Commit f8da0ea0 authored by GARNIER Laurent's avatar GARNIER Laurent
update message
parent 56c42c55
1 merge request!7Jupyter token 2021
......@@ -108,7 +108,7 @@ class Init:
if 'allgo_instance' in kwargs:
API_parameters['allgo_instance'] = kwargs['allgo_instance']
# Try to communicate with Allgo
# Try to communicate with Allgo to test allgo instance
try:
if(not API_parameters['verbose_level'] == 'errors'):
print("\n Try to connect to the allgo API instance: "+API_parameters['allgo_instance'])
