GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
ALVAREZ BARRIENTOS Felipe
dolfin_dic
c870881c
c870881c
8 years ago
Martin Genet
Downloads
Patches
New print commands
ab2383d6
fedic.py
+69
-48
69 additions, 48 deletions
fedic.py
69 additions
48 deletions
fedic.py
69
48
c870881c
@@ -18,6 +18,15 @@ import myVTKPythonLibrary as myVTK
def
print_str
tab
string
print
tab
string
def
print_var
tab
name
val
print
tab
name
str
val
def
print_sci
tab
name
val
print
tab
name
ljust
12
format
val
.4e
def
fedic
working_folder
working_basename
@@ -40,22 +49,24 @@ def fedic(
print_iterations
continue_after_fail
print
Loading mesh…
tab
print_str
tab
Loading mesh…
mesh_filename
mesh_folder
mesh_basename
.xml
assert
os
path
exists
mesh_filename
No mesh in
mesh_filename
. Aborting.
mesh
dolfin
Mesh
mesh_filename
dX
dolfin
dx
mesh
mesh_volume
dolfin
assemble
dolfin
Constant
dX
print
Computing quadrature degree for images…
print
_str
tab
ref_image_filename
images_folder
images_basename
_
str
images_k_ref
zfill
images_zfill
.vti
if
images_quadrature
is
None
images_quadrature
myFEniCS
compute_quadrature_degree
image_filename
ref_image_filename
mesh
mesh
print
images_quadrature =
str
images_quadrature
mesh
mesh
verbose
print_var
tab
images_quadrature
images_quadrature
print
Loading reference image…
print
_str
tab
images_dimension
myVTK
computeImageDimensionality
image_filename
ref_image_filename
verbose
@@ -75,6 +86,9 @@ def fedic(
cell
mesh
ufl_cell
degree
images_quadrature
quad_scheme
default
te
_quad_scheme
default
for
k
in
xrange
images_dimension
2
te
sub_elements
k
_quad_scheme
default
if
images_dimension
2
Iref
myFEniCS
ExprIm2
filename
ref_image_filename
@@ -91,9 +105,9 @@ def fedic(
element
ve
Iref_norm
dolfin
assemble
Iref
2
dX
form_compiler_parameters
quadrature_degree
images_quadrature
mesh_volume
1.
2
assert
Iref_norm
0.
Iref_norm =
str
Iref_norm
<= 0. Aborting.
print
Iref_norm =
str
Iref_norm
print
_var
tab
Iref_norm
Iref_norm
print
Defining functions…
print
_str
tab
Defining functions…
vfs
dolfin
VectorFunctionSpace
mesh
mesh
family
Lagrange
@@ -113,7 +127,7 @@ def fedic(
dU_
dolfin
TrialFunction
vfs
dV_
dolfin
TestFunction
vfs
print
Defining variational forms…
print
_str
tab
penalty
dolfin
Constant
penalty
if
images_dimension
2
Idef
myFEniCS
ExprDefIm2
@@ -159,7 +173,7 @@ def fedic(
B0
dolfin
assemble
b0
quadrature_degree
images_quadrature
B0_norm
numpy
linalg
norm
B0
assert
B0_norm
0.
B0_norm =
str
B0_norm
<= 0. Aborting.
print
B0_norm =
str
B0_norm
print
_var
tab
B0_norm
B0_norm
# linear system
A
None
@@ -167,17 +181,17 @@ def fedic(
A
dolfin
assemble
a
tensor
A
quadrature_degree
images_quadrature
B
None
print
Checking number of frames…
print
_str
tab
n_frames
len
glob
glob
images_folder
images_basename
_
images_zfill
.vti
#n_frames = 2
assert
n_frames
n_frames =
str
n_frames
<= 1. Aborting.
print
n_frames =
str
n_frames
print
_var
tab
n_frames
n_frames
assert
abs
images_k_ref
n_frames
abs(images_k_ref) =
str
images_k_ref
>= n_frames. Aborting.
