Commit 48b5696b authored by Kevin TIBI's avatar Kevin TIBI
Fix cluster mode for skydive
If we use multiple skydive analyzers, we need to add this configuration.
Works with one node.
Change-Id: I9b52bf184e269d314e2af2ac80dc45557e3533af
parent 70a50993
...@@ -23,7 +23,7 @@ openstack: ...@@ -23,7 +23,7 @@ openstack:
etcd: etcd:
servers: servers:
{% if enable_etcd == "yes" %} {% if enable_etcd | bool %}
{% for host in groups['etcd'] %} {% for host in groups['etcd'] %}
- http://{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ etcd_client_port }} - http://{{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ etcd_client_port }}
{% endfor %} {% endfor %}
...@@ -19,9 +19,14 @@ openstack: ...@@ -19,9 +19,14 @@ openstack:
domain_name: Default domain_name: Default
endpoint_type: internal endpoint_type: internal
analyzers:
{% for host in groups['skydive-analyzer'] %}
- {{ hostvars[host]['ansible_' + hostvars[host]['api_interface']]['ipv4']['address'] }}:{{ skydive_analyzer_port }}
{% endfor %}
etcd: etcd:
client_timeout: 100 client_timeout: 100
embedded: false embedded: false
servers: servers:
