Compare revisions
Changes are shown as if the source revision was being merged into the target revision. Learn more about comparing revisions.
Source
Select target project
No results found
Select Git revision
  • 1-define-a-function-to-take-a-numpy-array
  • 1-define-a-function-to-take-a-numpy-array-2
  • 3-return-array-or-vector-from-c
  • 7-setup-ci
  • dev
  • feature/cgal-linking
  • feature/cgal_meshing
  • feature/tetrahedra-class
  • master
9 results
Target
  • afarnudi/pybinder_test
1 result
Select Git revision
  • 7-setup-ci
  • dev
  • master
9 results
Show changes
Commits on Source (8)
...@@ -11,7 +11,7 @@ tests: ...@@ -11,7 +11,7 @@ tests:
stage: test stage: test
tags: tags:
- ci.inria.fr - ci.inria.fr
- small - medium
script: script:
- pip install pytest coverage - pip install pytest coverage
- pip install -e . - pip install -e .
...@@ -33,7 +33,7 @@ build: ...@@ -33,7 +33,7 @@ build:
tags: tags:
- small - medium
script: script:
- pip install --upgrade build - pip install --upgrade build
- python -m build - python -m build
...@@ -9,7 +9,7 @@ project( ...@@ -9,7 +9,7 @@ project(
VERSION ${SKBUILD_PROJECT_VERSION} VERSION ${SKBUILD_PROJECT_VERSION}
LANGUAGES CXX) LANGUAGES CXX)
set(CMAKE_CXX_STANDARD 17) set(CMAKE_CXX_STANDARD 20)
set(CMAKE_CXX_STANDARD_REQUIRED ON) set(CMAKE_CXX_STANDARD_REQUIRED ON)
# Find the module development requirements (requires FindPython from 3.17 or # Find the module development requirements (requires FindPython from 3.17 or
...@@ -2,8 +2,10 @@ project(_cpp) ...@@ -2,8 +2,10 @@ project(_cpp)
add_library(_cpp SHARED add_library(_cpp SHARED
CgalLabelledImage.h CgalLabelledImage.h
CgalImageMeshing.h
LabelledTetrahedralMesh.h LabelledTetrahedralMesh.h
CgalLabelledImage.cpp CgalLabelledImage.cpp
CgalImageMeshing.cpp
LabelledTetrahedralMesh.cpp LabelledTetrahedralMesh.cpp
target_link_libraries(_cpp PUBLIC Eigen3::Eigen) target_link_libraries(_cpp PUBLIC Eigen3::Eigen)
#include <iostream>
#include <map>
#include <chrono>
#include "CgalLabelledImage.h"
#include "LabelledTetrahedralMesh.h"
#include "CgalImageMeshing.h"
C3t3 meshCgalImage(CGAL::Image_3 image, double facet_angle, double facet_size, double facet_distance, double cell_radius_edge_ratio, double cell_size)
auto start_time = std::chrono::system_clock::now();
std::cout<<" --> Computing tetrahedrization"<<std::endl;
Mesh_domain domain = Mesh_domain::create_labeled_image_mesh_domain(image);
// Mesh criteria
Mesh_criteria::Facet_criteria facet_criteria(facet_angle, facet_size, facet_distance); // angle, size, approximation
Mesh_criteria::Cell_criteria cell_criteria(cell_radius_edge_ratio, cell_size); // radius-edge ratio, size
Mesh_criteria criteria(facet_criteria, cell_criteria);
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria);
auto end_time = std::chrono::system_clock::now();
std::cout<<" <-- Computing tetrahedrization ("<<c3t3.number_of_cells()<<" cells, "<<c3t3.triangulation().number_of_vertices()<<" vertices) ["<<(end_time - start_time).count()/1000.<<"s]"<<std::endl;
return c3t3;
LabelledTetrahedralMesh tetraMeshFromCgal(C3t3 c3t3)
LabelledTetrahedralMesh mesh;
Tr tri = c3t3.triangulation();
std::cout<<" --> Adding points"<<std::endl;
std::vector<Tr::Point> points;
std::unordered_map<double, std::unordered_map<double, std::unordered_map<double, int> > > point_vertices;
for (auto vertex_it = tri.all_vertices_begin(); vertex_it != tri.all_vertices_end(); ++vertex_it) {
auto point = vertex_it->point();
if (!point_vertices.contains(point.x())) {
point_vertices[point.x()] = std::unordered_map<double, std::unordered_map<double, int> >();
if (!point_vertices[point.x()].contains(point.y())) {
point_vertices[point.x()][point.y()] = std::unordered_map<double, int>();
point_vertices[point.x()][point.y()][point.z()] = points.size();
points.push_back(point);
mesh.addPoint({point.x(), point.y(), point.z()});
std::cout<<" <-- Adding points ["<<(end_time - start_time).count()/1000.<<"s]"<<std::endl;
std::vector<std::vector<int> > triangle_vertices;
