GitLab
Explore
Primary navigation
Search or go to…
V
VARNA-api
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
AMIBIO
VARNA-api
a57a71fc
a57a71fc
3 years ago
htyao
Downloads
Patches
Add function show()
0db6d234
1 merge request
!9
Add cartoon like example
src/varnaapi/models.py
+7
7 additions, 0 deletions
7 additions
7
a57a71fc
@@ -4,6 +4,7 @@ import abc
from
string
import
ascii_lowercase
ascii_uppercase
from
colour
import
Color
import
subprocess
from
tempfile
import
NamedTemporaryFile
from
deprecated
import
deprecated
from
IPython.display
import
display
SVG
@@ -243,6 +244,12 @@ class BasicDraw(VarnaConfig):
elif
output
3
svg
display
SVG
filename
output
def
show
self
extension
png
Show the drawing
Equivalent to `savefig(tmp, show=True)` where tmp is a temporary file
tmp
NamedTemporaryFile
suffix
extension
self
savefig
tmp
name
show
True
class
Structure
BasicDraw
def
__init__
self
sequence
None
structure
None
This diff is collapsed.
Loading
Save comment
