Commit 1a3648e0 authored by Martin Genet's avatar Martin Genet
Adding cpp expressions...finally!
parent ef3d0831
......@@ -3,8 +3,10 @@
from fedic import *
from plot_strains_vs_radius import *
from plot_strains import *
from image_expressions_cpp import *
from compute_strains import *
from print_tools import *
from plot_displacement_error import *
from image_expressions_py import *
from compute_displacement_error import *
from compute_quadrature_degree import *
from image_expressions import *
......@@ -18,6 +18,7 @@ import myVTKPythonLibrary as myVTK
def compute_strains(
sol_folder,
sol_basename,
sol_zfill=6,
sol_ext="vtu",
disp_array_name="displacement",
ref_folder=None,
......@@ -48,12 +49,12 @@ def compute_strains(
ref_mesh = None
n_sector_ids = 0
n_frames = len(glob.glob(sol_folder+"/"+sol_basename+"_*."+sol_ext))
if (verbose): print "n_frames = " + str(n_frames)
n_zfill = len(glob.glob(sol_folder+"/"+sol_basename+"_*."+sol_ext)[0].rsplit("_")[-1].split(".")[0])
if (verbose): print "n_zfill = " + str(n_zfill)
n_frames = len(glob.glob(sol_folder+"/"+sol_basename+"_"+"[0-9]"*sol_zfill+"."+sol_ext))
if (write_strains):
strain_file = open(sol_folder+"/"+sol_basename+"-strains.dat", "w")
strain_file.write("#t Err_avg Err_std Ecc_avg Ecc_std Ell_avg Ell_std Erc_avg Erc_std Erl_avg Erl_std Ecl_avg Ecl_std\n")
This diff is collapsed.
......@@ -16,412 +16,124 @@ from myVTKPythonLibrary.mat_vec_tools import *
def getScalingFactor(scalar_type_as_string):
if (scalar_type_as_string == 'unsigned char' ): return float(2**8 -1)
elif (scalar_type_as_string == 'unsigned short'): return float(2**16-1)
elif (scalar_type_as_string == 'unsigned int' ): return float(2**32-1)
elif (scalar_type_as_string == 'unsigned long' ): return float(2**64-1)
elif (scalar_type_as_string == 'float' ): return 1.
elif (scalar_type_as_string == 'double' ): return 1.
else: assert (0), "Wrong image scalar type. Aborting."
def get_ExprIm_cpp(
im_dim,
im_type="im",
im_is_def=False,
verbose=False):
class ExprIm2(dolfin.Expression):
def __init__(self, filename=None, Z=0., **kwargs):
if filename is not None:
self.init_image(filename=filename)
self.X = numpy.array([float()]*2+[Z])
assert (im_dim in (2,3))
assert (im_type in ("im","grad"))
def init_image(self, filename):
self.image = myVTK.readImage(
filename=filename,
verbose=0)
self.s = getScalingFactor(
scalar_type_as_string=self.image.GetScalarTypeAsString())
self.interpolator = myVTK.createImageInterpolator(
image=self.image,
out_value=0.,
verbose=0)
ExprIm_cpp = '''\
#include <string.h>
def eval(self, Expr, X):
#print "Expr"
self.X[0:2] = X[0:2]
#print " X = " + str(X)
self.interpolator.Interpolate(self.X, Expr)
#print " Expr = " + str(Expr)
Expr /= self.s
class ExprIm3(dolfin.Expression):
def __init__(self, filename, **kwargs):
filename=filename,
verbose=0)
image=self.image,
out_value=0.,
verbose=0)
#print "Expr"
self.interpolator.Interpolate(X, Expr)
Expr /= self.s
class ExprGradIm2(dolfin.Expression):
filename=filename,
verbose=0)
self.image = myVTK.computeImageGradient(
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
def value_shape(self):
return (2,)
Expr /= self.s
class ExprGradIm3(dolfin.Expression):
def __init__(self, filename=None, **kwargs):
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (3,)
Expr /= self.s
