Commit 5441963c authored by Doug Szumski's avatar Doug Szumski
Support deploying Monasca Log Persister
This is a Logstash component which reads processed logs from Kafka
and writes them to Elasticsearch (or some other backend supported by
Logstash).
Ingesting the logs from this service with Fluentd will be covered under
a different commit.
Change-Id: I2d722991ab2072c54c4715507b19a4c9279f921b
Partially-Implements: blueprint monasca-roles
parent 08cbba52
...@@ -449,6 +449,9 @@ monasca ...@@ -449,6 +449,9 @@ monasca
[monasca-log-transformer:children] [monasca-log-transformer:children]
monasca monasca
[monasca-log-persister:children]
monasca
# Ironic # Ironic
[ironic-api:children] [ironic-api:children]
ironic ironic
...@@ -458,6 +458,9 @@ monasca ...@@ -458,6 +458,9 @@ monasca
monasca monasca
monasca
# Ironic # Ironic
ironic ironic
...@@ -27,6 +27,15 @@ monasca_services: ...@@ -27,6 +27,15 @@ monasca_services:
- "{{ node_config_directory }}/monasca-log-transformer/:{{ container_config_directory }}/:ro" - "{{ node_config_directory }}/monasca-log-transformer/:{{ container_config_directory }}/:ro"
- "/etc/localtime:/etc/localtime:ro" - "/etc/localtime:/etc/localtime:ro"
- "kolla_logs:/var/log/kolla" - "kolla_logs:/var/log/kolla"
container_name: monasca_log_persister
group: monasca-log-persister
enabled: true
image: "{{ monasca_logstash_image_full }}"
volumes:
- "{{ node_config_directory }}/monasca-log-persister/:{{ container_config_directory }}/:ro"
# Databases # Databases
...@@ -45,6 +54,7 @@ monasca_influxdb_http_port: "{{ influxdb_http_port }}" ...@@ -45,6 +54,7 @@ monasca_influxdb_http_port: "{{ influxdb_http_port }}"
monasca_kafka_servers: "{% for host in groups['kafka'] %}{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ kafka_port }}{% if not loop.last %},{% endif %}{% endfor %}" monasca_kafka_servers: "{% for host in groups['kafka'] %}{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ kafka_port }}{% if not loop.last %},{% endif %}{% endfor %}"
monasca_zookeeper_servers: "{% for host in groups['zookeeper'] %}{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ zookeeper_client_port }}{% if not loop.last %},{% endif %}{% endfor %}" monasca_zookeeper_servers: "{% for host in groups['zookeeper'] %}{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ zookeeper_client_port }}{% if not loop.last %},{% endif %}{% endfor %}"
monasca_memcached_servers: "{% for host in groups['memcached'] %}{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ memcached_port }}{% if not loop.last %},{% endif %}{% endfor %}" monasca_memcached_servers: "{% for host in groups['memcached'] %}{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ memcached_port }}{% if not loop.last %},{% endif %}{% endfor %}"
monasca_elasticsearch_servers: "{% for host in groups['elasticsearch'] %}'{{ internal_protocol }}://{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ elasticsearch_port }}'{% if not loop.last %},{% endif %}{% endfor %}"
monasca_metrics_topic: "metrics" monasca_metrics_topic: "metrics"
monasca_raw_logs_topic: "logs" monasca_raw_logs_topic: "logs"
...@@ -62,3 +62,24 @@ ...@@ -62,3 +62,24 @@
- config_json.changed | bool - config_json.changed | bool
or monasca_log_transformer_confs.changed | bool or monasca_log_transformer_confs.changed | bool
or monasca_log_transformer_container.changed | bool or monasca_log_transformer_container.changed | bool
- name: Restart monasca-log-persister container
vars:
service_name: "monasca-log-persister"
service: "{{ monasca_services[service_name] }}"
config_json: "{{ monasca_config_jsons.results|selectattr('item.key', 'equalto', service_name)|first }}"
monasca_log_persister_container: "{{ check_monasca_containers.results|selectattr('item.key', 'equalto', service_name)|first }}"
kolla_docker:
action: "recreate_or_restart_container"
common_options: "{{ docker_common_options }}"
name: "{{ service.container_name }}"
image: "{{ service.image }}"
volumes: "{{ service.volumes }}"
when:
- action != "config"
- inventory_hostname in groups[service.group]
