Commit 1a7279ca authored by Clémence Laurent's avatar Clémence Laurent
changes previously made to .pm file to python
parent 8da38e6b
...@@ -52,15 +52,15 @@ def altok_split_sentences(s, lang, weak_sbound = 0, less_lists = 0, noxml = 0, a ...@@ -52,15 +52,15 @@ def altok_split_sentences(s, lang, weak_sbound = 0, less_lists = 0, noxml = 0, a
s = re.sub(r"&lt; *br *(?:\/ *)?&gt;", r'</s><s type="br">', s) s = re.sub(r"&lt; *br *(?:\/ *)?&gt;", r'</s><s type="br">', s)
if re.search(r"^(ja|zh|tw)$", lang): if re.search(r"^(ja|zh|tw)(_|$)", lang):
s = re.sub(r"([①-⑫●※*■◆→⇒◇◎★☆〇·•])", r"<l/>\1", s) s = re.sub(r"([①-⑫●※*■◆→⇒◇◎★☆〇·•])", r"<l/>\1", s)
s = re.sub(r"(?<![1-91-9〇零一二三四五六七八九○十百千萬億兆万亿])( +)(○ +)(?![1-91-9〇零一二三四五六七八九○十百千萬億兆万亿])", r"\1<l/>\2", s) s = re.sub(r"(?<![1-91-9〇零一二三四五六七八九○十百千萬億兆万亿])( +)(○ +)(?![1-91-9〇零一二三四五六七八九○十百千萬億兆万亿])", r"\1<l/>\2", s)
s = re.sub(r"([\(\(] *[1-91-9] *[\)\)])", r"<l/>\1", s) s = re.sub(r"([\(\(] *[1-91-9] *[\)\)])", r"<l/>\1", s)
s = re.sub(r"(?<![\(\(A-Za-z] )(?<![0-91-9A-Za-z])([1-91-9]+ +[\.\)、\)。,::])", r"<l/>\1", s) s = re.sub(r"(?<![\(\(A-Za-z] )(?<![0-91-9A-Za-z])([1-91-9]+ +[\.\)、\)。,::])", r"<l/>\1", s)
s = re.sub(r"(^|。)( +)((?:第 )?[一二] [\.\)、\)。,::])", r"\1\2<l/>\3", s) s = re.sub(r"(^|。)( +)((?:第 )?[一二] [\.\)、\)。,::])", r"\1\2<l/>\3", s)
elif re.search(r"^th$", lang): elif re.search(r"^th(_|$)", lang):
s = re.sub(r"(^|<br\/?>)( +)(๑๐|๑?[๑๒๓๔๕๖๗๘๙])( \.)", r"\1\2</l>\3 \4", s) s = re.sub(r"(^|<br\/?>)( +)(๑๐|๑?[๑๒๓๔๕๖๗๘๙])( \.)", r"\1\2</l>\3 \4", s)
elif lang == "km": elif re.search(r"^km(_|$)", lang):
s = re.sub(r"([\P{Latin}\)][ ​]*)(-[ ​]*\P{Latin})", r"\1</l>\2", s) s = re.sub(r"([\P{Latin}\)][ ​]*)(-[ ​]*\P{Latin})", r"\1</l>\2", s)
s = re.sub(r"([\P{Latin}\)][ ​]*)(\d+ ?[,\-][ ​]*\P{Latin})", r"\1</l>\2", s) s = re.sub(r"([\P{Latin}\)][ ​]*)(\d+ ?[,\-][ ​]*\P{Latin})", r"\1</l>\2", s)
else: else:
...@@ -84,31 +84,32 @@ def altok_split_sentences(s, lang, weak_sbound = 0, less_lists = 0, noxml = 0, a ...@@ -84,31 +84,32 @@ def altok_split_sentences(s, lang, weak_sbound = 0, less_lists = 0, noxml = 0, a
#un ajout d'espace ici en faisant le process de trad #un ajout d'espace ici en faisant le process de trad
s = re.sub(r'<s type="br"></s>( *)<s type="li">', r'\1<s type="br,li">', s) s = re.sub(r'<s type="br"></s>( *)<s type="li">', r'\1<s type="br,li">', s)
if re.search(r"^(ja|zh)$", lang): if re.search(r"^(ja|zh)(_|$)", lang):
s = re.sub(r" ([!?\!\?。。])( +)", r" \1</s>\2<s>", s) s = re.sub(r" ([!?\!\?。。\.])( +)", r" \1</s>\2<s>", s)
if weak_sbound > 0: if weak_sbound > 0:
s = re.sub(r" ([:;:;]|)( +)", r" \1</s>\2<s>", s) s = re.sub(r" ([:;:;]|)( +)", r" \1</s>\2<s>", s)
s = re.sub(r" ([។៕])( +)", r" \1</s>\2<s>", s) s = re.sub(r" ([។៕])( +)", r" \1</s>\2<s>", s)