std::unordered_map<int, std::unordered_map<int, std::unordered_map<int, int> > > triangle_indices;
for (auto facet_it = c3t3.facets_in_complex_begin(); facet_it != c3t3.facets_in_complex_end(); ++facet_it) {
std::pair<Tr::Cell_handle, int> facet = *facet_it;
auto cell = facet.first;
auto f_id = facet.second;
auto triangle = tri.triangle(cell, f_id);
//std::cout<<triangle[0]<<" "<<triangle[1]<<" "<<triangle[2]<<std::endl;
std::vector<int> vertices;
for (int v=0; v<3; v++) {
auto point = triangle[v];
int vertex = point_vertices[point.x()][point.y()][point.z()];
vertices.push_back(vertex);
triangle_indices[vertices[0]][vertices[1]][vertices[2]] = triangle_vertices.size();
triangle_vertices.push_back(vertices);
// std::cout<<triangle_vertices.size()<<" triangles"<<std::endl;
std::vector<std::vector<int> > tetra_vertices;
std::vector<int> tetra_labels;
std::cout<<" --> Adding tetras"<<std::endl;
for (auto cell_it = c3t3.cells_in_complex_begin(); cell_it != c3t3.cells_in_complex_end(); ++cell_it) {
auto tetra = tri.tetrahedron(cell_it);
for (int v=0; v<4; v++) {
auto point = tetra[v];
tetra_vertices.push_back(vertices);
int label = cell_it->subdomain_index();
tetra_labels.push_back(label);
mesh.addTetra({vertices[0], vertices[1], vertices[2], vertices[3]}, label);
// std::cout<<" Tetra "<<vertices[0]<<" "<<vertices[1]<<" "<<vertices[2]<<" "<<vertices[3]<<std::endl;
for (int t=0; t<4; t++) {
auto triangle = tri.triangle(cell_it, t);
std::vector<int> t_vertices;
t_vertices.push_back(vertex);
// std::cout<<" Triangle "<<triangle_indices[t_vertices[0]][t_vertices[1]][t_vertices[2]]<<std::endl;
// std::cout<<tetra_vertices.size()<<" tetras"<<std::endl;
std::cout<<" <-- Adding tetras ["<<(end_time - start_time).count()/1000.<<"s]"<<std::endl;
return mesh;
LabelledTetrahedralMesh cgalImageMeshing(Eigen::Array<unsigned short, Eigen::Dynamic, 1> image_array, Eigen::Array<int, 3, 1> shape, Eigen::Array<double, 3, 1> voxelsize, double facet_angle, double facet_size, double facet_distance, double cell_radius_edge_ratio, double cell_size)
CGAL::Image_3 image = buildCgalImage(image_array, shape, voxelsize);
C3t3 c3t3 = meshCgalImage(image, facet_angle, facet_size, facet_distance, cell_radius_edge_ratio, cell_size);
LabelledTetrahedralMesh mesh = tetraMeshFromCgal(c3t3);
return mesh;
#pragma once
#include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Labeled_image_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/Image_3.h>
#include <Eigen/Dense>
class LabelledTetrahedralMesh;
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Labeled_mesh_domain_3<K> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain, CGAL::Default, CGAL::Sequential_tag>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
// Criteria
typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
C3t3 meshCgalImage(CGAL::Image_3 image, double facet_angle=30, double facet_size=6, double facet_distance=4, double cell_radius_edge_ratio=3, double cell_size=8);
LabelledTetrahedralMesh tetraMeshFromCgal(C3t3 c3t3);
Eigen::Array<double, 3, 1> voxelsize={1.0, 1.0, 1.0},
double cell_size=8
#include "LabelledTetrahedralMesh.h" #include "LabelledTetrahedralMesh.h"
#include <iostream>
std::vector< std::vector<int> > LabelledTetrahedralMesh::_tetra_triangle_indices = {{0, 1, 2}, {1, 3, 2}, {2, 3, 0}, {3, 1, 0}};
Eigen::ArrayX3d LabelledTetrahedralMesh::vertexPoints(void) const Eigen::ArrayX3d LabelledTetrahedralMesh::vertexPoints(void) const
...@@ -38,9 +42,53 @@ Eigen::Array<unsigned short, Eigen::Dynamic, 1> LabelledTetrahedralMesh::tetraLa ...@@ -38,9 +42,53 @@ Eigen::Array<unsigned short, Eigen::Dynamic, 1> LabelledTetrahedralMesh::tetraLa
return tetra_labels; return tetra_labels;
Eigen::Array<unsigned short, Eigen::Dynamic, 3> LabelledTetrahedralMesh::triangleVertices(void) const
Eigen::Array<unsigned short, Eigen::Dynamic, 3> triangle_vertices(this->_triangle_vertices.size(), 3);
for (int i=0; i<this->_triangle_vertices.size(); i++) {
