GitLab
Explore
Primary navigation
Search or go to…
dolfin_dic
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
BERBEROGLU Ezgi
dolfin_dic
07f30e18
07f30e18
5 years ago
Martin Genet
Downloads
Patches
Now all strain files can write time instead of time index
035ba9cf
compute_strains.py
+6
-10
6 additions, 10 deletions
compute_strains.py
6 additions
10 deletions
compute_strains.py
6
10
07f30e18
@@ -36,8 +36,8 @@ def compute_strains(
remove_boundary_layer
in_place
write_strains
temporal_offset
None
temporal_resolution
None
temporal_offset
temporal_resolution
plot_strains
plot_regional_strains
write_strains_vs_radius
@@ -233,11 +233,7 @@ def compute_strains(
if
sector_id
continue
strains_per_sector
sector_id
append
farray_strain
GetTuple
k_cell
if
temporal_offset
is
not
None
temporal_resolution
is
not
None
strain_file
write
str
temporal_offset
k_frame
temporal_resolution
else
strain_file
write
str
k_frame
strain_file
write
str
temporal_offset
k_frame
temporal_resolution
strains_all_avg
numpy
mean
strains_all
strains_all_std
numpy
std
strains_all
strain_file
write
join
str
strains_all_avg
k_comp
str
strains_all_std
k_comp
for
k_comp
in
xrange
6
@@ -251,7 +247,7 @@ def compute_strains(
if
farray_rr
mesh
GetCellData
GetArray
rr
for
k_cell
in
xrange
n_cells
strains_vs_radius_file
write
join
str
val
for
val
in
k_frame
farray_rr
GetTuple1
k_cell
list
farray_strain
GetTuple
k_cell
\n
write
join
str
val
for
val
in
temporal_offset
k_frame
temporal_resolution
farray_rr
GetTuple1
k_cell
list
farray_strain
GetTuple
k_cell
\n
write
\n
write
\n
@@ -271,7 +267,7 @@ def compute_strains(
#print binned_strains_avg
#print binned_strains_std
for
k_r
in
xrange
n_r
binned_strains_vs_radius_file
write
join
str
val
for
val
in
k_frame
k_r
0.5
n_r
val
for
k_comp
in
xrange
6
for
val
in
binned_strains_avg
k_r
k_comp
binned_strains_std
k_r
k_comp
\n
write
join
str
val
for
val
in
temporal_offset
k_frame
temporal_resolution
k_r
0.5
n_r
val
for
k_comp
in
xrange
6
for
val
in
binned_strains_avg
k_r
k_comp
binned_strains_std
k_r
k_comp
\n
write
\n
write
\n
@@ -320,7 +316,7 @@ def compute_strains(
farray_beta
SetTuple1
k_point
beta
if
r
15.
continue
# if (ll < 1./3): continue
twist_vs_height_file
write
join
str
val
for
val
in
k_frame
ll
beta
\n
write
join
str
val
for
val
in
temporal_offset
k_frame
temporal_resolution
ll
beta
\n
mesh_filename
working_folder
working_basename
-wStrains
not
in_place
_
str
k_frame
zfill
working_zfill
working_ext
myvtk
writeUGrid
ugrid
mesh
This diff is collapsed.
Loading
Save comment