elif lang == "th": elif re.search(r"^th(_|$)", lang)::
pass pass
else: else:
s = re.sub(rf"([\.:;\?\!]) ([\"“”\˝] {maj.pattern}[^\"“”\˝<>]*[\.:;\?\!] [\"“”\˝]) ({maj.pattern})", r"\1</s> <s>\2</s> <s>\3", s) # detection of sentences entirely surrounded by double quotes s = re.sub(rf"([\.:;\?\!])( +)([\"“”\˝] {maj.pattern}[^\"“”\˝<>]*[\.:;\?\!] [\"“”\˝])( +)({maj.pattern})", r"\1</s>\2<s>\3</s>\4<s>\5", s) # detection of sentences entirely surrounded by double quotes
s = re.sub(rf"([\.:;\?\!]) ([\"“”\˝] {maj.pattern}[^\"“”\˝<>]*[\.:;\?\!] [\"“”\˝]) $", r"\1</s> <s>\2</s> ", s) # detection of sentences entirely surrounded by double quotes s = re.sub(rf"([\.:;\?\!])( +)([\"“”\˝] {maj.pattern}[^\"“”\˝<>]*[\.:;\?\!] [\"“”\˝])( +)$", r"\1</s>\2<s>\3</s>\4", s) # detection of sentences entirely surrounded by double quotes
s = re.sub(rf"(\.(?: \.)*)( +)(\( \. \. \. \))( +)({maj.pattern}|[\[_{{\.])", r"\1</s>\2<s>\3</s>\4<s>\5", s) s = re.sub(rf"(\.(?: \.)*|…)( +)(\( (?:\. \. \.|…) \))( +)({maj.pattern}|[\[_{{\.])", r"\1</s>\2<s>\3</s>\4<s>\5", s)
s = re.sub(rf"([^\.][0-9}} ]\.(?: \.)*)( +)({initialclass.pattern}|{special_split.pattern})", r"\1</s>\2<s>\3", s) # STANDARD CASE s = re.sub(rf"([^\.][0-9}} ](?:\.(?: \.)*|…))( +)({initialclass.pattern}|{special_split.pattern})", r"\1</s>\2<s>\3", s) # STANDARD CASE
s = re.sub(rf"({maj.pattern}{l.pattern}+ {maj.pattern} \.)</s> <s>({maj.pattern}{l.pattern}+ )", r"\1 \2", s) # oversegmentation correction by the standard case (case Prénom I. Nom) s = re.sub(rf"({maj.pattern}{l.pattern}+ {maj.pattern} \.)</s> <s>({maj.pattern}{l.pattern}+ )", r"\1 \2", s) # oversegmentation correction by the standard case (case Prénom I. Nom)
s = re.sub(rf"\b((?:mr?s?|me?lle|[pd]r) \.)</s> <s>((?:{maj.pattern} \. )*{maj.pattern}{l.pattern}+ )", r"\1 \2", s, flags = re.IGNORECASE) # oversegmentation correction by the standard case (cas Mr. et autres) s = re.sub(rf"\b((?:mr?s?|me?lle|[pd]r) \.)</s>( +)<s>((?:{maj.pattern} \. )*{maj.pattern}{l.pattern}+ )", r"\1\2\3", s, flags = re.IGNORECASE) # oversegmentation correction by the standard case (cas Mr. et autres)
s = re.sub(rf"( {strictmaj.pattern} \.)</s> <s>({minus.pattern}(?:{l.pattern}+| \.) )", r"\1 \2", s) # oversegmentation correction by the standard case in mode 'allow_sentence_initial_lowercase' (examples: A.F.D.S.F.G. est une entreprise connue. | We need to R.S.V.P. a.s.a.p., you know!) s = re.sub(rf"( {strictmaj.pattern} \.)</s> <s>({minus.pattern}(?:{l.pattern}+| \.) )", r"\1 \2", s) # oversegmentation correction by the standard case in mode 'allow_sentence_initial_lowercase' (examples: A.F.D.S.F.G. est une entreprise connue. | We need to R.S.V.P. a.s.a.p., you know!)
