Commit 3d81425c authored by Martin Genet's avatar Martin Genet
compute_displacements -> compute_displacements_from_ref
parent d83afeed
......@@ -28,7 +28,7 @@ from fedic2 import *
from generated_grad_expressions_cpp import *
from plot_displacement_error import *
from Problem import *
from compute_displacements import *
from compute_displacements_from_ref import *
from generate_images import *
from ImageSeries import *
from compute_displacement_error import *
......@@ -20,7 +20,7 @@ import dolfin_dic as ddic
def compute_displacements(
def compute_displacements_from_ref(
working_folder,
working_basename,
ref_frame,
