GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
569a718e
569a718e
5 years ago
Martin Genet
Downloads
Patches
Better approach for conditional readers & writers
6a0acc93
downsample_images.py
+21
-23
21 additions, 23 deletions
21 additions
23 deletions
21
23
569a718e
@@ -69,30 +69,27 @@ def downsample_images(
# mypy.my_print(verbose, "images_downsampled_npoints = "+str(images_downsampled_npoints))
if
images_ext
vtk
reader
vtk
vtkImageReader
writer
vtk
vtkImageWriter
if
write_temp_images
writer_fft
vtk
vtkImageWriter
if
keep_resolution
writer_mul
vtk
vtkImageWriter
else
writer_sel
vtk
vtkImageWriter
reader_constr
vtk
vtkImageReader
writer_constr
vtk
vtkImageWriter
elif
images_ext
vti
reader
vtk
vtkXMLImageDataReader
writer
vtk
vtkXMLImageDataWriter
if
write_temp_images
writer_fft
vtk
if
keep_resolution
writer_mul
vtk
else
writer_sel
vtk
reader_constr
vtk
writer_constr
vtk
else
assert
ext
must be
.vtk
.vti
. Aborting.
reader
reader_constr
writer
writer_constr
if
write_temp_images
writer_fft
writer_constr
if
keep_resolution
writer_mul
writer_constr
else
writer_sel
writer_constr
fft
vtk
vtkImageFFT
fft
SetDimensionality
images_ndim
fft
SetInputConnection
reader
GetOutputPort
if
write_temp_images
writer_fft
SetInputConnection
fft
GetOutputPort
if
write_temp_images
writer_fft
SetInputConnection
fft
GetOutputPort
if
keep_resolution
image_filename
images_folder
images_basename
_
str
zfill
images_zfill
images_ext
@@ -139,16 +136,18 @@ def downsample_images(
mask_scalars
SetTuple
k_point
else
mask_scalars
SetTuple
k_point
if
write_temp_images
myvtk
writeImage
mask_image
filename
images_folder
images_basename
_mask
images_ext
verbose
if
write_temp_images
myvtk
writeImage
mask_image
filename
images_folder
images_basename
_mask
images_ext
verbose
mult
vtk
vtkImageMathematics
mult
SetOperationToMultiply
mult
SetInputConnection
fft
GetOutputPort
mult
SetInputData
mask_image
if
write_temp_images
writer_mul
SetInputConnection
mult
GetOutputPort
if
write_temp_images
writer_mul
SetInputConnection
mult
GetOutputPort
else
image_downsampled
vtk
vtkImageData
@@ -250,7 +249,6 @@ def downsample_images(
# print "image_downsampled_scalars = "+str(image_downsampled_scalars)
if
write_temp_images
# writer_sel.SetInputData(image_downsampled)
writer_sel
SetFileName
images_folder
images_basename
_sel
_
str
k_frame
zfill
images_zfill
images_ext
writer_sel
This diff is collapsed.
Loading
Save comment
