Python3 compatibility
Hi,
I got this compilation error, on a Raspberry Pi with ArchLinux ARM (as Raspbian has a version of Qt5 that is too old):
/home/alarm/aseba/enki/python/enki.cpp: In static member function 'static void* Vector_from_python::convertible(PyObject*)':
/home/alarm/aseba/enki/python/enki.cpp:108:34: error: 'PyInt_Check' was not declared in this scope
if (!(PyFloat_Check(item0) || PyInt_Check(item0)))
/home/alarm/aseba/enki/python/enki.cpp:108:34: note: suggested alternative: 'PySet_Check'
PySet_Check
/home/alarm/aseba/enki/python/enki.cpp:112:34: error: 'PyInt_Check' was not declared in this scope
if (!(PyFloat_Check(item1) || PyInt_Check(item1)))
/home/alarm/aseba/enki/python/enki.cpp:112:34: note: suggested alternative: 'PySet_Check'
PySet_Check
/home/alarm/aseba/enki/python/enki.cpp:123:34: error: 'PyInt_Check' was not declared in this scope
/home/alarm/aseba/enki/python/enki.cpp:123:34: note: suggested alternative: 'PySet_Check'
PySet_Check
/home/alarm/aseba/enki/python/enki.cpp:127:34: error: 'PyInt_Check' was not declared in this scope
/home/alarm/aseba/enki/python/enki.cpp:127:34: note: suggested alternative: 'PySet_Check'
PySet_Check
So it seems that this package is not yet compatible with Python 3, right ?
Therefore, I suggest either to make it compatible, or to raise an issue in CMake if PYTHON_VERSION_MAJOR > 2
Also, this could be documented, and adding -DPYTHON_EXECUTABLE=$(which python2)
should be enough to workaround this.
