GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
e599b20e
e599b20e
5 years ago
Martin Genet
Downloads
Patches
Naming convention
fdbf833b
compute_strains.py
+13
-12
13 additions, 12 deletions
compute_strains.py
13 additions
12 deletions
compute_strains.py
13
12
e599b20e
@@ -23,11 +23,11 @@ def compute_strains(
working_folder
working_basename
working_ext
vtu
ref_frame
None
ref_frame
None
# MG20190612: Reference configuration.
disp_array_name
displacement
defo_grad_array_name
DeformationGradient
strain_array_name
Strain
ref_mesh_folder
None
ref_mesh_folder
None
# MG20190612: Mesh with sectors/parts/etc.
ref_mesh_basename
None
ref_mesh_ext
vtk
CYL_or_PPS
PPS
@@ -41,8 +41,9 @@ def compute_strains(
verbose
if
ref_mesh_folder
is
not
None
ref_mesh_basename
is
not
None
ref_mesh_filename
ref_mesh_folder
ref_mesh_basename
ref_mesh_ext
ref_mesh
myvtk
readUGrid
filename
ref_mesh_f
older
ref_mesh_basename
ref_mesh_ext
filename
ref_mesh_f
ilename
verbose
verbose
ref_mesh_n_cells
ref_mesh
GetNumberOfCells
if
verbose
print
ref_mesh_n_cells =
str
ref_mesh_n_cells
@@ -61,9 +62,9 @@ def compute_strains(
n_sector_ids
if
ref_mesh
GetCellData
HasArray
part_id
part_id
_array
ref_mesh
GetCellData
GetArray
part_id
iarray_
part_id
ref_mesh
GetCellData
GetArray
part_id
else
part_id
_array
None
iarray_
part_id
None
else
ref_mesh
None
@@ -91,15 +92,15 @@ def compute_strains(
binned_strain_vs_radius_file
write
#t rr Err Ecc Ell Erc Erl Ecl
\n
if
ref_frame
is
not
None
mesh_filename
working_folder
working_basename
_
str
ref_frame
zfill
working_zfill
working_ext
mesh
myvtk
readUGrid
filename
mesh_filename
mesh
_filename
working_folder
working_basename
_
str
ref_frame
zfill
working_zfill
working_ext
mesh
myvtk
readUGrid
filename
mesh
_filename
verbose
verbose
myvtk
addDeformationGradients
mesh
mesh
mesh
mesh
disp_array_name
disp_array_name
verbose
verbose
farray_F0
mesh
GetCellData
GetArray
farray_F0
mesh
GetCellData
GetArray
for
k_frame
in
xrange
n_frames
print
k_frame =
str
k_frame
@@ -111,8 +112,8 @@ def compute_strains(
n_cells
mesh
GetNumberOfCells
if
ref_mesh
is
not
None
assert
n_cells
ref_mesh_n_cells
ref_mesh_n_cells (
str
ref_mesh_n_cells
) ≠ n_cells (
str
n_cells
). Aborting.
if
part_id
_array
is
not
None
mesh
GetCellData
AddArray
part_id
_array
if
iarray_
part_id
is
not
None
mesh
GetCellData
AddArray
iarray_
part_id
if
iarray_sector_id
is
not
None
mesh
GetCellData
AddArray
iarray_sector_id
myvtk
This diff is collapsed.
Loading
Save comment