- service.enabled | bool
or monasca_log_persister_confs.changed | bool
or monasca_log_persister_elasticsearch_template.changed | bool
or monasca_log_persister_container.changed | bool
...@@ -118,6 +118,45 @@ ...@@ -118,6 +118,45 @@
notify: notify:
- Restart monasca-log-transformer container - Restart monasca-log-transformer container
- name: Copying over monasca-log-persister config
vars:
service: "{{ monasca_services['monasca-log-persister'] }}"
template:
src: "{{ item }}"
dest: "{{ node_config_directory }}/monasca-log-persister/log-persister.conf"
mode: "0660"
become: true
register: monasca_log_persister_confs
with_first_found:
- "{{ node_custom_config }}/monasca/{{ inventory_hostname }}/log-persister.conf"
- "{{ node_custom_config }}/monasca/log-persister.conf"
- "{{ role_path }}/templates/monasca-log-persister/log-persister.conf.j2"
when:
- inventory_hostname in groups[service['group']]
notify:
- Restart monasca-log-persister container
- name: Copying over monasca-log-persister elasticsearch template
vars:
template:
src: "{{ item }}"
dest: "{{ node_config_directory }}/monasca-log-persister/elasticsearch-template.json"
mode: "0660"
become: true
register: monasca_log_persister_elasticsearch_template
with_first_found:
- "{{ node_custom_config }}/monasca/{{ inventory_hostname }}/elasticsearch-template.json"
- "{{ node_custom_config }}/monasca/elasticsearch-template.json"
- "{{ role_path }}/templates/monasca-log-persister/elasticsearch-template.json"
when:
notify:
- name: Check monasca containers - name: Check monasca containers
become: true become: true
kolla_docker: kolla_docker:
...@@ -6,7 +6,8 @@ ...@@ -6,7 +6,8 @@
- include: config.yml - include: config.yml
when: inventory_hostname in groups['monasca-api'] or when: inventory_hostname in groups['monasca-api'] or
inventory_hostname in groups['monasca-log-api'] or inventory_hostname in groups['monasca-log-api'] or
inventory_hostname in groups['monasca-log-transformer'] inventory_hostname in groups['monasca-log-transformer'] or
inventory_hostname in groups['monasca-log-persister']
- include: bootstrap.yml - include: bootstrap.yml
when: inventory_hostname in groups['monasca-api'] when: inventory_hostname in groups['monasca-api']
...@@ -17,4 +18,5 @@ ...@@ -17,4 +18,5 @@
- include: check.yml - include: check.yml
"aliases": {},
"mappings": {
"log": {
"_all": {
"enabled": true,
"omit_norms": true
"dynamic_templates": [
"message_field": {
"mapping": {
"fielddata": {
"format": "disabled"
"index": "analyzed",
"omit_norms": true,
"type": "string"
"match": "message",
"match_mapping_type": "string"
"other_fields": {
"mapping": {
"index": "not_analyzed",
"type": "string"
"match": "*",
"properties": {
"@timestamp": {
"type": "date"
"@version": {
"type": "string"
"creation_time": {
"type": "date"
"order": 0,
"settings": {
"index": {
"refresh_interval": "5s"
"template": "monasca-*"
# Persist transformed logs to Elasticsearch
input {
kafka {
zk_connect => "{{ monasca_zookeeper_servers }}"
topic_id => "{{ monasca_transformed_logs_topic }}"
group_id => "transformer-logstash-consumer"
output {
elasticsearch {
index => "monasca-%{[meta][tenantId]}-%{+YYYY.MM.dd}"
hosts => [{{ monasca_elasticsearch_servers }}]
document_type => "log"
template_name => "monasca"
template => "/etc/logstash/elasticsearch-template.json"
"command": "/usr/share/logstash/bin/logstash --log-in-json --log /var/log/kolla/monasca/monasca-log-persister.log -f /etc/logstash/conf.d/log-persister.conf",
"config_files": [
"source": "{{ container_config_directory }}/log-persister.conf",
"dest": "/etc/logstash/conf.d/log-persister.conf",
"owner": "logstash",
"perm": "0600"
"source": "{{ container_config_directory }}/elasticsearch-template.json",
"dest": "/etc/logstash/elasticsearch-template.json",
"perm": "0600"
"permissions": [
"path": "/var/log/kolla/monasca",
"owner": "logstash:kolla",
"recurse": true
features:
Add support for deploying the Monasca Log Persister. The Log
Persister is responsible for reading logs from the Kafka processed
logs topic and writing them to Elasticsearch.
