Commit 56405338 authored by Henry Schreiner's avatar Henry Schreiner
feat: initial commit
parents
on:
workflow_dispatch:
pull_request:
push:
branches:
- master
jobs:
make_dist:
name: Make distributions
runs-on: ubuntu-latest
steps:
- uses: actions/checkout@v2
with:
repository: pybind/pybind11
- uses: actions/setup-python@v2
- name: Download requirements
run: python -m pip install build
- name: Build files
run: |
python -m build
PYBIND11_GLOBAL_SDIST=ON python -m build
- uses: actions/upload-artifact@v2
with:
path: dist/*
build:
name: Build with Pip
needs: [make_dist]
strategy:
fail-fast: false
matrix:
platform: [windows-latest, macos-latest, ubuntu-latest]
python-version: ["2.7", "3.5", "3.8"]
exclude:
# Not supported by scikit-build
- platform: windows-latest
python-version: "2.7"
runs-on: ${{ matrix.platform }}
steps:
- uses: actions/download-artifact@v2
with:
path: dist
with:
python-version: ${{ matrix.python-version }}
- name: Add requirements
run: python -m pip install --upgrade wheel setuptools
# Eventually Microsoft might have an action for setting up
# MSVC, but for now, this action works:
- name: Prepare compiler environment for Windows 🐍 2.7
if: runner.os == 'Windows'
uses: ilammy/msvc-dev-cmd@v1
with:
arch: x64
- name: Build and install
run: pip install --verbose . --find-links ${{ github.workspace }}/dist
- name: Test
run: python tests/test.py
# Using https://github.com/github/gitignore/blob/master/Python.gitignore
# Byte-compiled / optimized / DLL files
__pycache__/
*.py[cod]
