Commit 4d83b318 authored by NADAL Morgane's avatar NADAL Morgane
handle singular matrices
parent 685f23fe
...@@ -42,17 +42,22 @@ def ls_ellipsoid(xx: array_t, yy: array_t, zz: array_t) -> array_t: # finds the ...@@ -42,17 +42,22 @@ def ls_ellipsoid(xx: array_t, yy: array_t, zz: array_t) -> array_t: # finds the
JT = J.transpose() JT = J.transpose()
JTJ = np_.dot(JT, J) JTJ = np_.dot(JT, J)
InvJTJ = np_.linalg.inv(JTJ); try:
ABC = np_.dot(InvJTJ, np_.dot(JT, K)) InvJTJ = np_.linalg.inv(JTJ);
# Rearrange, move the 1 to the other side # Rearrange, move the 1 to the other side
# Ax^2 + By^2 + Cz^2 + Dxy + Exz + Fyz + Gx + Hy + Iz - 1 = 0 # Ax^2 + By^2 + Cz^2 + Dxy + Exz + Fyz + Gx + Hy + Iz - 1 = 0
# or # or
# Ax^2 + By^2 + Cz^2 + Dxy + Exz + Fyz + Gx + Hy + Iz + J = 0 # Ax^2 + By^2 + Cz^2 + Dxy + Exz + Fyz + Gx + Hy + Iz + J = 0
# where J = -1 # where J = -1
ellipsoid_coef = np_.append(ABC, -1) ellipsoid_coef = np_.append(ABC, -1)
return (ellipsoid_coef) return (ellipsoid_coef)
except:
print("Singular matrix, cannot find the best fitting ellipsoid.")
return (np_.zeros(9))
def polyToParams3D(ellipsoid_coef: array_t, printMe: bool = False) -> tuple: def polyToParams3D(ellipsoid_coef: array_t, printMe: bool = False) -> tuple:
...@@ -70,74 +75,78 @@ def polyToParams3D(ellipsoid_coef: array_t, printMe: bool = False) -> tuple: ...@@ -70,74 +75,78 @@ def polyToParams3D(ellipsoid_coef: array_t, printMe: bool = False) -> tuple:
if printMe: if printMe:
print('\npolynomial\n', ellipsoid_coef) print('\npolynomial\n', ellipsoid_coef)
Amat = np_.array( if ellipsoid_coef == (np_.zeros(9)):
[ return "NaN", "NaN", "NaN", "NaN"
[ellipsoid_coef[0], ellipsoid_coef[3] / 2.0, ellipsoid_coef[4] / 2.0, ellipsoid_coef[6] / 2.0],
[ellipsoid_coef[3] / 2.0, ellipsoid_coef[1], ellipsoid_coef[5] / 2.0, ellipsoid_coef[7] / 2.0], else:
[ellipsoid_coef[4] / 2.0, ellipsoid_coef[5] / 2.0, ellipsoid_coef[2], ellipsoid_coef[8] / 2.0], Amat = np_.array(
[ellipsoid_coef[6] / 2.0, ellipsoid_coef[7] / 2.0, ellipsoid_coef[8] / 2.0, ellipsoid_coef[9]] [
]) [ellipsoid_coef[0], ellipsoid_coef[3] / 2.0, ellipsoid_coef[4] / 2.0, ellipsoid_coef[6] / 2.0],
if printMe: [ellipsoid_coef[4] / 2.0, ellipsoid_coef[5] / 2.0, ellipsoid_coef[2], ellipsoid_coef[8] / 2.0],
print('\nAlgebraic form of polynomial\n', Amat) [ellipsoid_coef[6] / 2.0, ellipsoid_coef[7] / 2.0, ellipsoid_coef[8] / 2.0, ellipsoid_coef[9]]
# See B.Bartoni, Preprint SMU-HEP-10-14 Multi-dimensional Ellipsoidal Fitting
# equation 20 for the following method for finding the center if printMe:
A3 = Amat[0:3, 0:3] print('\nAlgebraic form of polynomial\n', Amat)
A3inv = inv(A3)
ofs = ellipsoid_coef[6:9] / 2.0 # See B.Bartoni, Preprint SMU-HEP-10-14 Multi-dimensional Ellipsoidal Fitting
center = -np_.dot(A3inv, ofs) # equation 20 for the following method for finding the center
if printMe: A3 = Amat[0:3, 0:3]
print('\nCenter at:', center) A3inv = inv(A3)
# Center the ellipsoid at the origin center = -np_.dot(A3inv, ofs)
Tofs = np_.eye(4) if printMe:
