Commit 87d5683e authored by NADAL Morgane's avatar NADAL Morgane
corrected error in ToPixel
parent 78cca4dc
......@@ -132,17 +132,15 @@ def FindVoxelDimensionInMicron(data_path: str) -> array_t:
print('/!\ Unable to find the voxel dimensions in micron in the metadata. Please specify it in the parameters.')
def ToPixel(micron: float, voxel_size_micron: array_t) -> int:
# Conversion of pixels into micron. Used in morphomath (disk structuring element mp_.disk(n_pixel)).
# Assumes that the axes X and Y have the same ratio pixel:micron.
return round(micron/voxel_size_micron[0])
def ToPixel(micron: float, voxel_size_micron: array_t, dimension: int = 1, axis: int = 0) -> int:
return round(micron/(voxel_size_micron[axis]**dimension))
def ToMicron(pixel: int, voxel_size_micron: array_t) -> float:
def ToMicron(pixel: int, voxel_size_micron: array_t, dimension: int = 1, axis: int = 0) -> float:
# May not be used. if not used, delete.
# Conversion of micron into pixels.
return float(pixel * voxel_size_micron[0])
return float(pixel * (voxel_size_micron[axis])**dimension)
def DijkstraCosts(image: array_t, som_map: array_t, ext_map: array_t) -> array_t:
......@@ -90,16 +90,17 @@ start_time = tm_.time()
# --- Images
# Find the dimension of the image voxels in micron
size_voxel_in_micron = in_.FindVoxelDimensionInMicron(data_path)
image = io_.imread(data_path)
# Image size verification - simple version without user interface
image = in_.ImageVerification(image, channel)
# iv_.image_verification(image, channel) # -> PySide2 interface # TODO: must return the modified image!
# /!\ conflicts between some versions of PySide2 and Python3
image = image[:, 512:, 512:] # 562
image = image[:, 512:, 512:] # 562 # Just for development
img_shape = image.shape
# pl_.matshow(image[image.shape[0] // 2, :, :])
# pl_.show()
......@@ -129,7 +130,7 @@ axes = {}
# --- Somas
print("\n--- Soma Detection")
soma_min_area_c = in_.ToPixel(soma_min_area_c, size_voxel_in_micron)
soma_min_area_c = in_.ToPixel(soma_min_area_c, size_voxel_in_micron, dimension=2)
soma_selem_c = mp_.disk(in_.ToPixel(soma_selem_micron_c, size_voxel_in_micron))
som_nfo["map"] = soma_t.Map(image_for_soma, soma_low_c, soma_high_c, soma_selem_c)
......@@ -155,7 +156,7 @@ if with_plot:
# -- Extentions
print("\n--- Extension Detection")
ext_min_area_c = in_.ToPixel(ext_min_area_c, size_voxel_in_micron)
ext_min_area_c = in_.ToPixel(ext_min_area_c, size_voxel_in_micron, dimension=2)
ext_selem_pixel_c = mp_.disk(in_.ToPixel(ext_selem_micron_c, size_voxel_in_micron))
......@@ -286,3 +287,5 @@ print(f"DONE: {tm_.strftime('%a, %b %d %Y @ %H:%M:%S')}")
if with_plot:
pl_.show()
# graph = skl_graph_t.FromSkeleton(soma_map) # Travailler apd squelettes (soma pas sous fore de sk)
\ No newline at end of file
......@@ -42,7 +42,7 @@ soma_low_c: 0.15
soma_high_c: 0.7126
soma_selem_micron_c: 0.24050024 * 2
# soma_selem_c = mp_.disk(2)
soma_min_area_c: 0.24050024 * 1000
soma_min_area_c: (0.24050024 ** 2) * 1000
;soma_min_area_c: 1000
[Extensions]
......@@ -52,7 +52,7 @@ ext_high_c: 0.6
# 0.04 # 0.6 # high_ext = 8.0e-3
ext_selem_micron_c: 0.24050024 * 1
# ext_selem_c = mp_.disk(1)
ext_min_area_c: 0.24050024 * 100
ext_min_area_c: (0.24050024 ** 2) * 100
;ext_min_area_c: 100 # pixels
[Connexions]
......@@ -37,19 +37,19 @@ with_plot = False
soma_low_c = 0.15
soma_high_c = 0.7126
ext_low_c = 3 #1e-7 ##0.2 # 0.02 # 0.2 # ext_low_c = 9.0e-4
ext_high_c = 1e-10 #1.2e-7 ##0.6 # 0.04 # 0.6 # high_ext = 8.0e-3
ext_low_c = 0.2 #3 #1e-7 ##0.2 # 0.02 # 0.2 # ext_low_c = 9.0e-4
ext_high_c = 0.6 #1e-10 #1.2e-7 ##0.6 # 0.04 # 0.6 # high_ext = 8.0e-3
soma_selem_micron_c = 0.24050024 * 2
ext_selem_micron_c = 0.24050024 * 1
max_straight_sq_dist_c = (30 ** 2) * 0.24050024
max_weighted_length_c = 20.0 * 0.24050024
soma_min_area_c = 1000 * 0.24050024
ext_min_area_c = 100 * 0.24050024
soma_min_area_c = 1000 * (0.24050024 ** 2)
ext_min_area_c = 100 * (0.24050024 ** 2)
# soma_min_area_c = 1000
# ext_min_area_c = 100