*$py.class
# C extensions
*.so
# Distribution / packaging
.Python
build/
develop-eggs/
dist/
downloads/
eggs/
.eggs/
lib/
lib64/
parts/
sdist/
var/
wheels/
share/python-wheels/
*.egg-info/
.installed.cfg
*.egg
MANIFEST
# PyInstaller
# Usually these files are written by a python script from a template
# before PyInstaller builds the exe, so as to inject date/other infos into it.
*.manifest
*.spec
# Installer logs
pip-log.txt
pip-delete-this-directory.txt
# Unit test / coverage reports
htmlcov/
.tox/
.nox/
.coverage
.coverage.*
.cache
nosetests.xml
coverage.xml
*.cover
*.py,cover
.hypothesis/
.pytest_cache/
cover/
# Translations
*.mo
*.pot
# Django stuff:
*.log
local_settings.py
db.sqlite3
db.sqlite3-journal
# Flask stuff:
instance/
.webassets-cache
# Scrapy stuff:
.scrapy
# Sphinx documentation
docs/_build/
# PyBuilder
.pybuilder/
target/
# Jupyter Notebook
.ipynb_checkpoints
# IPython
profile_default/
ipython_config.py
# pyenv
# For a library or package, you might want to ignore these files since the code is
# intended to run in multiple environments; otherwise, check them in:
# .python-version
# pipenv
# According to pypa/pipenv#598, it is recommended to include Pipfile.lock in version control.
# However, in case of collaboration, if having platform-specific dependencies or dependencies
# having no cross-platform support, pipenv may install dependencies that don't work, or not
# install all needed dependencies.
#Pipfile.lock
# PEP 582; used by e.g. github.com/David-OConnor/pyflow
__pypackages__/
# Celery stuff
celerybeat-schedule
celerybeat.pid
# SageMath parsed files
*.sage.py
# Environments
.env
.venv
env/
venv/
ENV/
env.bak/
venv.bak/
# Spyder project settings
.spyderproject
.spyproject
# Rope project settings
.ropeproject
# mkdocs documentation
/site
# mypy
.mypy_cache/
.dmypy.json
dmypy.json
# Pyre type checker
.pyre/
# pytype static type analyzer
.pytype/
# Cython debug symbols
cython_debug/
# To use:
# pre-commit run -a
# Or:
# pre-commit install # (runs every time you commit in git)
# To update this file:
# pre-commit autoupdate
# See https://github.com/pre-commit/pre-commit
repos:
# Standard hooks
- repo: https://github.com/pre-commit/pre-commit-hooks
rev: v3.2.0
hooks:
- id: check-added-large-files
- id: check-case-conflict
- id: check-merge-conflict
- id: check-symlinks
- id: check-yaml
- id: debug-statements
- id: end-of-file-fixer
- id: mixed-line-ending
- id: requirements-txt-fixer
- id: trailing-whitespace
- id: fix-encoding-pragma
# Black, the code formatter, natively supports pre-commit
- repo: https://github.com/psf/black
rev: 20.8b1
hooks:
- id: black
exclude: ^(docs)
# Changes tabs to spaces
- repo: https://github.com/Lucas-C/pre-commit-hooks
rev: v1.1.9
hooks:
- id: remove-tabs
exclude: ^(docs)
# CMake formatting
- repo: https://github.com/cheshirekow/cmake-format-precommit
rev: v0.6.13
hooks:
- id: cmake-format
additional_dependencies: [pyyaml]
types: [file]
files: (\.cmake|CMakeLists.txt)(.in)?$
cmake_minimum_required(VERSION 3.7...3.18)
project(scikit_build_example VERSION "0.0.1")
# Define CMAKE_INSTALL_xxx: LIBDIR, INCLUDEDIR
include(GNUInstallDirs)
find_package(pybind11 CONFIG REQUIRED)
pybind11_add_module(_core MODULE src/main.cpp)
target_compile_definitions(_core PRIVATE VERSION_INFO=${PROJECT_VERSION})
install(TARGETS _core DESTINATION .)
# Quiet a warning, since this project is only valid with SKBUILD
set(ignoreMe "${SKBUILD}")
LICENSE 0 → 100644
Copyright (c) 2016 The Pybind Development Team, All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this
list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its contributors
may be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
You are under no obligation whatsoever to provide any bug fixes, patches, or
upgrades to the features, functionality or performance of the source code
("Enhancements") to anyone; however, if you choose to make your Enhancements
available either publicly, or directly to the author of this software, without
imposing a separate written license agreement for such Enhancements, then you
hereby grant the following license: a non-exclusive, royalty-free perpetual
license to install, use, modify, prepare derivative works, incorporate into
other computer software, distribute, and sublicense such enhancements or
derivative works thereof, in binary and source code form.
python_example
[![Gitter][gitter-badge]][gitter-link]
[![Wheels Actions Status][actions-pip-badge]][actions-pip-link]
[gitter-badge]: https://badges.gitter.im/pybind/Lobby.svg
[gitter-link]: https://gitter.im/pybind/Lobby
[actions-pip-link]: https://github.com/pybind/scikit_build_example/actions?query=workflow%3APip
[actions-pip-badge]: https://github.com/pybind/scikit_build_example/workflows/Pip/badge.svg
An example project built with [pybind11](https://github.com/pybind/pybind11).
Warning: this is currently using a pre-release of pybind11 2.6.0, since the
infrastructure for building pure Python examples has been heavily improved
there.
Installation
**On Unix (Linux, macOS)**
- clone this repository
- `pip install ./scikit_build_example`
**On Windows (Requires Visual Studio 2017)**
- For Python 3.5+:
- For Python 2.7:
- Pybind11 + Scikit-Build does not support Python 2.7 on Windows.
CI Examples
There are examples for CI in `.github/workflows`. A simple way to produces
binary "wheels" for all platforms is illustrated in the "wheels.yml" file,
using [`cibuildwheel`][].
License
pybind11 is provided under a BSD-style license that can be found in the LICENSE
file. By using, distributing, or contributing to this project, you agree to the
terms and conditions of this license.
Test call
```python
import python_example
python_example.add(1, 2)
[`cibuildwheel`]: https://cibuildwheel.readthedocs.io
# Makefile for Sphinx documentation
# You can set these variables from the command line.
SPHINXOPTS =
SPHINXBUILD = sphinx-build
PAPER =
BUILDDIR = _build
# User-friendly check for sphinx-build
ifeq ($(shell which $(SPHINXBUILD) >/dev/null 2>&1; echo $$?), 1)
$(error The '$(SPHINXBUILD)' command was not found. Make sure you have Sphinx installed, then set the SPHINXBUILD environment variable to point to the full path of the '$(SPHINXBUILD)' executable. Alternatively you can add the directory with the executable to your PATH. If you don't have Sphinx installed, grab it from http://sphinx-doc.org/)
