GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
c92df657
c92df657
8 years ago
Martin Genet
Downloads
Patches
Image interpolator with out value
c870881c
image_expressions.py
+21
-12
21 additions, 12 deletions
21 additions
12 deletions
21
12
c92df657
@@ -12,6 +12,7 @@ import dolfin
import
numpy
import
myVTKPythonLibrary
as
myVTK
from
myVTKPythonLibrary.mat_vec_tools
import
@@ -39,7 +40,10 @@ class ExprIm2(dolfin.Expression):
#print self.s
self
interpolator
myVTK
createImageInterpolator
self
out_value
0.
verbose
#print "ExprIm2.interpolator.GetNumberOfComponents() = " + str(self.interpolator.GetNumberOfComponents())
#print "ExprIm2.interpolator.GetOutValue() = " + str(self.interpolator.GetOutValue())
def
eval
self
Expr
X
#print "Expr"
@@ -64,6 +68,7 @@ class ExprIm3(dolfin.Expression):
#print self.s
self
interpolator
myVTK
self
out_value
0.
verbose
def
eval
self
Expr
X
@@ -91,7 +96,10 @@ class ExprGradIm2(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
#print "ExprGradIm2.interpolator.GetNumberOfComponents() = " + str(self.interpolator.GetNumberOfComponents())
#print "ExprGradIm2.interpolator.GetOutValue() = " + str(self.interpolator.GetOutValue())
def
value_shape
self
return
2
@@ -117,6 +125,7 @@ class ExprGradIm3(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
@@ -131,7 +140,6 @@ class ExprHessIm2(dolfin.Expression):
if
filename
is
not
None
self
init_image
filename
filename
self
X
numpy
array
float
2
Z
self
H_vec
numpy
empty
4
def
init_image
self
filename
self
myVTK
readImage
@@ -144,6 +152,7 @@ class ExprHessIm2(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
@@ -151,15 +160,13 @@ class ExprHessIm2(dolfin.Expression):
def
eval
self
Expr
X
self
X
X
self
interpolator
Interpolate
self
X
self
H_vec
cvec4_to_mat22
self
H_vec
Expr
self
interpolator
Interpolate
self
X
Expr
Expr
self
s
class
ExprHessIm3
dolfin
Expression
def
__init__
self
filename
None
kwargs
if
filename
is
not
None
self
init_image
filename
filename
self
H_vec
numpy
empty
9
def
init_image
self
filename
self
myVTK
readImage
@@ -172,14 +179,14 @@ class ExprHessIm3(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
return
3
3
def
eval
self
Expr
X
self
interpolator
Interpolate
X
self
H_vec
cvec9_to_mat33
self
H_vec
Expr
self
interpolator
Interpolate
X
Expr
Expr
self
s
class
ExprDefIm2
dolfin
Expression
@@ -198,6 +205,7 @@ class ExprDefIm2(dolfin.Expression):
self
GetScalarTypeAsString
self
interpolator
myVTK
self
out_value
0.
verbose
def
eval
self
Expr
X
@@ -232,6 +240,7 @@ class ExprDefIm3(dolfin.Expression):
#print self.s
self
interpolator
myVTK
self
out_value
0.
verbose
def
eval
self
Expr
X
@@ -268,6 +277,7 @@ class ExprGradDefIm2(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
@@ -307,6 +317,7 @@ class ExprGradDefIm3(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
@@ -334,7 +345,6 @@ class ExprHessDefIm2(dolfin.Expression):
self
U
U
self
UX
numpy
empty
2
self
x
numpy
array
float
2
Z
self
H_vec
numpy
empty
4
def
init_image
self
filename
self
myVTK
readImage
@@ -347,6 +357,7 @@ class ExprHessDefIm2(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
@@ -355,8 +366,7 @@ class ExprHessDefIm2(dolfin.Expression):
def
eval
self
Expr
X
self
U
eval
self
UX
X
self
x
X
self
UX
self
interpolator
Interpolate
self
x
self
H_vec
cvec4_to_mat22
self
H_vec
Expr
self
interpolator
Interpolate
self
x
Expr
Expr
self
s
class
ExprHessDefIm3
dolfin
Expression
@@ -366,7 +376,6 @@ class ExprHessDefIm3(dolfin.Expression):
self
U
U
self
UX
numpy
empty
3
self
x
numpy
empty
3
self
H_vec
numpy
empty
9
def
init_image
self
filename
self
myVTK
readImage
@@ -379,6 +388,7 @@ class ExprHessDefIm3(dolfin.Expression):
verbose
self
interpolator
myVTK
self
out_value
1.
verbose
def
value_shape
self
@@ -387,8 +397,7 @@ class ExprHessDefIm3(dolfin.Expression):
def
eval
self
Expr
X
self
U
eval
self
UX
X
self
x
X
self
UX
self
interpolator
Interpolate
self
x
self
H_vec
cvec9_to_mat33
self
H_vec
Expr
self
interpolator
Interpolate
self
x
Expr
Expr
self
s
cppcode_ExprIm
This diff is collapsed.
Loading
Save comment