class ExprHessIm2(dolfin.Expression):
filename=filename,
verbose=0)
self.image = myVTK.computeImageHessian(
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (2,2)
Expr /= self.s
class ExprHessIm3(dolfin.Expression):
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (3,3)
Expr /= self.s
class ExprDefIm2(dolfin.Expression):
def __init__(self, U, filename=None, Z=0., **kwargs):
self.U = U
self.UX = numpy.empty(2)
self.x = numpy.array([float()]*2+[Z])
filename=filename,
verbose=0)
image=self.image,
out_value=0.,
verbose=0)
#print "Expr"
#print " U = " + str(U.vector().array())
#print " UX = " + str(self.UX)
self.U.eval(self.UX, X)
self.x[0:2] = X[0:2] + self.UX[0:2]
#print " x = " + str(self.x)
self.interpolator.Interpolate(self.x, Expr)
Expr /= self.s
class ExprDefIm3(dolfin.Expression):
def __init__(self, U, filename=None, **kwargs):
self.U = U
self.UX = numpy.empty(3)
self.x = numpy.empty(3)
filename=filename,
verbose=0)
image=self.image,
out_value=0.,
verbose=0)
#print "Expr"
self.x[:] = X + self.UX
Expr /= self.s
class ExprGradDefIm2(dolfin.Expression):
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (2,)
#print "Expr"
Expr /= self.s
class ExprGradDefIm3(dolfin.Expression):
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (3,)
#print "Expr"
Expr /= self.s
class ExprHessDefIm2(dolfin.Expression):
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (2,2)
Expr /= self.s
class ExprHessDefIm3(dolfin.Expression):
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
out_value=self.s,
verbose=0)
return (3,3)
Expr /= self.s
cppcode_ExprIm='''
#include <vtkSmartPointer.h>
#include <vtkXMLImageDataReader.h>
#include <vtkImageData.h>
#include <vtkImageData.h>'''+('''
#include <vtkImageGradient.h>''')*(im_type=="grad")+'''
#include <vtkImageInterpolator.h>
namespace dolfin
class MyFun : public Expression
class MyExpr : public Expression
public:
MyFun(): Expression()
vtkSmartPointer<vtkImageInterpolator> interpolator;'''+('''
const Function* U;
mutable Array<double> UX;
mutable Array<double> x;''')*(im_is_def)+('''
mutable Array<double> X;''')*(not im_is_def)*(im_dim==2)+'''
public:
MyExpr():
Expression('''+('''2''')*(im_type=="grad")+''')'''+(''',
UX('''+str(im_dim)+'''),
x(3)''')*(im_is_def)+(''',
X(3)''')*(not im_is_def)*(im_dim==2)+'''
void init('''+('''
const Function &UU,''')*(im_is_def)+('''
const double &Z=0.''')*(im_dim==2)+''')
U = &UU;''')*(im_is_def)+('''
x[2] = Z;''')*(im_is_def)*(im_dim==2)+('''
X[2] = Z;''')*(not im_is_def)*(im_dim==2)+'''
void init_image(
const char* filename,
const char* interpol_mode="'''+('''linear''')*(im_type=="im")+('''nearest''')*(im_type=="grad")+'''",
const double &interpol_out_value='''+('''0.''')*(im_type=="im")+('''1.''')*(im_type=="grad")+''')
vtkSmartPointer<vtkXMLImageDataReader> reader = vtkSmartPointer<vtkXMLImageDataReader>::New();
reader->SetFileName(filename);
reader->Update();'''+('''
vtkSmartPointer<vtkImageGradient> gradient = vtkSmartPointer<vtkImageGradient>::New();
#if VTK_MAJOR_VERSION >= 6
gradient->SetInputData(reader->GetOutput());
#else
gradient->SetInput(reader->GetOutput());
#endif
gradient->SetDimensionality('''+str(im_dim)+''');
gradient->Update();''')*(im_type=="grad")+'''
interpolator = vtkSmartPointer<vtkImageInterpolator>::New();
if (strcmp(interpol_mode, "nearest") == 0)
reader->SetFileName("<<filename>>");
