GitLab
Explore
Primary navigation
Search or go to…
C
cm
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Andreas Enge
cm
6f4e8e9d
6f4e8e9d
1 year ago
Andreas Enge
Downloads
Patches
Add a configure check for FLINT version 3 or higher.
* configure.ac: Add a check and define or not HAVE_FLINT3.
3d1f1f2c
configure.ac
+17
17 additions, 0 deletions
configure.ac
17 additions
configure.ac
17
6f4e8e9d
@@ -282,6 +282,23 @@ error
AC_MSG_RESULT(yes)
AC_MSG_RESULT(yes)
AC_DEFINE([HAVE_FLINT],[1],[Define to 1 if FLINT is present.])
AC_MSG_CHECKING(for FLINT 3 or higher)
AC_COMPILE_IFELSE(
[AC_LANG_SOURCE(
#include "flint/flint.h"
#if __FLINT_RELEASE < 30000
# error "FLINT version is less than 3.0.0"
error
#endif
AC_MSG_RESULT(yes)
AC_DEFINE([HAVE_FLINT3],[1],[Define to 1 if FLINT 3 or later is present.])
AC_MSG_RESULT(no)
AC_MSG_RESULT([no, only FLINT version >= 2.7.0 works with CM])
This diff is collapsed.
Loading
Save comment
