GitLab
Explore
Primary navigation
Search or go to…
N
NutriMorph
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
DEBREUVE Eric
NutriMorph
c8b83d38
c8b83d38
4 years ago
NADAL Morgane
Downloads
Patches
tests frangi3d skimage + python
905b5135
2
2 changed files
brick/processing/frangi3.py
+12
12 additions, 0 deletions
nutrimorph.py
+1
-1
1 addition, 1 deletion
nutrimorph.py
13 additions
1 deletion
12
c8b83d38
@@ -44,6 +44,7 @@ from typing import Callable, Optional, Tuple
import
numpy
as
np_
from
multiprocessing.sharedctypes
import
Array
as
shared_array_t
from
scipy
import
ndimage
as
im_
import
skimage.filters
as
fl_
_folder
_
ph_
split
ph_
realpath
__file__
if
_folder
__len__
@@ -201,6 +202,15 @@ def _EnhancementWSequentialScales(
enhanced
None
scale_map
None
# local_enhanced = fl_.frangi(
# img,
# sigmas=scales,
# alpha=alpha,
# beta=beta,
# gamma=frangi_c,
# black_ridges=not bright_on_dark,
for
s_idx
scale
in
enumerate
scales
local_enhanced
method_fct
@@ -212,6 +222,8 @@ def _EnhancementWSequentialScales(
bright_on_dark
bright_on_dark
# print(f"scale={scale}")
if
s_idx
larger_map
local_enhanced
enhanced
enhanced
larger_map
local_enhanced
larger_map
This diff is collapsed.
nutrimorph.py
c8b83d38
@@ -348,7 +348,7 @@ if with_plot:
pl_
show
po_
MaximumIntensityProjectionZ
som_nfo
soma_w_ext_lmp
po_.MaximumIntensityProjectionZ(ext_nfo['lmp_soma'])
po_
ext_nfo
lmp_soma
# --- Extract all the extensions of all somas as a graph
print
\n
--- Graph extraction
Loading
Save comment
