeneric<FPP, Cpu>& A, const Faust::MatSparse<FPP, Cpu>& s1, const Faust::MatSparse<FPP, Cpu>& s2, Faust::MatSparse<FPP, Cpu>& X, Faust::MatSparse<FPP, Cpu>& Y, std::vector<std::vector<int>> &rows, std::vector<std::vector<int>> &cols)
const Faust::MatDense<FPP, Cpu>* dsA = dynamic_cast<const Faust::MatDense<FPP, Cpu>*>(&A);
const Faust::MatSparse<FPP, Cpu>* spA;
if(dsA == nullptr)
spA = dynamic_cast<const Faust::MatSparse<FPP, Cpu>*>(&A);
if(spA == nullptr)
throw std::runtime_error("lifting_two_layers_factorization A must be MatDense or MatSparse.");
int r = s1.getNbCol();
int m = rows[0].size(), n = cols[0].size();
MatDense<FPP, Cpu> Us(m, r), Vs(n, r);
MatDense<FPP, Cpu> Ss(r);
MatDense<FPP, Cpu> subAs(m, r * n);
for(int i=0; i < r; i++)
if(dsA)
dsA->submatrix(rows[i], cols[i], subAs.getData() + i * m * n);
else else
subA.best_low_rank(1, U[t], V[t]); spA->submatrix(rows[i], cols[i], subAs.getData() + i * m * n);
#endif
batched_svd(subAs, r /* batch_sz */, Us, Vs, Ss, /* rank */ 1);
using Map = Eigen::Map<Eigen::Matrix<FPP, Eigen::Dynamic, Eigen::Dynamic>>;
Map U(Us.getData() + i * m, m, 1);
U *= Ss(i);
Vs.adjoint();
std::vector<Eigen::Triplet<FPP>> XtripletList; std::vector<Eigen::Triplet<FPP>> XtripletList;
std::vector<Eigen::Triplet<FPP>> YtripletList; std::vector<Eigen::Triplet<FPP>> YtripletList;
Map U_(Us.getData() + t * m, m, 1);
Map V_(Vs.getData() + t * n, 1, n);
for(int i=0;i<rows[t].size();i++) for(int i=0;i<rows[t].size();i++)
XtripletList.push_back(Eigen::Triplet<FPP>(rows[t][i], t, U[t].getData()[i])); XtripletList.push_back(Eigen::Triplet<FPP>(rows[t][i], t, U_(i, 0)));
for(int i=0;i<cols[t].size();i++) for(int i=0;i<cols[t].size();i++)
YtripletList.push_back(Eigen::Triplet<FPP>(t, cols[t][i], V[t](0,i))); YtripletList.push_back(Eigen::Triplet<FPP>(t, cols[t][i], V_(0, i)));
X = MatSparse<FPP, Cpu>(XtripletList, s1.getNbRow(), s1.getNbCol()); X = MatSparse<FPP, Cpu>(XtripletList, s1.getNbRow(), s1.getNbCol());
Y = MatSparse<FPP, Cpu>(YtripletList, s2.getNbRow(), s2.getNbCol()); Y = MatSparse<FPP, Cpu>(YtripletList, s2.getNbRow(), s2.getNbCol());
#endif
template<typename FPP> template<typename FPP>
void solveDTO(const Faust::MatDense<FPP, Cpu>& A, const Faust::MatDense<FPP, Cpu>& s1, const Faust::MatDense<FPP, Cpu>& s2, Faust::MatDense<FPP, Cpu>& X, Faust::MatDense<FPP, Cpu>& Y) void solveDTO(const Faust::MatDense<FPP, Cpu>& A, const Faust::MatDense<FPP, Cpu>& s1, const Faust::MatDense<FPP, Cpu>& s2, Faust::MatDense<FPP, Cpu>& X, Faust::MatDense<FPP, Cpu>& Y)
...@@ -311,6 +382,7 @@ namespace Faust ...@@ -311,6 +382,7 @@ namespace Faust
Y.set_row_coeffs(row_id, CP, besty, i); Y.set_row_coeffs(row_id, CP, besty, i);
