Commit 8e25ca73 authored by DEBREUVE Eric's avatar DEBREUVE Eric
corrected wrong method name
parent 1ab35221
...@@ -125,7 +125,7 @@ print("\n--- Extension <-> Extension") ...@@ -125,7 +125,7 @@ print("\n--- Extension <-> Extension")
should_look_for_connections = True should_look_for_connections = True
while should_look_for_connections: while should_look_for_connections:
som_nfo["soma_w_ext_lmp"] = soma_t.SomasWithExtensionsLMap(somas) som_nfo["soma_w_ext_lmp"] = soma_t.SomasLMap(somas)
som_nfo["dist_to_closest"], som_nfo["influence_map"] = soma_t.InfluenceMaps( som_nfo["dist_to_closest"], som_nfo["influence_map"] = soma_t.InfluenceMaps(
som_nfo["soma_w_ext_lmp"] som_nfo["soma_w_ext_lmp"]
