GitLab
Explore
Primary navigation
Search or go to…
python_client
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
allgo
API-Clients
python_client
436fb669
There was an error fetching the commit references. Please try again later.
436fb669
5 years ago
LETORT Sebastien
Downloads
Patches
new unit test for StatusError (minor)
5ce186b7
2 merge requests
!4
Client api
!2
Continuous integration, more tests
tests/test_allgo.py
+17
17 additions, 0 deletions
tests/test_allgo.py
17 additions
tests/test_allgo.py
17
436fb669
@@ -18,6 +18,23 @@ else:
import
allgo
# I need to modify constant
import
allgo
from
allgo
import
from
allgo
import
class
TestStatusError
REF_MSG
whatever, an error message.
@pytest.fixture
def
response
self
m
Mock
m
json
return_value
error
self
REF_MSG
return
m
@pytest.mark.dbg
def
test_msg
self
response
err
StatusError
42
response
assert
self
REF_MSG
err
msg
@pytest.fixture
scope
module
@pytest.fixture
scope
module
This diff is collapsed.
Loading
Save comment
