GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
ALVAREZ BARRIENTOS Felipe
dolfin_dic
5355a664
5355a664
6 years ago
Martin Genet
Downloads
Patches
Cleaning code
c8ea67de
fedic.py
+2
-2
2 additions, 2 deletions
fedic.py
2 additions
2 deletions
fedic.py
2
2
5355a664
@@ -90,7 +90,8 @@ def fedic(
mypy
print_str
Checking number of frames…
tab
image_filenames
glob
glob
images_folder
images_basename
_[0-9]*
images_ext
assert
len
image_filenames
Not enough images (
images_folder
images_basename
_[0-9]*
images_ext
). Aborting.
assert
len
image_filenames
Not enough images (
images_folder
images_basename
_[0-9]*
images_ext
). Aborting.
images_zfill
len
image_filenames
rsplit
_
split
#mypy.print_var("images_zfill",images_zfill,tab+1)
if
images_n_frames
is
None
@@ -98,7 +99,6 @@ def fedic(
assert
images_n_frames
images_n_frames =
str
images_n_frames
<= 1. Aborting.
mypy
print_var
images_n_frames
images_n_frames
tab
assert
abs
images_ref_frame
images_n_frames
abs(images_ref_frame) =
str
images_ref_frame
>= images_n_frames. Aborting.
images_ref_frame
images_ref_frame
images_n_frames
This diff is collapsed.
Loading
Save comment
