Commit e1c5bbd9 authored by Murali Annamneni's avatar Murali Annamneni
Include default_docker_volume_type for magnum.conf
To create a magnum cluster, its required to specify
'default_docker_volume_type' with some default value (default cinder
 volume type). And, it also enables users to select
diffferent cinder volume types for their volumes.
Change-Id: I50b4c436875e4daac48a14fc1e119136eb5fd844
parent a018e60c
......@@ -42,6 +42,9 @@ magnum_database_address: "{{ database_address }}:{{ database_port }}"
# Magnum
enable_cluster_user_trust: False
# The default cinder volume type to be used for container storage volume in clusters
# that specify the docker-volume-size option. For example gp1, io1 etc
default_docker_volume_type: ""
......@@ -18,6 +18,11 @@ workers = {{ openstack_service_workers }}
connection = mysql+pymysql://{{ magnum_database_user }}:{{ magnum_database_password }}@{{ magnum_database_address }}/{{ magnum_database_name }}
max_retries = -1
{% if enable_cinder | bool %}
[cinder]
default_docker_volume_type = {{ default_docker_volume_type }}
{% endif %}
[heat_client]
region_name = {{ openstack_region_name }}
endpoint_type = internalURL
upgrade:
Added default_docker_volume_type for magnum which is required to
specify the default cinder volume type to be used for container
storage volume in clusters that specify the docker-volume-size
option. For example gp1, io1 etc.