endif
# Internal variables.
PAPEROPT_a4 = -D latex_paper_size=a4
PAPEROPT_letter = -D latex_paper_size=letter
ALLSPHINXOPTS = -d $(BUILDDIR)/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
# the i18n builder cannot share the environment and doctrees with the others
I18NSPHINXOPTS = $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
.PHONY: help
help:
@echo "Please use \`make <target>' where <target> is one of"
@echo " html to make standalone HTML files"
@echo " dirhtml to make HTML files named index.html in directories"
@echo " singlehtml to make a single large HTML file"
@echo " pickle to make pickle files"
@echo " json to make JSON files"
@echo " htmlhelp to make HTML files and a HTML help project"
@echo " qthelp to make HTML files and a qthelp project"
@echo " applehelp to make an Apple Help Book"
@echo " devhelp to make HTML files and a Devhelp project"
@echo " epub to make an epub"
@echo " latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
@echo " latexpdf to make LaTeX files and run them through pdflatex"
@echo " latexpdfja to make LaTeX files and run them through platex/dvipdfmx"
@echo " text to make text files"
@echo " man to make manual pages"
@echo " texinfo to make Texinfo files"
@echo " info to make Texinfo files and run them through makeinfo"
@echo " gettext to make PO message catalogs"
@echo " changes to make an overview of all changed/added/deprecated items"
@echo " xml to make Docutils-native XML files"
@echo " pseudoxml to make pseudoxml-XML files for display purposes"
@echo " linkcheck to check all external links for integrity"
@echo " doctest to run all doctests embedded in the documentation (if enabled)"
@echo " coverage to run coverage check of the documentation (if enabled)"
.PHONY: clean
clean:
rm -rf $(BUILDDIR)/*
.PHONY: html
html:
$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html
@echo
@echo "Build finished. The HTML pages are in $(BUILDDIR)/html."
.PHONY: dirhtml
dirhtml:
$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml
@echo
@echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml."
.PHONY: singlehtml
singlehtml:
$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml
@echo
@echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml."
.PHONY: pickle
pickle:
$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle
@echo
@echo "Build finished; now you can process the pickle files."
.PHONY: json
json:
$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json
@echo
@echo "Build finished; now you can process the JSON files."
.PHONY: htmlhelp
htmlhelp:
$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp
@echo
@echo "Build finished; now you can run HTML Help Workshop with the" \
".hhp project file in $(BUILDDIR)/htmlhelp."
.PHONY: qthelp
qthelp:
$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp
@echo
@echo "Build finished; now you can run "qcollectiongenerator" with the" \
".qhcp project file in $(BUILDDIR)/qthelp, like this:"
@echo "# qcollectiongenerator $(BUILDDIR)/qthelp/python_example.qhcp"
@echo "To view the help file:"
@echo "# assistant -collectionFile $(BUILDDIR)/qthelp/python_example.qhc"
.PHONY: applehelp
applehelp:
$(SPHINXBUILD) -b applehelp $(ALLSPHINXOPTS) $(BUILDDIR)/applehelp
@echo
@echo "Build finished. The help book is in $(BUILDDIR)/applehelp."
@echo "N.B. You won't be able to view it unless you put it in" \
"~/Library/Documentation/Help or install it in your application" \
"bundle."
.PHONY: devhelp
devhelp:
$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp
@echo
@echo "Build finished."
@echo "# mkdir -p $$HOME/.local/share/devhelp/python_example"
@echo "# ln -s $(BUILDDIR)/devhelp $$HOME/.local/share/devhelp/python_example"
@echo "# devhelp"
.PHONY: epub
epub:
$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub
@echo
@echo "Build finished. The epub file is in $(BUILDDIR)/epub."
.PHONY: latex
latex:
$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
@echo
@echo "Build finished; the LaTeX files are in $(BUILDDIR)/latex."
@echo "Run \`make' in that directory to run these through (pdf)latex" \
"(use \`make latexpdf' here to do that automatically)."
.PHONY: latexpdf
latexpdf:
@echo "Running LaTeX files through pdflatex..."
$(MAKE) -C $(BUILDDIR)/latex all-pdf
@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
.PHONY: latexpdfja
latexpdfja:
@echo "Running LaTeX files through platex and dvipdfmx..."
$(MAKE) -C $(BUILDDIR)/latex all-pdf-ja
.PHONY: text
text:
$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text
@echo
@echo "Build finished. The text files are in $(BUILDDIR)/text."
.PHONY: man
man:
$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man
@echo
@echo "Build finished. The manual pages are in $(BUILDDIR)/man."
