Commit c352f1eb authored by BERTOT Yves's avatar BERTOT Yves
separates computations to make functions available in the polynomial ring
parent e158ace5
...@@ -8,11 +8,46 @@ Set Implicit Arguments. ...@@ -8,11 +8,46 @@ Set Implicit Arguments.
Unset Strict Implicit. Unset Strict Implicit.
Unset Printing Implicit Defensive. Unset Printing Implicit Defensive.
Section num_computations.
Variable P : Type.
Variable R : unitRingType.
Variables coords : P -> R * R.
Definition mkf3 (T : Type) (a b c : T) :=
[ffun i : 'I_3 => if val i == 0 then a else if val i == 1 then b else c].
Notation "<< a ; b ; c >>" := (mkf3 a b c).
Definition project_p (p : R * R) : R ^ 3 :=
[ffun i => if val i == 0 then 1%R else if val i == 1 then p.1 else p.2].
Definition surface_mx (t : (R * R)%type ^ 3) :=
(\matrix_(i < 3, j < 3) project_p (t i) j)%R.
End num_computations.
Section num_computations_comparison.
Variable P : Type.
Variable R : realDomainType.
Variable coords : P -> R * R.
Definition ccw0 (a b c : R * R) := (0 < \det (surface_mx (mkf3 a b c)))%R.
Definition ccw (a b c : P) := ccw0 (coords a) (coords b) (coords c).
End num_computations_comparison.
Section abstract_over_types. Section abstract_over_types.
Variable P : finType. Variable P : finType.
Variable R : numDomainType. Variable R : realDomainType.
Variable coords : P -> R * R. Variable coords : P -> R * R.
...@@ -22,20 +57,9 @@ Variable pick_set : {set P} -> option P. ...@@ -22,20 +57,9 @@ Variable pick_set : {set P} -> option P.
Variable pick_triangle : {set {set P}} -> P -> option {set P}. Variable pick_triangle : {set {set P}} -> P -> option {set P}.
Notation "<< a ; b ; c >>" := (mkf3 a b c). Notation "<< a ; b ; c >>" := (mkf3 a b c).
Definition project_p (p : P) : R ^ 3 := Notation ccw := (ccw coords).
[ffun i =>
else if val i == 1 then (coords p).1 else (coords p).2].
Definition surface_mx (t : P ^ 3) :=
Definition ccw (a b c : P) := (0 < \det (surface_mx << a; b; c>>))%R.
Definition separated (t : {set P}) (q p : P) := Definition separated (t : {set P}) (q p : P) :=
(q \in t) && (q \in t) &&
...@@ -280,15 +304,15 @@ Definition naive_triangulate' (s : {set P}) := naive_triangulate #|s| s. ...@@ -280,15 +304,15 @@ Definition naive_triangulate' (s : {set P}) := naive_triangulate #|s| s.
Definition flip_edge (t1 t2 : {set P}) := Definition flip_edge (t1 t2 : {set P}) :=
[set x |: (t1 :\: t2) :|: (t2 :\: t1) | x in t1 :&: t2]. [set x |: (t1 :\: t2) :|: (t2 :\: t1) | x in t1 :&: t2].
Definition in_circle_l (p : P) : R ^ 4 := Definition in_circle_l (p : R * R) : R ^ 4 :=
[ffun i : 'I_4 => [ffun i : 'I_4 =>
if val i < 3 then if val i < 3 then
project_p p (inord i) project_p p (inord i)
else else
((coords p).1 ^+ 2 + (coords p).2 ^+ 2)%R]. (p.1 ^+ 2 + p.2 ^+ 2)%R].
Definition in_circle_mx (t : P ^ 4) := Definition in_circle_mx (t : P ^ 4) :=
(\matrix_(i < 4, j < 4) in_circle_l (t i) j)%R. (\matrix_(i < 4, j < 4) in_circle_l (coords (t i)) j)%R.
