Commit 69bc7b4e authored by wu.chunyang's avatar wu.chunyang Committed by Surya Prakash (spsurya)
add trove policy file customization
now,the trove does not support policy customization.
this ps to add it.
Change-Id: I32d62d0293ddf63572cf754a7108ed74f94b216a
parent 0cc8d65a
......@@ -5,6 +5,7 @@
service: "{{ trove_services[service_name] }}"
config_json: "{{ trove_config_jsons.results|selectattr('item.key', 'equalto', service_name)|first }}"
trove_conf: "{{ trove_confs.results|selectattr('item.key', 'equalto', service_name)|first }}"
policy_overwriting: "{{ trove_policy_overwriting.results|selectattr('item.key', 'equalto', service_name)|first }}"
trove_api_container: "{{ check_trove_containers.results|selectattr('item.key', 'equalto', service_name)|first }}"
become: true
kolla_docker:
......@@ -20,6 +21,7 @@
- service.enabled | bool
- config_json.changed | bool
or trove_conf.changed | bool
or policy_overwriting.changed | bool
or trove_api_container.changed | bool
- name: Restart trove-conductor container
......@@ -28,6 +30,7 @@
trove_conductor_container: "{{ check_trove_containers.results|selectattr('item.key', 'equalto', service_name)|first }}"
become: true
kolla_docker:
......@@ -43,6 +46,7 @@
or trove_conductor_container.changed | bool
- name: Restart trove-taskmanager container
......@@ -51,6 +55,7 @@
trove_taskmanager_container: "{{ check_trove_containers.results|selectattr('item.key', 'equalto', service_name)|first }}"
become: true
kolla_docker:
......@@ -66,4 +71,5 @@
or trove_taskmanager_container.changed | bool
......@@ -12,6 +12,23 @@
- item.value.enabled | bool
with_dict: "{{ trove_services }}"
- name: Check if policies shall be overwritten
local_action: stat path="{{ item }}"
run_once: True
register: trove_policy
with_first_found:
- files: "{{ supported_policy_format_list }}"
paths:
- "{{ node_custom_config }}/trove/"
skip: true
- name: Set trove policy file
set_fact:
trove_policy_file: "{{ trove_policy.results.0.stat.path | basename }}"
trove_policy_file_path: "{{ trove_policy.results.0.stat.path }}"
when:
- trove_policy.results
- name: Copying over config.json files for services
template:
src: "{{ item.key }}.json.j2"
......@@ -71,6 +88,20 @@
notify:
- "Restart {{ item.key }} container"
- name: Copying over existing policy file
template:
src: "{{ trove_policy_file_path }}"
dest: "{{ node_config_directory }}/{{ item.key }}/{{ trove_policy_file }}"
register: trove_policy_overwriting
when:
- trove_policy_file is defined
- inventory_hostname in groups[item.value.group]
notify:
- Restart trove-api container
- Restart trove-conductor container
- Restart trove-taskmanager container
- name: Check trove containers
become: true
kolla_docker:
......@@ -6,7 +6,13 @@
"dest": "/etc/trove/trove.conf",
"owner": "trove",
"perm": "0600"
}{% if trove_policy_file is defined %},
"source": "{{ container_config_directory }}/{{ trove_policy_file }}",
"dest": "/etc/trove/{{ trove_policy_file }}",
"owner": "trove",
"perm": "0600"
}{% endif %}
"permissions": [
"dest": "/etc/trove/trove-conductor.conf",
"owner": "trove",
"perm": "0600"
"owner": "trove",
"perm": "0600"
}{% endif %}
"permissions": [
"dest": "/etc/trove/trove-taskmanager.conf",
"owner": "trove",
"perm": "0600"
"owner": "trove",
"perm": "0600"
}{% endif %}
"permissions": [
......@@ -56,3 +56,8 @@ trace_sqlalchemy = true
hmac_keys = {{ osprofiler_secret }}
connection_string = {{ osprofiler_backend_connection_string }}
{% endif %}
[oslo_policy]
policy_file = {{ trove_policy_file }}
{% endif %}