.PHONY: texinfo
texinfo:
$(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo
@echo
@echo "Build finished. The Texinfo files are in $(BUILDDIR)/texinfo."
@echo "Run \`make' in that directory to run these through makeinfo" \
"(use \`make info' here to do that automatically)."
.PHONY: info
info:
@echo "Running Texinfo files through makeinfo..."
make -C $(BUILDDIR)/texinfo info
@echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo."
.PHONY: gettext
gettext:
$(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale
@echo
@echo "Build finished. The message catalogs are in $(BUILDDIR)/locale."
.PHONY: changes
changes:
$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes
@echo
@echo "The overview file is in $(BUILDDIR)/changes."
.PHONY: linkcheck
linkcheck:
$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck
@echo
@echo "Link check complete; look for any errors in the above output " \
"or in $(BUILDDIR)/linkcheck/output.txt."
.PHONY: doctest
doctest:
$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest
@echo "Testing of doctests in the sources finished, look at the " \
"results in $(BUILDDIR)/doctest/output.txt."
.PHONY: coverage
coverage:
$(SPHINXBUILD) -b coverage $(ALLSPHINXOPTS) $(BUILDDIR)/coverage
@echo "Testing of coverage in the sources finished, look at the " \
"results in $(BUILDDIR)/coverage/python.txt."
.PHONY: xml
xml:
$(SPHINXBUILD) -b xml $(ALLSPHINXOPTS) $(BUILDDIR)/xml
@echo
@echo "Build finished. The XML files are in $(BUILDDIR)/xml."
.PHONY: pseudoxml
pseudoxml:
$(SPHINXBUILD) -b pseudoxml $(ALLSPHINXOPTS) $(BUILDDIR)/pseudoxml
@echo
@echo "Build finished. The pseudo-XML files are in $(BUILDDIR)/pseudoxml."
# -*- coding: utf-8 -*-
# python_example documentation build configuration file, created by
# sphinx-quickstart on Fri Feb 26 00:29:33 2016.
# This file is execfile()d with the current directory set to its
# containing dir.
# Note that not all possible configuration values are present in this
# autogenerated file.
# All configuration values have a default; values that are commented out
# serve to show the default.
import sys
import os
# If extensions (or modules to document with autodoc) are in another directory,
# add these directories to sys.path here. If the directory is relative to the
# documentation root, use os.path.abspath to make it absolute, like shown here.
#sys.path.insert(0, os.path.abspath('.'))
# -- General configuration ------------------------------------------------
# If your documentation needs a minimal Sphinx version, state it here.
#needs_sphinx = '1.0'
# Add any Sphinx extension module names here, as strings. They can be
# extensions coming with Sphinx (named 'sphinx.ext.*') or your custom
# ones.
extensions = [
'sphinx.ext.autodoc',
'sphinx.ext.intersphinx',
'sphinx.ext.autosummary',
'sphinx.ext.napoleon',
autosummary_generate = True
# Add any paths that contain templates here, relative to this directory.
templates_path = ['_templates']
# The suffix(es) of source filenames.
# You can specify multiple suffix as a list of string:
# source_suffix = ['.rst', '.md']
source_suffix = '.rst'
# The encoding of source files.
#source_encoding = 'utf-8-sig'
# The master toctree document.
master_doc = 'index'
# General information about the project.
project = u'python_example'
copyright = u'2016, Sylvain Corlay'
author = u'Sylvain Corlay'
# The version info for the project you're documenting, acts as replacement for
# |version| and |release|, also used in various other places throughout the
# built documents.
# The short X.Y version.
version = u'0.0.1'
# The full version, including alpha/beta/rc tags.
release = u'0.0.1'
# The language for content autogenerated by Sphinx. Refer to documentation
# for a list of supported languages.
# This is also used if you do content translation via gettext catalogs.
# Usually you set "language" from the command line for these cases.
language = None
# There are two options for replacing |today|: either, you set today to some
# non-false value, then it is used:
#today = ''
# Else, today_fmt is used as the format for a strftime call.
#today_fmt = '%B %d, %Y'
# List of patterns, relative to source directory, that match files and
# directories to ignore when looking for source files.
exclude_patterns = ['_build']
