GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
ALVAREZ BARRIENTOS Felipe
dolfin_dic
60a98748
60a98748
7 years ago
Martin Genet
Downloads
Patches
adding option for reference mesh extention
fe5e7067
Branches containing commit
compute_strains.py
+5
-3
5 additions, 3 deletions
compute_strains.py
5 additions
3 deletions
compute_strains.py
5
3
60a98748
@@ -29,6 +29,7 @@ def compute_strains(
strain_array_name
Strain
strain_array_name
Strain
mesh_w_local_basis_folder
None
None
mesh_w_local_basis_basename
None
None
mesh_w_local_basis_ext
vtk
CYL_or_PPS
PPS
CYL_or_PPS
PPS
write_strains
write_strains
temporal_offset
None
temporal_offset
None
@@ -40,9 +41,8 @@ def compute_strains(
verbose
verbose
if
is
not
None
is
not
None
if
is
not
None
is
not
None
mesh_w_local_basis_filename
-WithLocalBasis.vtk
mesh_w_local_basis
myvtk
readUGrid
mesh_w_local_basis
myvtk
readUGrid
filename
ilename
filename
older
verbose
verbose
verbose
verbose
mesh_w_local_basis_n_cells
mesh_w_local_basis
GetNumberOfCells
mesh_w_local_basis
GetNumberOfCells
if
verbose
print
mesh_w_local_basis_n_cells =
str
if
verbose
print
str
@@ -95,13 +95,15 @@ def compute_strains(
farray_F0
ref_mesh
GetCellData
GetArray
defo_grad_array_name
farray_F0
ref_mesh
GetCellData
GetArray
for
k_frame
in
xrange
n_frames
for
k_frame
in
xrange
n_frames
print
k_frame =
str
k_frame
mesh_filename
working_folder
working_basename
_
str
k_frame
zfill
working_zfill
working_ext
mesh_filename
working_folder
working_basename
_
str
k_frame
zfill
working_zfill
working_ext
mesh
myvtk
readUGrid
mesh
myvtk
readUGrid
filename
mesh_filename
filename
mesh_filename
verbose
verbose
verbose
verbose
n_cells
mesh
GetNumberOfCells
n_cells
mesh
GetNumberOfCells
if
mesh_w_local_basis
is
not
None
if
mesh_w_local_basis
is
not
None
assert
n_cells
assert
n_cells
mesh_w_local_basis_n_cells (
str
) ≠ n_cells (
str
n_cells
). Aborting.
mesh
GetCellData
AddArray
mesh_w_local_basis
GetCellData
GetArray
part_id
mesh
GetCellData
AddArray
mesh_w_local_basis
GetCellData
GetArray
part_id
mesh
GetCellData
AddArray
mesh_w_local_basis
GetCellData
GetArray
sector_id
mesh
GetCellData
AddArray
mesh_w_local_basis
GetCellData
GetArray
sector_id
myvtk
addDeformationGradients
myvtk
This diff is collapsed.
Loading
Save comment
