GitLab
Explore
Primary navigation
Search or go to…
N
NutriMorph
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
DEBREUVE Eric
NutriMorph
8fedfebd
8fedfebd
4 years ago
NADAL Morgane
Downloads
Patches
dvpt pca
98cd4399
Branches containing commit
features_analysis.py
+161
-22
161 additions, 22 deletions
161 additions
22 deletions
161
22
8fedfebd
@@ -39,10 +39,21 @@ import scipy as si_
import
seaborn
as
sb_
import
seaborn
as
sb_
import
os
import
os
import
glob
import
glob
import
pandas
as
pd
from
typing
import
def
KmeansOnDF
df
pd_
DataFrame
nb_clusters
tuple
representation
bool
False
labeled_somas
None
elbow
bool
False
intracluster_var
bool
True
def
KmeansOnDF
df
pd_
DataFrame
nb_clusters
tuple
representation
bool
False
labeled_somas
None
elbow
bool
False
intracluster_var
bool
True
KMeans
Perform kmeans on the pandas dataframe. Can find the best number of cluster with elbow method,
find the intracluster variance, and represent the result on the initial images.
Returns kmeans.
# Data standardization
scaler
StandardScaler
scaler
StandardScaler
scaler
fit
df
scaler
fit
df
@@ -97,6 +108,9 @@ def IntraClusterVariance(df: pd_.DataFrame(), kmeans: KMeans(), nb_cluster: int)
def
RepresentationOnImages
labeled_somas
kmeans
nb_cluster
def
labeled_somas
kmeans
nb_cluster
Represent the result of kmeans on labeled image. IN DVPT. Only available for a kmean intra-image.
clustered_somas
labeled_somas
copy
clustered_somas
labeled_somas
copy
clustered_somas
np_
amax
clustered_somas
axis
clustered_somas
np_
amax
clustered_somas
axis
for
indx
value
in
enumerate
kmeans
labels_
for
indx
value
in
enumerate
kmeans
labels_
@@ -130,26 +144,151 @@ def FeaturesStatistics(df):
pl_
close
pl_
close
def
PCAOnDF
df
pd_
DataFrame
def
PCAOnDF
df
pd_
DataFrame
target
str
targets
str
colors
str
save_name
str
None
title
str
list
Perform 2D PCA on the CHO-DIO dataframe.
Print ratio variance and plot the PCA.
# Separating the features from their conditions and durations
# all_target = df.loc[:, [target]].values
df_all
df
drop
target
axis
# Standardize the data
scaler
StandardScaler
scaler
StandardScaler
scaler
fit
df
scaler
fit
df
_all
stand_df
scaler
transform
df
stand_df
scaler
transform
df
_all
# Create the PCA and fit the data
pca
PCA
n_components
2
pca
PCA
n_components
2
principalComponents
pca
fit_transform
stand_df
principal_components
pca
fit_transform
stand_df
principalDf
pd
DataFrame
principalComponents
columns
principal component 1
principal component 2
print
f
PCA explained variance ratio (
save_name
pca
explained_variance_ratio_
principal_df
pd_
DataFrame
columns
# if __name__ == "__main__":
# os.chdir("D:\MorganeNadal\Results\Features")
# Give the final df containing the principal component and their condition
# all_filenames = [i for i in glob.glob('*.{}'.format("csv"))]
final_df
pd_
concat
principal_df
df
target
axis
# print(all_filenames)
# df = pd_.concat([pd_.read_csv(f, index_col=0) for f in all_filenames])
# Plot
# # df.to_csv("D:\MorganeNadal\Results\combined_features.csv")
fig
pl_
figure
figsize
8
8
# # labeled_somas = np_.load("D:\\MorganeNadal\\Results\\labeled_somas.npy")
ax
fig
add_subplot
# # df = pd_.read_csv("D:\\MorganeNadal\\M2 report\\Results\\features_all_images_DIO_CHO_.csv", index_col=0)
ax
set_xlabel
Principal Component 1
fontsize
15