# The reST default role (used for this markup: `text`) to use for all
# documents.
#default_role = None
# If true, '()' will be appended to :func: etc. cross-reference text.
#add_function_parentheses = True
# If true, the current module name will be prepended to all description
# unit titles (such as .. function::).
#add_module_names = True
# If true, sectionauthor and moduleauthor directives will be shown in the
# output. They are ignored by default.
#show_authors = False
# The name of the Pygments (syntax highlighting) style to use.
pygments_style = 'sphinx'
# A list of ignored prefixes for module index sorting.
#modindex_common_prefix = []
# If true, keep warnings as "system message" paragraphs in the built documents.
#keep_warnings = False
# If true, `todo` and `todoList` produce output, else they produce nothing.
todo_include_todos = False
# -- Options for HTML output ----------------------------------------------
# The theme to use for HTML and HTML Help pages. See the documentation for
# a list of builtin themes.
html_theme = 'alabaster'
# Theme options are theme-specific and customize the look and feel of a theme
# further. For a list of options available for each theme, see the
# documentation.
#html_theme_options = {}
# Add any paths that contain custom themes here, relative to this directory.
#html_theme_path = []
# The name for this set of Sphinx documents. If None, it defaults to
# "<project> v<release> documentation".
#html_title = None
# A shorter title for the navigation bar. Default is the same as html_title.
#html_short_title = None
# The name of an image file (relative to this directory) to place at the top
# of the sidebar.
#html_logo = None
# The name of an image file (within the static path) to use as favicon of the
# docs. This file should be a Windows icon file (.ico) being 16x16 or 32x32
# pixels large.
#html_favicon = None
# Add any paths that contain custom static files (such as style sheets) here,
# relative to this directory. They are copied after the builtin static files,
# so a file named "default.css" will overwrite the builtin "default.css".
html_static_path = ['_static']
# Add any extra paths that contain custom files (such as robots.txt or
# .htaccess) here, relative to this directory. These files are copied
# directly to the root of the documentation.
#html_extra_path = []
# If not '', a 'Last updated on:' timestamp is inserted at every page bottom,
# using the given strftime format.
#html_last_updated_fmt = '%b %d, %Y'
# If true, SmartyPants will be used to convert quotes and dashes to
# typographically correct entities.
#html_use_smartypants = True
# Custom sidebar templates, maps document names to template names.
#html_sidebars = {}
# Additional templates that should be rendered to pages, maps page names to
# template names.
#html_additional_pages = {}
# If false, no module index is generated.
#html_domain_indices = True
# If false, no index is generated.
#html_use_index = True
# If true, the index is split into individual pages for each letter.
#html_split_index = False
# If true, links to the reST sources are added to the pages.
#html_show_sourcelink = True
# If true, "Created using Sphinx" is shown in the HTML footer. Default is True.
#html_show_sphinx = True
# If true, "(C) Copyright ..." is shown in the HTML footer. Default is True.
#html_show_copyright = True
# If true, an OpenSearch description file will be output, and all pages will
# contain a <link> tag referring to it. The value of this option must be the
# base URL from which the finished HTML is served.
#html_use_opensearch = ''
# This is the file name suffix for HTML files (e.g. ".xhtml").
#html_file_suffix = None
# Language to be used for generating the HTML full-text search index.
# Sphinx supports the following languages:
# 'da', 'de', 'en', 'es', 'fi', 'fr', 'hu', 'it', 'ja'
# 'nl', 'no', 'pt', 'ro', 'ru', 'sv', 'tr'
#html_search_language = 'en'
# A dictionary with options for the search language support, empty by default.
# Now only 'ja' uses this config value
#html_search_options = {'type': 'default'}
# The name of a javascript file (relative to the configuration directory) that
# implements a search results scorer. If empty, the default will be used.
#html_search_scorer = 'scorer.js'
# Output file base name for HTML help builder.
htmlhelp_basename = 'python_exampledoc'