images_k_ref
images_k_ref
n_frames
print
images_k_ref
str
images_k_ref
print
_var
tab
images_k_ref
images_k_ref
print
Printing initial solution…
print
_str
tab
if
not
os
path
exists
working_folder
os
mkdir
working_folder
pvd_basename
working_folder
working_basename
_
@@ -186,16 +200,17 @@ def fedic(
os
remove
vtu_filename
file_pvd
U
float
images_k_ref
print_str
tab
Looping over frames…
n_iter_tot
global_success
True
for
forward_or_backward
in
forward
backward
# not sure if this still works…
print
forward_or_backward
forward_or_backward
print
_var
tab
forward_or_backward
forward_or_backward
if
forward_or_backward
forward
k_frames
range
images_k_ref
n_frames
elif
forward_or_backward
backward
k_frames
range
images_k_ref
print
k_frames =
str
k_frames
print
_var
tab
k_frames
k_frames
if
forward_or_backward
backward
U
vector
0.
@@ -205,8 +220,9 @@ def fedic(
DIdef
init_image
filename
ref_image_filename
DDIdef
init_image
filename
ref_image_filename
tab
for
k_frame
in
k_frames
print
k_frame =
str
k_frame
print
_var
tab
k_frame
k_frame
if
print_iterations
frame_basename
working_folder
working_basename
-frame=
str
k_frame
zfill
images_zfill
@@ -223,11 +239,11 @@ def fedic(
# linear system: matrix
if
tangent_type
startswith
Idef_old
A
dolfin
assemble
a
tensor
A
quadrature_degree
images_quadrature
#print
"A = " + str(
A.array())
#print
_var(tab,"A",
A.array())
#A_norm = numpy.linalg.norm(A.array())
#print
"A_norm = " + str(
A_norm)
#print
_var(tab,"A_norm",
A_norm)
print
Loading image and image gradient…
print
_str
tab
image_filename
images_folder
images_basename
_
str
k_frame
zfill
images_zfill
.vti
Idef
init_image
filename
image_filename
DIdef
init_image
filename
image_filename
@@ -243,19 +259,20 @@ def fedic(
err_im
dI_norm
Iref_norm
file_dat_frame
write
join
str
val
for
val
in
None
None
None
None
None
None
dI_norm
err_im
None
\n
print
Running registration…
print_str
tab
tab
k_iter
success
False
while
True
print
k_iter =
str
k_iter
print
_var
tab
k_iter
k_iter
n_iter_tot
if
tangent_type
startswith
Idef
A
dolfin
assemble
a
tensor
A
quadrature_degree
images_quadrature
#print
"A = " + str(
A.array())
#print
_var(tab,"A",
A.array())
#print
"A_norm = " + str(
A_norm)
#print
_sci(tab,"A_norm",
A_norm)
# linear system: residual
if
relax_type
aitken
@@ -263,19 +280,18 @@ def fedic(
B_old
B
copy
elif
k_iter
B_old
B
#print "B_old = " + str(B_old[0])
B
dolfin
assemble
b
tensor
B
quadrature_degree
images_quadrature
#print
"B = " + str(
B.array())
#print
_var(tab,"B",
B.array())
# residual error
B_norm
numpy
linalg
norm
B
array
#print
"B_norm = " + str(
B_norm)
#print
_sci(tab,"B_norm",
B_norm)
err_res
B_norm
B0_norm
print
err_res =
str
err_res
print
_sci
tab
err_res
err_res
# linear system: solve
dolfin
solve
A
dU
vector
B
#print
"dU = " + str(
dU.vector().array())
#print
_var(tab,"dU",
# relaxation
if
relax_type
constant
@@ -290,24 +306,25 @@ def fedic(
elif
k_iter
dB
B
B_old
relax
1.
