GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
c54871c4
c54871c4
8 years ago
Martin Genet
Downloads
Patches
better control over regularization quadrature
6ceea095
fedic.py
+36
-8
36 additions, 8 deletions
fedic.py
36 additions
8 deletions
fedic.py
36
8
c54871c4
@@ -229,7 +229,7 @@ def fedic(
for
filename
in
glob
glob
working_folder
working_basename
-frame=[0-9]*.*
os
remove
filename
mypy
print_str
tab
Defining
mechanical
energy…
mypy
print_str
tab
Defining
regularization
energy…
E
dolfin
Constant
1.0
nu
dolfin
Constant
regul_poisson
kappa
E
3
2
nu
# = E/3 if nu = 0
@@ -270,6 +270,13 @@ def fedic(
mesh_V
dolfin
assemble
J
dX
mypy
print_sci
tab
mesh_V
mesh_V
regularization_quadrature
2
mesh_degree
#regularization_quadrature = 2*mesh_degree
#regularization_quadrature = mesh_degree+1
#regularization_quadrature = 1
#regularization_quadrature = None
file_volume_basename
working_folder
working_basename
-volume
file_volume
open
.dat
w
file_volume
write
#k_frame mesh_V
\n
@@ -386,7 +393,10 @@ def fedic(
mypy
print_str
tab
Matrix assembly… (image term)
A
dolfin
assemble
1.
regul_level
DDpsi_c_ref
dX
tensor
A
form_compiler_parameters
quadrature_degree
images_quadrature
mypy
print_str
tab
Matrix assembly… (regularization term)
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
quadrature_degree
mesh_degree
add_values
True
if
is
not
None
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
quadrature_degree
add_values
True
else
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
add_values
True
B
None
mypy
print_str
tab
Looping over frames…
@@ -439,7 +449,10 @@ def fedic(
mypy
print_str
tab
A
dolfin
assemble
1.
regul_level
DDpsi_c_old
dX
tensor
A
quadrature_degree
images_quadrature
mypy
print_str
tab
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
quadrature_degree
mesh_degree
add_values
True
if
is
not
None
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
quadrature_degree
add_values
True
else
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
add_values
True
#mypy.print_var(tab,"A",A.array())
#A_norm = A.norm("l2")
#mypy.print_var(tab,"A_norm",A_norm)
@@ -473,7 +486,10 @@ def fedic(
mypy
print_str
tab
A
dolfin
assemble
1.
regul_level
DDpsi_c
dX
tensor
A
quadrature_degree
images_quadrature
mypy
print_str
tab
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
quadrature_degree
mesh_degree
add_values
True
if
is
not
None
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
quadrature_degree
add_values
True
else
A
dolfin
assemble
regul_level
DDpsi_m
dX
tensor
A
add_values
True
#mypy.print_sci(tab,"A_norm",A_norm)
@@ -489,12 +505,18 @@ def fedic(
mypy
print_str
tab
Residual assembly… (image term)
B
dolfin
assemble
1.
regul_level
Dpsi_c_old
dX
tensor
B
quadrature_degree
images_quadrature
mypy
print_str
tab
Residual assembly… (regularization term)
B
dolfin
assemble
regul_level
Dpsi_m
dX
tensor
B
quadrature_degree
mesh_degree
add_values
True
if
is
not
None
B
dolfin
assemble
regul_level
Dpsi_m
dX
tensor
B
quadrature_degree
add_values
True
else
B
dolfin
assemble
regul_level
Dpsi_m
dX
tensor
B
add_values
True
else
mypy
print_str
tab
B
dolfin
assemble
1.
regul_level
Dpsi_c
dX
tensor
B
quadrature_degree
images_quadrature
mypy
print_str
tab
B
dolfin
assemble
regul_level
Dpsi_m
dX
tensor
B
quadrature_degree
mesh_degree
add_values
True
if
is
not
None
B
dolfin
assemble
regul_level
Dpsi_m
dX
tensor
B
quadrature_degree
add_values
True
else
B
dolfin
assemble
regul_level
Dpsi_m
dX
tensor
B
add_values
True
#mypy.print_var(tab,"B",B.array())
# residual error
@@ -553,7 +575,10 @@ def fedic(
relax_cur
relax_c
relax_fc
dolfin
assemble
1.
regul_level
psi_c
dX
quadrature_degree
images_quadrature
#mypy.print_sci(tab,"relax_fc",relax_fc)
relax_fc
dolfin
assemble
regul_level
psi_m
dX
quadrature_degree
mesh_degree
if
is
not
None
relax_fc
dolfin
assemble
regul_level
psi_m
dX
quadrature_degree
else
relax_fc
dolfin
assemble
regul_level
psi_m
dX
if
numpy
isnan
relax_fc
relax_fc
float
+inf
@@ -570,7 +595,10 @@ def fedic(
relax_cur
relax_d
relax_fd
dolfin
assemble
1.
regul_level
psi_c
dX
quadrature_degree
images_quadrature
#mypy.print_sci(tab,"relax_fd",relax_fd)
relax_fd
dolfin
assemble
regul_level
psi_m
dX
quadrature_degree
mesh_degree
if
is
not
None
relax_fd
dolfin
assemble
regul_level
psi_m
dX
quadrature_degree
else
relax_fd
dolfin
assemble
regul_level
psi_m
dX
if
numpy
isnan
relax_fd
relax_fd
float
+inf
This diff is collapsed.
Loading
Save comment