# -- Options for LaTeX output ---------------------------------------------
latex_elements = {
# The paper size ('letterpaper' or 'a4paper').
#'papersize': 'letterpaper',
# The font size ('10pt', '11pt' or '12pt').
#'pointsize': '10pt',
# Additional stuff for the LaTeX preamble.
#'preamble': '',
# Latex figure (float) alignment
#'figure_align': 'htbp',
# Grouping the document tree into LaTeX files. List of tuples
# (source start file, target name, title,
# author, documentclass [howto, manual, or own class]).
latex_documents = [
(master_doc, 'python_example.tex', u'python_example Documentation',
u'Sylvain Corlay', 'manual'),
# The name of an image file (relative to this directory) to place at the top of
# the title page.
#latex_logo = None
# For "manual" documents, if this is true, then toplevel headings are parts,
# not chapters.
#latex_use_parts = False
# If true, show page references after internal links.
#latex_show_pagerefs = False
# If true, show URL addresses after external links.
#latex_show_urls = False
# Documents to append as an appendix to all manuals.
#latex_appendices = []
#latex_domain_indices = True
# -- Options for manual page output ---------------------------------------
# One entry per manual page. List of tuples
# (source start file, name, description, authors, manual section).
man_pages = [
(master_doc, 'python_example', u'python_example Documentation',
[author], 1)
#man_show_urls = False
# -- Options for Texinfo output -------------------------------------------
# Grouping the document tree into Texinfo files. List of tuples
# (source start file, target name, title, author,
# dir menu entry, description, category)
texinfo_documents = [
author, 'python_example', 'One line description of project.',
'Miscellaneous'),
#texinfo_appendices = []
#texinfo_domain_indices = True
# How to display URL addresses: 'footnote', 'no', or 'inline'.
#texinfo_show_urls = 'footnote'
# If true, do not generate a @detailmenu in the "Top" node's menu.
#texinfo_no_detailmenu = False
# Example configuration for intersphinx: refer to the Python standard library.
intersphinx_mapping = {'https://docs.python.org/': None}
Contents:
.. toctree::
:maxdepth: 2
python_example
@ECHO OFF
REM Command file for Sphinx documentation
if "%SPHINXBUILD%" == "" (
set SPHINXBUILD=sphinx-build
set BUILDDIR=_build
set ALLSPHINXOPTS=-d %BUILDDIR%/doctrees %SPHINXOPTS% .
set I18NSPHINXOPTS=%SPHINXOPTS% .
if NOT "%PAPER%" == "" (
set ALLSPHINXOPTS=-D latex_paper_size=%PAPER% %ALLSPHINXOPTS%
set I18NSPHINXOPTS=-D latex_paper_size=%PAPER% %I18NSPHINXOPTS%
if "%1" == "" goto help
if "%1" == "help" (
:help
echo.Please use `make ^<target^>` where ^<target^> is one of
echo. html to make standalone HTML files
echo. dirhtml to make HTML files named index.html in directories
echo. singlehtml to make a single large HTML file
echo. pickle to make pickle files
echo. json to make JSON files
echo. htmlhelp to make HTML files and a HTML help project
echo. qthelp to make HTML files and a qthelp project
echo. devhelp to make HTML files and a Devhelp project
echo. epub to make an epub
echo. latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter
echo. text to make text files
echo. man to make manual pages
echo. texinfo to make Texinfo files
echo. gettext to make PO message catalogs
echo. changes to make an overview over all changed/added/deprecated items
echo. xml to make Docutils-native XML files
echo. pseudoxml to make pseudoxml-XML files for display purposes
echo. linkcheck to check all external links for integrity
echo. doctest to run all doctests embedded in the documentation if enabled
echo. coverage to run coverage check of the documentation if enabled
goto end
if "%1" == "clean" (
for /d %%i in (%BUILDDIR%\*) do rmdir /q /s %%i
del /q /s %BUILDDIR%\*
goto end
REM Check if sphinx-build is available and fallback to Python version if any
%SPHINXBUILD% 1>NUL 2>NUL
if errorlevel 9009 goto sphinx_python
goto sphinx_ok
:sphinx_python
set SPHINXBUILD=python -m sphinx.__init__
%SPHINXBUILD% 2> nul
if errorlevel 9009 (
echo.
echo.The 'sphinx-build' command was not found. Make sure you have Sphinx
echo.installed, then set the SPHINXBUILD environment variable to point
echo.to the full path of the 'sphinx-build' executable. Alternatively you
echo.may add the Sphinx directory to PATH.
echo.
echo.If you don't have Sphinx installed, grab it from
echo.http://sphinx-doc.org/
exit /b 1
:sphinx_ok
if "%1" == "html" (
%SPHINXBUILD% -b html %ALLSPHINXOPTS% %BUILDDIR%/html
if errorlevel 1 exit /b 1
echo.
echo.Build finished. The HTML pages are in %BUILDDIR%/html.
goto end
if "%1" == "dirhtml" (
%SPHINXBUILD% -b dirhtml %ALLSPHINXOPTS% %BUILDDIR%/dirhtml
echo.
echo.Build finished. The HTML pages are in %BUILDDIR%/dirhtml.