B_old
inner
dB
dB
inner
dB
print
relax =
str
relax
print
_var
tab
relax
relax
elif
relax_type
manual
B_relax
numpy
empty
relax_n_iter
B_norm_relax
numpy
empty
relax_n_iter
tab
for
relax_k
in
xrange
relax_n_iter
print
"relax_k = " + str(
relax_k)
print
_var
tab
relax_k
relax_k
U
vector
1.
relax_n_iter
dU
vector
B
dolfin
assemble
b
tensor
B
quadrature_degree
images_quadrature
B_relax
relax_k
numpy
linalg
norm
B
print
"B_relax = " + str(B
_relax[relax_k])
B_
norm_
relax
relax_k
numpy
linalg
norm
B
print
_sci
tab
B_norm_relax
B_norm
_relax
relax_k
U
vector
dU
vector
#print
_relax)
#print
_var(tab,"B_norm_relax",B_norm
_relax)
if
print_iterations
iter_basename
frame_basename
-iter=
str
k_iter
zfill
3
open
iter_basename
.dat
w
write
\n
join
join
str
val
for
val
in
float
relax_k
relax_n_iter
B_relax
relax_k
for
relax_k
in
xrange
relax_n_iter
open
iter_basename
.dat
w
write
\n
join
join
str
val
for
val
in
float
relax_k
relax_n_iter
B_
norm_
relax
relax_k
for
relax_k
in
xrange
relax_n_iter
os
system
gnuplot -e
set terminal pdf; set output
iter_basename
.pdf
; plot
iter_basename
.dat
u 1:2 w l notitle
relax_k
numpy
argmin
B_relax
relax_k
numpy
argmin
B_
norm_
relax
relax
float
relax_k
relax_n_iter
print
relax =
str
relax
print
_var
tab
relax
relax
else
assert
relax_type must be
constant
aitken
manual
. Aborting.
@@ -316,30 +333,30 @@ def fedic(
U
vector
relax
dU
vector
if
print_iterations
#print
"U = " + str(
U.vector().array())
#print
_var(tab,"U",
U.vector().array())
file_pvd_frame
U
float
k_iter
# displacement error
dU_norm
numpy
linalg
norm
dU
vector
array
print
dU_norm =
str
dU_norm
print
_sci
tab
dU_norm
dU_norm
U_norm
numpy
linalg
norm
U
vector
array
assert
U_norm
0.
U_norm =
str
U_norm
<= 0. Aborting.
print
U_norm =
str
U_norm
print
_sci
tab
U_norm
U_norm
err_disp
dU_norm
U_norm
print
err_disp =
str
err_disp
print
_sci
tab
err_disp
err_disp
# image error
if
k_iter
dI_norm_old
dI_norm
dI_norm
dolfin
assemble
Idef
Iref
2
dX
quadrature_degree
images_quadrature
mesh_volume
1.
2
#print
"dI_norm = " + str(
dI_norm)
#print
_sci(tab,"dI_norm",
dI_norm)
err_im
dI_norm
Iref_norm
print
err_im =
str
err_im
print
_sci
tab
err_im
err_im
if
k_iter
err_im_rel
1.
else
err_im_rel
abs
dI_norm
dI_norm_old
dI_norm_old
print
err_im_rel
str
err_im_rel
print
_sci
tab
err_im_rel
err_im_rel
if
print_iterations
file_dat_frame
write
join
str
val
for
val
in
k_iter
B_norm
err_res
relax
dU_norm
U_norm
err_disp
dI_norm
err_im
err_im_rel
\n
@@ -355,17 +372,19 @@ def fedic(
if
err_res
tol_res
success
True
if
success
print
Nonlinear solver converged…
print
_str
tab
break
if
k_iter
n_iter_max
global_success
False
print
Warning! Nonlinear solver failed to converge… (k_frame =
str
k_frame
print
_str
tab
str
k_frame
break
# increment counter
k_iter
tab
if
print_iterations
os
remove
frame_basename
_.pvd
file_dat_frame
close
@@ -378,13 +397,15 @@ def fedic(
U_old
vector
DU_old
vector
DU_old
vector
0.
print
Printing solution…
print
_str
tab
Printing solution…
file_pvd
U
float
k_frame
tab
if
not
success
not
continue_after_fail
break
print
n_iter_tot
str
n_iter_tot
print
_var
tab
n_iter_tot
n_iter_tot
os
remove
pvd_basename
.pvd
This diff is collapsed.
Loading
Save comment