Tofs[3, 0:3] = center print('\nCenter at:', center)
R = np_.dot(Tofs, np_.dot(Amat, Tofs.T))
if printMe: # Center the ellipsoid at the origin
print('\nAlgebraic form translated to center\n', R, '\n') Tofs = np_.eye(4)
R3 = R[0:3, 0:3] R = np_.dot(Tofs, np_.dot(Amat, Tofs.T))
s1 = -R[3, 3] if printMe:
R3S = R3 / s1 print('\nAlgebraic form translated to center\n', R, '\n')
(el, ec) = eig(R3S) R3 = R[0:3, 0:3]
el = np_.abs(el) s1 = -R[3, 3]
R3S = R3 / s1
# Sorting in descending order of the eigenvalues and eigenvectors
sorting_vec = np_.argsort(-el) (el, ec) = eig(R3S)
el = el[sorting_vec] el = np_.abs(el)
ec = ec[:, sorting_vec]
# Calculating cartesian axes sorting_vec = np_.argsort(-el)
recip = 1.0 / el el = el[sorting_vec]
axes = np_.sqrt(recip) # axes are in ascending order ec = ec[:, sorting_vec]
if printMe:
print('\nAxes are\n', axes, '\n') # Calculating cartesian axes
recip = 1.0 / el
# Calculating the orientation axes = np_.sqrt(recip) # axes are in ascending order
inverse = inv(ec) # inverse is actually the transpose here if printMe:
if printMe: print('\nAxes are\n', axes, '\n')
print('\nRotation matrix\n', inverse)
# Calculating spherical axes inverse = inv(ec) # inverse is actually the transpose here
# # eigenvector 1 if printMe:
r1 = np_.sqrt(sum(axe**2 for axe in ec[:, 0])) print('\nRotation matrix\n', inverse)
phi1 = np_.arctan2(ec[1, 0], ec[0, 0])
theta1 = np_.arccos(ec[2, 0] / r1) # Calculating spherical axes
spherical_axes1 = (r1, theta1, phi1) # # eigenvector 1
# # eigenvector 2 r1 = np_.sqrt(sum(axe**2 for axe in ec[:, 0]))
r2 = np_.sqrt(sum(axe**2 for axe in ec[:, 1])) phi1 = np_.arctan2(ec[1, 0], ec[0, 0])
phi2 = np_.arctan2(ec[1, 1], ec[0, 1]) theta1 = np_.arccos(ec[2, 0] / r1)
theta2 = np_.arccos(ec[2, 1] / r2) spherical_axes1 = (r1, theta1, phi1)
spherical_axes2 = (r2, theta2, phi2) # # eigenvector 2
spherical_axes = (spherical_axes1, spherical_axes2) phi2 = np_.arctan2(ec[1, 1], ec[0, 1])
if printMe: spherical_axes2 = (r2, theta2, phi2)
print('\nAxes in spherical coord are\n', spherical_axes, '\n')
return center, axes, inverse, spherical_axes
if printMe:
def GetConvexHull3D(soma_sites: site_h) -> tuple: def GetConvexHull3D(soma_sites: site_h) -> tuple:
...@@ -169,7 +178,12 @@ def FindBestFittingEllipsoid3D(soma: soma_t) -> tuple: ...@@ -169,7 +178,12 @@ def FindBestFittingEllipsoid3D(soma: soma_t) -> tuple:
# fit ellipsoid on the convex hull # fit ellipsoid on the convex hull
# # get ellipsoid polynomial coefficients # # get ellipsoid polynomial coefficients
ellipsoid_coef = ls_ellipsoid(convex_hull[0], convex_hull[1], convex_hull[2]) ellipsoid_coef = ls_ellipsoid(convex_hull[0], convex_hull[1], convex_hull[2])
# # get ellipsoid 3D parameters
center, axes, orientation, spherical_coor = polyToParams3D(ellipsoid_coef, False)
return ellipsoid_coef, center, axes, orientation, spherical_coor, convex_hull, volume_hull if ellipsoid_coef == (np_.zeros(9)):
return ellipsoid_coef, "NaN", "NaN", "NaN", "NaN", "NaN", "NaN"
else:
