GitLab
Explore
Primary navigation
Search or go to…
S
Source_Encoding
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
dnarXiv
Source_Encoding
8201876a
8201876a
1 year ago
BOULLE Olivier
Downloads
Patches
comments improved, refactoring
5a217f07
binary_dna_conversion.py
+23
-20
23 additions, 20 deletions
23 additions
20 deletions
23
20
8201876a
@@ -272,46 +272,47 @@ def binary_to_dna_baa(binary_string: str, GC_window=20) -> str:
for
i
in
range
n_quintuplets
bits5
binary_string
i
5
i
5
nucleotide_2
bit_pair_to_dna
bits5
3
nucleotide_3
bit_pair_to_dna
bits5
3
5
nucleotide_2
bit_pair_to_dna
bits5
3
# first alpha base of the encoded triplet
nucleotide_3
bit_pair_to_dna
bits5
3
5
# 2nd alpha base
# make nucleotide 1
if
len
sequence
3
# check 3 previous encoded bases
and 2 following alpha bases to see if there is a potential homopolymer of 4+
if
sequence
3
sequence
2
sequence
sequence
2
sequence
nucleotide_2
sequence
nucleotide_2
nucleotide_3
# break homopolymer
# break
the
homopolymer
nucleotide_1
bit_to_dna_balance_GC
bits5
sequence
else
# if no homopolymer to break, adjust GC% in the window of preceding bases + 2
new
alpha bases
following
alpha bases
check_window
sequence
min
len
sequence
GC_window
nucleotide_2
nucleotide_3
if
check_window
count
A
check_window
count
T
check_window
count
G
check_window
count
C
nucleotide_1
bit_to_dna_GC
bits5
nucleotide_1
bit_to_dna_GC
bits5
# more A/T -> add a G/C
elif
check_window
count
A
check_window
count
T
check_window
count
G
check_window
count
C
nucleotide_1
bit_to_dna_AT
bits5
else
# strictly equal, just balance with
preced
ing base
nucleotide_1
bit_to_dna_AT
bits5
# less A/T -> add a A/T
else
case of
strictly equal
%GC
, just balance with
follow
ing base
nucleotide_1
bits5
nucleotide_2
else
else
# empty string, just balance the GC with the following base
nucleotide_1
bits5
nucleotide_2
sequence
nucleotide_1
nucleotide_2
nucleotide_3
sequence
nucleotide_1
nucleotide_2
nucleotide_3
# add the encoded b a a bases to the sequence
bit_rest
binary_string
n_quintuplets
5
n_quintuplets
5
rest
# rest is 0-1-3 bits
# all complete quintuplets have been encoded, time for the rest
bit_rest
binary_string
n_quintuplets
5
n_quintuplets
5
rest
# rest is 0-1-3 bits long
if
len
bit_rest
# last conversions depends on the length of the rest, 1 bits = 1 base; 3 bits = 2 bases
if
len
bit_rest
nucleotide_2
nucleotide_2
# no nucleotide 2 to add
homopolymer_check_bool
sequence
3
sequence
2
sequence
else
# rest = 3
nucleotide_2
bit_pair_to_dna
bit_rest
3
# nucleotide_2 from a pair of bits
sequence
3
sequence
2
sequence
sequence
2
sequence
nucleotide_2
# true => careful for a potential homopolymer
if
# break homopolymer
need to
break homopolymer
with the nucleotide 1
nucleotide_1
bit_rest
sequence
else
# adjust GC%
check_window
sequence
min
len
sequence
GC_window
nucleotide_2
@@ -319,9 +320,9 @@ def binary_to_dna_baa(binary_string: str, GC_window=20) -> str:
nucleotide_1
bit_to_dna_GC
bit_rest
else
nucleotide_1
bit_to_dna_AT
bit_rest
sequence
nucleotide_1
nucleotide_2
# remove the banned words
sequence_wo_banwords
remove_ban_words_baa_encoding
sequence
@@ -336,10 +337,10 @@ def dna_to_binary_baa(sequence: str) -> str:
binary_string
n_triplet
rest
divmod
len
sequence
3
for
i
in
range
n_triplet
nucleotide
s3
sequence
i
3
i
3
bit_1
dna_to_bit_ATGC
nucleotide
s3
bits_23
dna_to_bit_pair
nucleotide
s3
bits_45
dna_to_bit_pair
nucleotide
s3
2
triplet_
nucleotide
sequence
i
3
i
3
bit_1
dna_to_bit_ATGC
triplet_
nucleotide
bits_23
dna_to_bit_pair
triplet_
nucleotide
bits_45
dna_to_bit_pair
triplet_
nucleotide
2
binary_string
bit_1
bits_23
bits_45
@@ -362,6 +363,8 @@ def remove_ban_words_baa_encoding(sequence: str, baa_method_offset=0) -> str:
the changed base must be a beta base, and be A<=>G; T<=>C, so the decoding of the updated sequence will still return the same result
if the original sequence has already been fragmented, the 3 bases windows of the baa method can be offset, baa_method_offset is used to correct this
#TODO also remove inverse repeat regions of 10+ bases
# change a beta base but keep the binary meaning for the decoding
This diff is collapsed.
Loading
Save comment
