Unverified Commit ce7c529d authored by dependabot[bot]'s avatar dependabot[bot] Committed by GitHub
chore(deps): bump pypa/cibuildwheel from 2.8.0 to 2.8.1 (#41)
Bumps [pypa/cibuildwheel](https://github.com/pypa/cibuildwheel) from 2.8.0 to 2.8.1.
- [Release notes](https://github.com/pypa/cibuildwheel/releases)
- [Changelog](https://github.com/pypa/cibuildwheel/blob/main/docs/changelog.md)
- [Commits](https://github.com/pypa/cibuildwheel/compare/v2.8.0...v2.8.1
updated-dependencies:
- dependency-name: pypa/cibuildwheel
  dependency-type: direct:production
  update-type: version-update:semver-patch
Signed-off-by: default avatardependabot[bot] <support@github.com>
Co-authored-by: default avatardependabot[bot] <49699333+dependabot[bot]@users.noreply.github.com>
parent bc13b889
...@@ -48,7 +48,7 @@ jobs: ...@@ -48,7 +48,7 @@ jobs:
with: with:
submodules: true submodules: true
- uses: pypa/cibuildwheel@v2.8.0 - uses: pypa/cibuildwheel@v2.8.1
- name: Verify clean directory - name: Verify clean directory
run: git diff --exit-code run: git diff --exit-code
