GitLab
Explore
Primary navigation
Search or go to…
S
Synthesis_Modules
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
dnarXiv
Synthesis_Modules
e656fcf3
e656fcf3
2 years ago
BOULLE Olivier
Downloads
Patches
init
adbeed91
Branches containing commit
get_clique.cpp
+195
195 additions, 0 deletions
get_clique.cpp
195 additions
get_clique.cpp
195
e656fcf3
// g++ -std=c++11 get_clique.cpp -o get_clique
#include
<iostream>
#include
<fstream>
#include
<stack>
#include
<string>
#include
<algorithm>
#include
<vector>
#include
<map>
using
namespace
std
class
int
g_size
// No. of vertices
vector
int
adj
// An array of adjacency lists
vector
int
test_clique
vector
pair
int
int
sorted_node_edges
int
node_index
vector
int
clique_list
public:
int
g_size
void
add_edge
int
node_a
int
node_b
// get a big clique with an heuristique
vector
int
get_clique
int
g_size
this
g_size
g_size
adj
new
vector
int
g_size
void
add_edge
int
node_a
int
node_b
adj
node_a
push_back
node_b
// Add w to v’s list.
//sort the vector by edge number
vector
int
get_clique
// heuristique here (maximum clique is NP-complete)
// sort nodes by number of edges
// start a clique from the node with most edges
// loop over next nodes with the most edges
// add to the clique if it is linked to all members
vector
pair
int
int
node_edges
//number of edges for each node
// fill the vector
for
int
node
node
g_size
node
node_edges
push_back
make_pair
node
adj
node
size
// sort by number of edges
sort
node_edges
begin
node_edges
const
pair
int
int
a
const
pair
int
int
b
// lambda function to sort vector pair by 2nd element descending
return
a
second
b
second
vector
int
clique_list
// fill the clique
clique_list
test_clique
node_edges
clique_list
return
clique_list
vector
int
test_clique
vector
pair
int
int
sorted_node_edges
int
node_index
vector
int
clique_list
// test if a node can be added to the clique list
// continue the test to the next node with the updated clique list
if
node_index
sorted_node_edges
size
return
clique_list
int
tested_node
sorted_node_edges
node_index
first
for
int
i
i
clique_list
size
i
vector
int
neigboors_array
adj
clique_list
i
// list of neigboors of this node
if
find
begin
neigboors_array
neigboors_array
tested_node
neigboors_array
// tested node is not linked to a node from the clique
return
test_clique
sorted_node_edges
node_index
clique_list
// cannot be added to the clique -> test the next node
// the tested node is linked to every node in the clique
clique_list
push_back
tested_node
return
test_clique
sorted_node_edges
node_index
clique_list
// test the next node
string
rev_comp
string
sequence
reverse
sequence
begin
sequence
for
int
i
i
sequence
length
i
switch
sequence
i
case
'A'
sequence
i
'T'
break
case
'C'
sequence
i
'G'
break
case
'G'
sequence
i
'C'
break
case
'T'
sequence
i
'A'
break
return
sequence
bool
test_hybridation
string
primer_a
string
primer_b
int
max_hybridisation_value
4
int
primer_size
20
for
int
i
i
primer_size
i
string
kmer_a
primer_a
substr
i
if
primer_b
find
kmer_a
string
npos
//cout << primer_b << " " << kmer_a << endl;
return
false
string
rev_primer_a
rev_comp
primer_a
for
int
i
i
primer_size
i
string
kmer_rev_a
rev_primer_a
substr
i
if
primer_b
find
kmer_rev_a
string
npos
//cout << primer_b << " " << kmer_rev_a << endl;
return
false
return
true
compute_hybridation
vector
string
primers_list
int
primers_n
primers_list
size
g
primers_n
for
int
i
i
primers_n
i
string
primer_a
primers_list
i
for
int
j
i
j
primers_n
j
string
primer_b
primers_list
j
//cout << "a";
if
test_hybridation
primer_a
primer_b
g
add_edge
i
j
g
add_edge
j
i
return
g
int
main
// read list of primers
vector
string
primers_list
ifstream
input_file
input_file
open
"primer_generator/temp/checked_primers.txt"
string
myline
if
input_file
is_open
while
input_file
getline
input_file
myline
if
myline
size
// last line is empty
primers_list
push_back
myline
else
cout
"Couldn't open file
\n
// use indexes of primers in the list
g
compute_hybridation
primers_list
cout
"get clique : hybridation graph created"
endl
vector
int
clique_list
g
get_clique
cout
"get clique : found clique of "
clique_list
size
" primers"
endl
ofstream
output_file
output_file
open
"test_primers.txt"
for
const
int
node
clique_list
output_file
primers_list
node
\n
output_file
close
return
This diff is collapsed.
Loading
Save comment
