GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
ef3d0831
ef3d0831
8 years ago
Martin Genet
Downloads
Patches
New print_tools.py file
0f0c9f88
3
3 changed files
fedic.py
+2
-11
2 additions, 11 deletions
fedic.py
image_expressions_cpp.py
+0
0 additions, 0 deletions
print_tools.py
+44
44 additions, 0 deletions
print_tools.py
46 additions
11 deletions
fedic.py
2
11
ef3d0831
@@ -14,22 +14,13 @@ import numpy
import
os
import
myFEniCSPythonLibrary
as
myFEniCS
import
myVTKPythonLibrary
as
myVTK
from
print_tools
import
dolfin
parameters
form_compiler
cpp_optimize_flags
-O3
dolfin
parameters
form_compiler
cpp_optimize
True
dolfin
parameters
form_compiler
optimize
True
def
print_str
tab
string
print
tab
string
def
print_var
tab
name
val
print
tab
name
str
val
def
print_sci
tab
name
val
print
tab
name
ljust
13
format
val
.4e
dolfin
parameters
form_compiler
optimize
False
# can't use that for "complex" mechanical models…
This diff is collapsed.
image_expressions.py
image_expressions
_cpp
.py
ef3d0831
File moved
print_tools.py
44
ef3d0831
#coding=utf8
### Created by Martin Genet, 2016 ###
### École Polytechnique, Palaiseau, France ###
import
myVTKPythonLibrary
as
myVTK
#class Printer:
#def __init__(self):
#self.cur_level = 0
#def inc(self):
#self.cur_level += 1
#def dec(self):
#self.cur_level -= 1
#def print_str(self, string, var_level=0):
#print " | "*(self.cur_level+var_level) + string
#def print_var(self, name, val, var_level=0):
#print " | "*(self.cur_level+var_level) + name + " = " + str(val)
#def print_sci(self, name, val, var_level=0):
#print " | "*(self.cur_level+var_level) + name.ljust(13) + " = " + format(val,".4e")
def
print_str
tab
string
print
tab
string
def
print_var
tab
name
val
print
tab
name
str
val
def
print_sci
tab
name
val
print
tab
name
ljust
13
format
val
.4e
Loading
Save comment
