Commit 287ac03b authored by Martin Genet's avatar Martin Genet
New default for gss line search
parent d1181076
...@@ -61,7 +61,7 @@ class NonlinearSolver(): ...@@ -61,7 +61,7 @@ class NonlinearSolver():
elif (self.relax_type == "gss"): elif (self.relax_type == "gss"):
self.compute_relax = self.compute_relax_gss self.compute_relax = self.compute_relax_gss
self.relax_tol = parameters["relax_tol"] if ("relax_tol" in parameters) else 0 self.relax_tol = parameters["relax_tol"] if ("relax_tol" in parameters) else 0
self.relax_n_iter_max = parameters["relax_n_iter_max"] if ("relax_n_iter_max" in parameters) else 5 self.relax_n_iter_max = parameters["relax_n_iter_max"] if ("relax_n_iter_max" in parameters) else 9
# iterations control # iterations control
self.tol_dU = parameters["tol_dU"] if ("tol_dU" in parameters) else None self.tol_dU = parameters["tol_dU"] if ("tol_dU" in parameters) else None
...@@ -323,11 +323,11 @@ class NonlinearSolver(): ...@@ -323,11 +323,11 @@ class NonlinearSolver():
# self.printer.print_var("ener_list",ener_list) # self.printer.print_var("ener_list",ener_list)
if (k_relax > 1): if (k_relax > 1):
ener_min_old = ener_min ener_min_old = ener_min
relax_min = relax_list[numpy.argmin(ener_list)]
# self.printer.print_sci("relax_min",relax_min)
ener_min = min(ener_list) ener_min = min(ener_list)
# self.printer.print_sci("ener_min",ener_min) # self.printer.print_sci("ener_min",ener_min)
if (k_relax > 1) and (ener_list[0] > 0): relax_min = relax_list[numpy.argmin(ener_list)]
if (ener_list[0] > 0) and (k_relax > 1):
dener_min = ener_min-ener_min_old dener_min = ener_min-ener_min_old
self.printer.print_sci("dener_min",dener_min) self.printer.print_sci("dener_min",dener_min)
relax_err = dener_min/ener_list[0] relax_err = dener_min/ener_list[0]