triangle_vertices(i, v) = this->_triangle_vertices[i][v];
return triangle_vertices;
Eigen::Array<int, Eigen::Dynamic, 2> LabelledTetrahedralMesh::triangleLabels(void) const
Eigen::Array<int, Eigen::Dynamic, 2> triangle_labels(this->_triangle_tetras.size(), 2);
for (int i=0; i<this->_triangle_tetras.size(); i++) {
triangle_labels(i, 0) = this->_tetra_labels[this->_triangle_tetras[i][0]];
if (this->_triangle_tetras[i].size() > 1) {
triangle_labels(i, 1) = this->_tetra_labels[this->_triangle_tetras[i][1]];
} else {
triangle_labels(i, 1) = -1;
return triangle_labels;
void LabelledTetrahedralMesh::addTetra(Eigen::Array<unsigned short, 4, 1> tetra, unsigned short label) void LabelledTetrahedralMesh::addTetra(Eigen::Array<unsigned short, 4, 1> tetra, unsigned short label)
std::vector<unsigned short> _tetra = std::vector<unsigned short> {tetra(0), tetra(1), tetra(2), tetra(3)}; std::vector<unsigned short> _tetra = std::vector<unsigned short> {tetra(0), tetra(1), tetra(2), tetra(3)};
unsigned short tetra_index = static_cast<unsigned short>(this->_tetra_vertices.size());
for (auto triangle_indices : LabelledTetrahedralMesh::_tetra_triangle_indices) {
std::vector<unsigned short> _triangle;
for (auto i_t : triangle_indices) {
_triangle.push_back(tetra(i_t));
std::sort(_triangle.begin(), _triangle.end());
auto triangle_match = std::find(this->_triangle_vertices.begin(), this->_triangle_vertices.end(), _triangle);
if (triangle_match == this->_triangle_vertices.end()) {
this->_triangle_vertices.push_back(_triangle);
this->_triangle_tetras.push_back({ tetra_index });
} else {
int triangle_index = triangle_match-_triangle_vertices.begin();
this->_triangle_tetras[triangle_index].push_back(tetra_index);
this->_tetra_vertices.push_back(_tetra); this->_tetra_vertices.push_back(_tetra);
this->_tetra_labels.push_back(label); this->_tetra_labels.push_back(label);
...@@ -17,10 +17,21 @@ public: ...@@ -17,10 +17,21 @@ public:
Eigen::Array<unsigned short, Eigen::Dynamic, 1> tetraLabels(void) const; Eigen::Array<unsigned short, Eigen::Dynamic, 1> tetraLabels(void) const;
void addTetra(Eigen::Array<unsigned short, 4, 1> tetra, unsigned short label); void addTetra(Eigen::Array<unsigned short, 4, 1> tetra, unsigned short label);
public:
Eigen::Array<unsigned short, Eigen::Dynamic, 3> triangleVertices(void) const;
Eigen::Array<int, Eigen::Dynamic, 2> triangleLabels(void) const;
private: private:
std::vector< std::vector<double> > _vertex_points; std::vector< std::vector<double> > _vertex_points;
std::vector< std::vector<unsigned short> > _tetra_vertices; std::vector< std::vector<unsigned short> > _tetra_vertices;
std::vector< unsigned short > _tetra_labels; std::vector< unsigned short > _tetra_labels;
std::vector< std::vector<unsigned short> > _triangle_vertices;
std::vector< std::vector<unsigned short> > _triangle_tetras;
private:
static std::vector< std::vector<int> > _tetra_triangle_indices;
LabelledTetrahedralMesh makeTetrahedron(void); LabelledTetrahedralMesh makeTetrahedron(void);
\ No newline at end of file
from typing import Iterable, Optional from typing import Iterable
import numpy as np import numpy as np
from ._wrp import LabelledTetrahedralMesh, make_tetrahedron from ._wrp import LabelledTetrahedralMesh, make_tetrahedron
from ._wrp import build_cgal_image as _build_cgal_image from ._wrp import build_cgal_image as _build_cgal_image
from ._wrp import cgal_image_meshing as _cgal_image_meshing
def build_cgal_image(img: np.ndarray, voxelsize: Optional[Iterable[float]]=(1., 1., 1.)) -> bool: def build_cgal_image(img: np.ndarray, voxelsize: Iterable[float]=(1., 1., 1.)) -> bool:
return _build_cgal_image(img.ravel().astype(np.uint16), img.shape, voxelsize) return _build_cgal_image(img.ravel().astype(np.uint16), img.shape, voxelsize)
def cgal_image_meshing(
img: np.ndarray, voxelsize: Iterable[float]=(1., 1., 1.),
facet_angle: float=30., facet_size: float=6., facet_distance: float=4.,
cell_radius_edge_ratio: float=3., cell_size: float=8.