# df = df.drop(["spherical_angles_eva", "spherical_angles_evb", "hist_lengths", "hist_lengths_P", "hist_lengths_S",
ax
set_ylabel
Principal Component 2
fontsize
15
# "hist_curvature", "hist_curvature_P", "hist_curvature_S"],
ax
set_title
f
2 component PCA
title
fontsize
20
# axis=1)
for
tgt
color
in
zip
targets
colors
# KMeansIntraImage(df, nb_clusters=(2,))
idx
final_df
target
tgt
# # FeatureDistribution(df)
ax
scatter
final_df
loc
idx
\ No newline at end of file
final_df
loc
idx
c
color
s
30
ax
legend
targets
ax
grid
if
save_name
is
not
None
pl_
savefig
f
D:
MorganeNadal
2_RESULTS
Results_wo_erosion
Features_analysis
PCA_
save_name
.png
return
pca
if
__name__
__main__
# os.chdir("D:\\MorganeNadal\\2_RESULTS\\Results_wo_erosion")
## If need to concatenate files:
# df.to_csv(".\combined_features.csv")
## If use labeled somas:
# df = pd_.read_csv(".\combined_features.csv", index_col=0)
df0
pd_
read_csv
D:
MorganeNadal
2_RESULTS
Results_wo_erosion
all_features.csv
# index_col=0,
df
df0
drop
Unnamed: 0
axis
# Statistical analysis
# For the moment drop the columns with non scalar values, and un-useful values
# - TO BE CHANGED (use distance metrics such as bhattacharyya coef, etc)
df
df
drop
soma uid
hist_lengths
hist_lengths_P
hist_lengths_S
hist_curvature
hist_curvature_P
hist_curvature_S
axis
df
df
dropna
axis
how
any
# -- PCA with all the features
# Between the two conditions, regardless the duration of experiment (2 conditions, all durations)
df_all
df
drop
duration
axis
all_pca
PCAOnDF
df_all
target
condition
targets
CHO
DIO
colors
b
r
save_name
all_features
# Between the two conditions, for each duration (2 conditions, 3 durations)
groupby_duration
df
groupby
duration
duration_pca
for
duration
values
in
groupby_duration
# print(duration, values.shape)
# groupby_condition = values.groupby("condition")
# for cond, val in groupby_condition:
# print(cond, val.shape)
## duration: str, values: pd_.DataFrame()
duration_df
values
drop
duration
axis
pca
PCAOnDF
duration_df
target
condition
targets
CHO
DIO
colors
b
r
save_name
f
duration
_features
title
f
duration
Sample
duration_pca
append
pca
## -- K-means with all the features (2 conditions)
## Between the two conditions, regardless the duration of experiment (2 conditions, all durations)
# kmeans = fa_.KmeansOnDF(concatenated_features_df, nb_clusters=(2,), elbow=True, intracluster_var=True)
## Between the two conditions, for each duration (2 conditions, 3 durations)
# for duration, values in groupby_duration:
# kmeans = fa_.KmeansOnDF(values, nb_clusters=(2,), elbow=True, intracluster_var=True)
## -- Select Discriminant features by statistical analysis
# TODO filtered_df = SelectFeatures(concatenated_features_df)
## -- PCA with all the features with the cluster as label
# TODO pca = fa_.PCAOnDF(concatenated_features_df)
# pca = fa_.PCAOnDF(values)
## -- PCA with selected features
# TODO pca = fa_.PCAOnDF(filtered_df)
# filtered_groupby_duration = filtered_df.groupby("Duration")
# for duration, values in filtered_groupby_duration:
## -- K-means with selected features
# filtered_kmeans = fa_.KmeansOnDF(filtered_df, nb_clusters=(2,), elbow=True, intracluster_var=True)
# filtered_kmeans = fa_.KmeansOnDF(values, nb_clusters=(2,), elbow=True, intracluster_var=True)
This diff is collapsed.
Loading
Save comment
