GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
ALVAREZ BARRIENTOS Felipe
dolfin_dic
4c4f2dc9
4c4f2dc9
6 years ago
PATTE Cecile
Downloads
Patches
add field_name option
8cbe4001
compute_warped_images.py
+8
-6
8 additions, 6 deletions
8 additions
6 deletions
8
6
4c4f2dc9
@@ -29,6 +29,7 @@ def compute_warped_images(
ref_frame
ref_frame
ref_image_model
None
ref_image_model
None
working_ext
vtu
working_ext
vtu
field_name
displacement
verbose
verbose
ref_image_zfill
len
glob
glob
ref_image_folder
ref_image_basename
_*.vti
rsplit
_
split
ref_image_zfill
len
glob
glob
ref_image_folder
ref_image_basename
_*.vti
rsplit
_
split
@@ -56,7 +57,7 @@ def compute_warped_images(
working_zfill
len
glob
glob
working_folder
working_basename
_*.
working_ext
rsplit
_
split
working_zfill
len
glob
glob
working_folder
working_basename
_*.
working_ext
rsplit
_
split
n_frames
len
glob
glob
working_folder
working_basename
_
[0-9]
working_zfill
working_ext
n_frames
len
glob
glob
working_folder
working_basename
_
[0-9]
working_zfill
working_ext
#n_frames = 1
n_frames = 1
X
numpy
empty
3
X
numpy
empty
3
U
numpy
empty
3
U
numpy
empty
3
@@ -68,7 +69,8 @@ def compute_warped_images(
mesh
myvtk
readUGrid
mesh
myvtk
readUGrid
filename
working_folder
working_basename
_
str
k_frame
zfill
working_zfill
working_ext
filename
working_folder
working_basename
_
str
k_frame
zfill
working_zfill
working_ext
#print mesh
# print mesh
mesh
GetPointData
SetActiveVectors
field_name
warp
vtk
vtkWarpVector
warp
vtk
vtkWarpVector
if
vtk
vtkVersion
GetVTKMajorVersion
6
if
vtk
vtkVersion
GetVTKMajorVersion
6
@@ -77,9 +79,9 @@ def compute_warped_images(
warp
SetInput
mesh
warp
SetInput
mesh
warp
Update
warp
Update
warped_mesh
warp
GetOutput
warped_mesh
warp
GetOutput
myvtk.writeUGrid(
myvtk
writeUGrid
ugrid=warped_mesh,
ugrid
warped_mesh
filename=working_folder+"/"+working_basename+"-warped_"+str(k_frame).zfill(working_zfill)+"."+working_ext)
filename
working_folder
working_basename
-warped_
str
k_frame
zfill
working_zfill
working_ext
probe
vtk
vtkProbeFilter
probe
vtk
vtkProbeFilter
if
vtk
vtkVersion
GetVTKMajorVersion
6
if
vtk
vtkVersion
GetVTKMajorVersion
6
@@ -91,7 +93,7 @@ def compute_warped_images(
probe
Update
probe
Update
probed_image
probe
GetOutput
probed_image
probe
GetOutput
scalars_mask
probed_image
GetPointData
GetArray
vtkValidPointMask
scalars_mask
probed_image
GetPointData
GetArray
vtkValidPointMask
scalars_U
probed_image
GetPointData
GetArray
displacement
scalars_U
probed_image
GetPointData
GetArray
field_name
#myvtk.writeImage(
#myvtk.writeImage(
#image=probed_image,
#filename=working_folder+"/"+working_basename+"_"+str(k_frame).zfill(working_zfill)+".vti")
This diff is collapsed.
Loading
Save comment