) -> LabelledTetrahedralMesh:
return _cgal_image_meshing(
img.ravel().astype(np.uint16), img.shape, voxelsize,
import unittest
from pybind_example.labelled_tetrahedral_mesh import cgal_image_meshing
class TestCgalImage(unittest.TestCase):
def setUp(self):
self.image = np.zeros((10, 8, 6), dtype=np.uint16)
self.image[:, :, 4:] = 1
self.image[:, :4, :4] = 2
self.image[:, 4:, :4] = 3
self.voxelsize = [0.5, 0.5, 1]
def tearDown(self):
pass
def test_cgal_meshing(self):
mesh = cgal_image_meshing(self.image, voxelsize=self.voxelsize, cell_size=1.)
tetra_labels = mesh.tetra_labels()
assert len(tetra_labels) > 0
assert all([l in tetra_labels for l in np.unique(self.image)])
n_tetras = len(tetra_labels)
refined_mesh = cgal_image_meshing(self.image, voxelsize=self.voxelsize, cell_size=0.5)
assert len(refined_mesh.tetra_labels()) > n_tetras
...@@ -3,6 +3,7 @@ ...@@ -3,6 +3,7 @@
#include <pybind11/eigen.h> #include <pybind11/eigen.h>
#include "CgalLabelledImage.h" #include "CgalLabelledImage.h"
namespace py = pybind11; namespace py = pybind11;
...@@ -24,9 +25,13 @@ PYBIND11_MODULE(_wrp, m) { ...@@ -24,9 +25,13 @@ PYBIND11_MODULE(_wrp, m) {
.def("add_point", &LabelledTetrahedralMesh::addPoint, py::arg("point")) .def("add_point", &LabelledTetrahedralMesh::addPoint, py::arg("point"))
.def("tetra_vertices", &LabelledTetrahedralMesh::tetraVertices) .def("tetra_vertices", &LabelledTetrahedralMesh::tetraVertices)
.def("tetra_labels", &LabelledTetrahedralMesh::tetraLabels) .def("tetra_labels", &LabelledTetrahedralMesh::tetraLabels)
.def("triangle_vertices", &LabelledTetrahedralMesh::triangleVertices)
.def("triangle_labels", &LabelledTetrahedralMesh::triangleLabels)
.def("add_tetra", &LabelledTetrahedralMesh::addTetra, py::arg("tetra"), py::arg("label")); .def("add_tetra", &LabelledTetrahedralMesh::addTetra, py::arg("tetra"), py::arg("label"));
m.def("make_tetrahedron", &makeTetrahedron); m.def("make_tetrahedron", &makeTetrahedron);
m.def("build_cgal_image", &cgalLabelledImage, py::arg("image_array"), py::arg("shape"), py::arg("voxelsize")); m.def("build_cgal_image", &cgalLabelledImage, py::arg("image_array"), py::arg("shape"), py::arg("voxelsize"));
m.def("cgal_image_meshing", &cgalImageMeshing, py::arg("image_array"), py::arg("shape"), py::arg("voxelsize"), py::arg("facet_angle"), py::arg("facet_size"), py::arg("facet_distance"), py::arg("cell_radius_edge_ratio"), py::arg("cell_size"));
