GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
da02b566
da02b566
5 years ago
Martin Genet
Downloads
Patches
compute quadrature degree now returns an int
1a5815d2
Branches containing commit
compute_quadrature_degree.py
+6
-3
6 additions, 3 deletions
6 additions
3 deletions
6
3
da02b566
@@ -26,7 +26,7 @@ def compute_quadrature_degree_from_points_count(
compute_n_quad
False
deg_min
deg_max
20
verbose
verbose
myvtk
readImage
filename
image_filename
@@ -38,6 +38,7 @@ def compute_quadrature_degree_from_points_count(
ugrid
ddic
mesh2ugrid
mesh
n_cells
ugrid
GetNumberOfCells
if
verbose
print
n_cells =
str
n_cells
cell_locator
closest_point
@@ -51,9 +52,11 @@ def compute_quadrature_degree_from_points_count(
point
numpy
empty
3
n_pixels_per_cell
numpy
zeros
n_cells
dtype
int
for
k_point
in
range
image_n_points
# if (verbose): print("k_point = "+str(k_point))
GetPoint
k_point
point
k_cell
cell_locator
FindCell
point
# if (verbose): print("k_cell = "+str(k_cell))
if
k_cell
continue
else
n_pixels_per_cell
k_cell
n_pixels_per_cell_max
max
n_pixels_per_cell
@@ -85,8 +88,8 @@ def compute_quadrature_degree_from_points_count(
n_quads
3
6
6
7
12
16
25
25
36
36
49
49
64
64
81
81
100
100
121
elif
image_dimension
3
n_quads
4
5
14
15
24
64
125
125
216
216
343
343
512
512
729
729
#degree = numpy.searchsorted(n_quads, n_pixels_per_cell_max)+1
degree
numpy
searchsorted
n_quads
n_pixels_per_cell_avg
#degree =
int(
degree
int
numpy
searchsorted
n_quads
return
degree
This diff is collapsed.
Loading
Save comment