reader->Update();
interpolator->Initialize(reader->GetOutput());
interpolator->Update();
void eval(Array<double>& values, const Array<double>& x) const
interpolator->SetInterpolationModeToNearest();
else if (strcmp(interpol_mode, "linear") == 0)
interpolator->Interpolate(x.data(), values.data());
interpolator->SetInterpolationModeToLinear();
private:
vtkSmartPointer<vtkImageInterpolator> interpolator = vtkSmartPointer<vtkImageInterpolator>::New();
else if (strcmp(interpol_mode, "cubic") == 0)
interpolator->SetInterpolationModeToCubic();
else
std::cout << "Interpolator interpol_mode (" << interpol_mode << ") must be \\"nearest\\", \\"linear\\" or \\"cubic\\". Aborting." << std::endl;
assert(0);
interpolator->SetOutValue(interpol_out_value);
interpolator->Initialize('''+('''reader->GetOutput()''')*(im_type=="im")+('''gradient->GetOutput()''')*(im_type=="grad")+''');
void eval(Array<double>& values, const Array<double>& position) const
std::cout << "position = " << position.str(1) << std::endl;''')*(verbose)+('''
U->eval(UX, position);'''+('''
std::cout << "UX = " << UX.str(1) << std::endl;''')*(verbose)+'''
x[0] = position[0] + UX[0];
x[1] = position[1] + UX[1];'''+('''
std::cout << "x = " << x.str(1) << std::endl;''')*(verbose)+'''
interpolator->Interpolate(x.data(), values.data());''')*(im_is_def)*(im_dim==2)+('''
x = position + UX;'''+('''
interpolator->Interpolate(x.data(), values.data());''')*(im_is_def)*(im_dim==3)+('''
X[0] = position[0];
X[1] = position[1];'''+('''
std::cout << "X = " << X.str(1) << std::endl;''')*(verbose)+'''
interpolator->Interpolate(X.data(), values.data());''')*(not im_is_def)*(im_dim==2)+('''
interpolator->Interpolate(position.data(), values.data());''')*(not im_is_def)*(im_dim==3)+('''
std::cout << "values = " << values.str(1) << std::endl;''')*(verbose)+'''
return ExprIm_cpp
#coding=utf8
### Created by Martin Genet, 2016 ###
### École Polytechnique, Palaiseau, France ###
import dolfin
import numpy
filename=filename,
verbose=0)
image=self.image,
mode="linear",
out_value=0.,
verbose=0)
#print " X = " + str(self.X)
Expr /= self.s
filename=filename,
verbose=0)
image=self.image,
mode="linear",
out_value=0.,
verbose=0)
Expr /= self.s
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (2,)
Expr /= self.s
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (3,)
Expr /= self.s
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (2,2)
Expr /= self.s
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (3,3)
Expr /= self.s
def __init__(self, U, filename=None, scaling=[1.,0.], Z=0., **kwargs):
self.U = U
self.scaling = scaling
filename=filename,
verbose=0)
image=self.image,
mode="linear",
out_value=0.,
verbose=0)
Expr /= self.s
Expr *= self.scaling[0]
Expr += self.scaling[1]
def __init__(self, U, filename=None, scaling=[1.,0.], **kwargs):
self.U = U
filename=filename,
verbose=0)
image=self.image,
mode="linear",
out_value=0.,
verbose=0)
Expr /= self.s
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (2,)
Expr /= self.s
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (3,)
Expr /= self.s
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (2,2)
Expr /= self.s
self.U = U
filename=filename,
verbose=0)
image=self.image,
verbose=0)
image=self.image,
mode="nearest",
out_value=self.s,
verbose=0)
return (3,3)
Expr /= self.s
