Commit 016089aa authored by Christian RAYMOND's avatar Christian RAYMOND
better alignment with almost similar objects
parent d7425d19
...@@ -96,6 +96,7 @@ The C++ version is template and can align any Objects with the folwing propertie ...@@ -96,6 +96,7 @@ The C++ version is template and can align any Objects with the folwing propertie
3) a `size()` method that return the number of character used to print the object 3) a `size()` method that return the number of character used to print the object
4) an `operator==()` to compare objects 4) an `operator==()` to compare objects
5) the `operator<<` in order to print the object in `size()` character 5) the `operator<<` in order to print the object in `size()` character
6) the `operator-` to privilegiate substitution over insertion/deletion when different object share similarity: return the percentage of similarity
### Exemple ### Exemple
...@@ -109,6 +110,7 @@ class Integer ...@@ -109,6 +110,7 @@ class Integer
int size() const {return std::to_string(_i).length();} //size() should provide the nbsymbols to write object on screen int size() const {return std::to_string(_i).length();} //size() should provide the nbsymbols to write object on screen
bool empty() const {return _i==std::numeric_limits<int>::max();}//empty() should say if the object is not empty (not constructed by the constructor without arg) bool empty() const {return _i==std::numeric_limits<int>::max();}//empty() should say if the object is not empty (not constructed by the constructor without arg)
bool operator==(const Integer& g) const {return _i==g._i;} //must provide a comparator bool operator==(const Integer& g) const {return _i==g._i;} //must provide a comparator
int operator-(const Integer& g) const {return std::min(_i,g._i)*100/std::max(_i,g._i);} //to privilegiate substitution error instead of insertion/deletion when operator== say false but objects share similarity (return PERCENTAGE of similarity so return always 0; to ignore this function)
friend std::ostream& operator<<(std::ostream& o,const Integer& i) {return o<<i._i;} friend std::ostream& operator<<(std::ostream& o,const Integer& i) {return o<<i._i;}
...@@ -12,6 +12,8 @@ ...@@ -12,6 +12,8 @@
#include "asciitablestream.hpp" #include "asciitablestream.hpp"
template<class T=std::string> template<class T=std::string>
class SequenceAligner class SequenceAligner
...@@ -316,7 +318,9 @@ class SequenceAligner ...@@ -316,7 +318,9 @@ class SequenceAligner
else else
subOp = SUB; subOp = SUB;
cs = cost[i-1][j-1] + substitutionPenalty; mint discountCost=abs(reference[i-1]-hypothesis[j-1]);
if(discountCost>0) discountCost = substitutionPenalty*discountCost/100;
cs = cost[i-1][j-1] + substitutionPenalty - discountCost ;
cmint ci = cost[i][j-1] + insertionPenalty; cmint ci = cost[i][j-1] + insertionPenalty;
cmint cd = cost[i-1][j] + deletionPenalty; cmint cd = cost[i-1][j] + deletionPenalty;
...@@ -401,3 +405,31 @@ class SequenceAligner ...@@ -401,3 +405,31 @@ class SequenceAligner
//utility for string
class Char
char _c;
public:
Char(): _c(0) {} //Default constructor should mark the object as empty in some way
Char(const char c): _c(c){}
int size() const {return 1;} //size() should provide the nbsymbols to write object on screen
bool empty() const {return _c==0;}//empty() should say if the object is not empty (not constructed by the constructor without arg)
bool operator==(const Char& g) const {return _c==g._c;} //must provide a comparator
int operator-(const Char& g) const {return 0;} //to privilegiate substitution error instead of insertion/deletion when operator== say false but objects share similarity (return 0; to ignore this function)
friend std::ostream& operator<<(std::ostream& o,const Char& i)
if(i._c==0) return o<<"";
return o<<i._c;
int operator-(const std::string& one,const std::string& two)
SequenceAligner<Char> wordAligner(false);
std::vector<Char> un{one.begin(),one.end()};
std::vector<Char> deux{two.begin(),two.end()};
const auto& res=wordAligner.align(un ,deux);
return res.f1();
...@@ -15,6 +15,7 @@ class Integer ...@@ -15,6 +15,7 @@ class Integer
int operator-(const Integer& g) const {return std::min(_i,g._i)*100/std::max(_i,g._i);} //to privilegiate substitution error instead of insertion/deletion when operator== say false but objects share similarity (return 0; to ignore this function), otherwise return the percentage of similarity
friend std::ostream& operator<<(std::ostream& o,const Integer& i) friend std::ostream& operator<<(std::ostream& o,const Integer& i)
if(i._i==std::numeric_limits<int>::max()) return o<<""; if(i._i==std::numeric_limits<int>::max()) return o<<"";
...@@ -71,7 +72,7 @@ int main(int argc,char*argv[0]) ...@@ -71,7 +72,7 @@ int main(int argc,char*argv[0])
std::cout<<"\n\n"<<ss<<std::endl; std::cout<<"\n\n"<<ss<<std::endl;
std::vector<Integer> num1={1,2,3}; std::vector<Integer> num1={400,2,3,300,308,306};
std::vector<Integer> num2={2,3,400}; std::vector<Integer> num2={2,3,400};
SequenceAligner<Integer> numEval; SequenceAligner<Integer> numEval;
