Commit fe5e7067 authored by Martin Genet's avatar Martin Genet
improving robustness of gss relaxation
parent a0ea751c
......@@ -719,6 +719,11 @@ def fedic(
mypy.print_str(" "+str(t)+" s")
#mypy.print_var("dU",dU.vector().array(),tab)
dU_norm = dU.vector().norm("l2")
#mypy.print_sci("dU_norm",dU_norm,tab)
if not (numpy.isfinite(dU_norm)):
dU.vector().zero()
# relaxation
if (relax_type == "constant"):
if (k_iter == 0):
......@@ -818,19 +823,23 @@ def fedic(
relax = relax_list[numpy.argmin(relax_vals)]
mypy.print_sci("relax",relax,tab)
if (relax == 0.):
mypy.print_str("Warning! Optimal relaxation is null…",tab)
else:
assert (0), "relax_type must be \"constant\", \"aitken\" or \"gss\". Aborting."
# solution update
U.vector().axpy(relax, dU.vector())
U_norm = U.vector().norm("l2")
#mypy.print_sci("U_norm",U_norm,tab)
if (print_iterations):
#mypy.print_var("U",U.vector().array(),tab)
file_pvd_frame << (U, float(k_iter+1))
# displacement error
dU_norm = abs(relax) * dU.vector().norm("l2")
dU_norm *= abs(relax)
if (dU_norm == 0.) and (Uold_norm == 0.) and (U_norm == 0.):
dU_err = 0.
elif (Uold_norm == 0.):