s = re.sub(rf"( {minus.pattern} \. {minus.pattern} \.)</s> <s>({minus.pattern}(?:{l.pattern}+| \.) )", r"\1 \2", s) # oversegmentation correction by the standard case in mode 'allow_sentence_initial_lowercase' (exemple: Please r.s.v.p. a.s.a.p. otherwise who know what will happen.) s = re.sub(rf"( {minus.pattern} \. {minus.pattern} \.)</s> <s>({minus.pattern}(?:{l.pattern}+| \.) )", r"\1 \2", s) # oversegmentation correction by the standard case in mode 'allow_sentence_initial_lowercase' (exemple: Please r.s.v.p. a.s.a.p. otherwise who know what will happen.)
s = re.sub(rf"( {minus.pattern} \.)</s> <s>({minus.pattern} \. )", r"\1 \2", s) # oversegmentation correction by the standard case in mode 'allow_sentence_initial_lowercase' (exemple: e. g.)
s = re.sub(rf"({l.pattern}|[\!\?])( +)(\. \. \.)( +)({maj.pattern}|{special_split.pattern})", r"\1</s>\2<s>\3</s>\4<s>\5", s) # used to use $l instead of $maj s = re.sub(rf"({l.pattern}|[\!\?])( +)(\. \. \.)( +)({maj.pattern}|{special_split.pattern})", r"\1</s>\2<s>\3</s>\4<s>\5", s) # used to use $l instead of $maj
s = re.sub(rf"(\. \.(?: \.)*)( +)({maj.pattern}|{special_split.pattern})", r"\1</s>\2<s>\3", s) s = re.sub(rf"(\. \.(?: \.)*)( +)({maj.pattern}|{special_split.pattern})", r"\1</s>\2<s>\3", s)
s = re.sub(rf"(\. (?: \.)+)( )({initialclass.pattern})", r"\1</s>\2<s>\3", s) # attention !!! s = re.sub(rf"(\. (?: \.)+)( +)({initialclass.pattern})", r"\1</s>\2<s>\3", s) # attention !!!
s = re.sub(r"(\. (?: \.)+)( +)([\[_\{\-\«¿¡])", r"\1</s>\2<s>\3", s) # attention !!! s = re.sub(r"(\. (?: \.)+)( +)([\[_\{\-\«¿¡])", r"\1</s>\2<s>\3", s) # attention !!!
s = re.sub(rf"([\?\!](?: ?(?: \.)+)?)( )({initialclass.pattern})", r"\1</s>\2<s>\3", s) # attention !!! s = re.sub(rf"([\?\!](?: ?(?: \.)+)?)( +)({initialclass.pattern})", r"\1</s>\2<s>\3", s) # attention !!!
s = re.sub(r"([\?\!](?: ?(?: \.)+)?)( +)([\[_\{\-\«¿¡])", r"\1</s>\2<s>\3", s) # attention !!! s = re.sub(r"([\?\!](?: ?(?: \.)+)?)( +)([\[_\{\-\«¿¡])", r"\1</s>\2<s>\3", s) # attention !!!
s = re.sub(r"([\.\?\!] +\.(?: \.)+)( )", r"\1</s>\2<s>", s) # attention s = re.sub(r"([\.\?\!] +\.(?: \.)+)( +)", r"\1</s>\2<s>", s) # attention
s = re.sub(r"([\.\?\!,:])( )([\-\+\«¿¡])", r"\1</s>\2<s>\3", s) # attention s = re.sub(r"([\.\?\!,:])( )([\-\+\«¿¡])", r"\1</s>\2<s>\3", s) # attention
if weak_sbound > 0: # if $weak_sbound, colons are sentence boundaries if weak_sbound > 0: # if $weak_sbound, colons are sentence boundaries