goto end
if "%1" == "singlehtml" (
%SPHINXBUILD% -b singlehtml %ALLSPHINXOPTS% %BUILDDIR%/singlehtml
echo.
echo.Build finished. The HTML pages are in %BUILDDIR%/singlehtml.
goto end
if "%1" == "pickle" (
%SPHINXBUILD% -b pickle %ALLSPHINXOPTS% %BUILDDIR%/pickle
echo.
echo.Build finished; now you can process the pickle files.
goto end
if "%1" == "json" (
%SPHINXBUILD% -b json %ALLSPHINXOPTS% %BUILDDIR%/json
echo.
echo.Build finished; now you can process the JSON files.
goto end
if "%1" == "htmlhelp" (
%SPHINXBUILD% -b htmlhelp %ALLSPHINXOPTS% %BUILDDIR%/htmlhelp
echo.
echo.Build finished; now you can run HTML Help Workshop with the ^
.hhp project file in %BUILDDIR%/htmlhelp.
goto end
if "%1" == "qthelp" (
%SPHINXBUILD% -b qthelp %ALLSPHINXOPTS% %BUILDDIR%/qthelp
echo.
echo.Build finished; now you can run "qcollectiongenerator" with the ^
.qhcp project file in %BUILDDIR%/qthelp, like this:
echo.^> qcollectiongenerator %BUILDDIR%\qthelp\python_example.qhcp
echo.To view the help file:
echo.^> assistant -collectionFile %BUILDDIR%\qthelp\python_example.ghc
goto end
if "%1" == "devhelp" (
%SPHINXBUILD% -b devhelp %ALLSPHINXOPTS% %BUILDDIR%/devhelp
echo.
goto end
if "%1" == "epub" (
%SPHINXBUILD% -b epub %ALLSPHINXOPTS% %BUILDDIR%/epub
echo.
echo.Build finished. The epub file is in %BUILDDIR%/epub.
goto end
if "%1" == "latex" (
%SPHINXBUILD% -b latex %ALLSPHINXOPTS% %BUILDDIR%/latex
echo.
echo.Build finished; the LaTeX files are in %BUILDDIR%/latex.
goto end
if "%1" == "latexpdf" (
cd %BUILDDIR%/latex
make all-pdf
cd %~dp0
echo.
echo.Build finished; the PDF files are in %BUILDDIR%/latex.
goto end
if "%1" == "latexpdfja" (
cd %BUILDDIR%/latex
make all-pdf-ja
cd %~dp0
echo.
goto end
if "%1" == "text" (
%SPHINXBUILD% -b text %ALLSPHINXOPTS% %BUILDDIR%/text
echo.
echo.Build finished. The text files are in %BUILDDIR%/text.
goto end
if "%1" == "man" (
%SPHINXBUILD% -b man %ALLSPHINXOPTS% %BUILDDIR%/man
echo.
echo.Build finished. The manual pages are in %BUILDDIR%/man.
goto end
if "%1" == "texinfo" (
%SPHINXBUILD% -b texinfo %ALLSPHINXOPTS% %BUILDDIR%/texinfo
echo.
echo.Build finished. The Texinfo files are in %BUILDDIR%/texinfo.
goto end
if "%1" == "gettext" (
%SPHINXBUILD% -b gettext %I18NSPHINXOPTS% %BUILDDIR%/locale
echo.
echo.Build finished. The message catalogs are in %BUILDDIR%/locale.
goto end
if "%1" == "changes" (
%SPHINXBUILD% -b changes %ALLSPHINXOPTS% %BUILDDIR%/changes
echo.
echo.The overview file is in %BUILDDIR%/changes.
goto end
if "%1" == "linkcheck" (
%SPHINXBUILD% -b linkcheck %ALLSPHINXOPTS% %BUILDDIR%/linkcheck
echo.
echo.Link check complete; look for any errors in the above output ^
or in %BUILDDIR%/linkcheck/output.txt.
goto end
if "%1" == "doctest" (
%SPHINXBUILD% -b doctest %ALLSPHINXOPTS% %BUILDDIR%/doctest
echo.
echo.Testing of doctests in the sources finished, look at the ^
results in %BUILDDIR%/doctest/output.txt.
goto end
if "%1" == "coverage" (
%SPHINXBUILD% -b coverage %ALLSPHINXOPTS% %BUILDDIR%/coverage
echo.
echo.Testing of coverage in the sources finished, look at the ^
results in %BUILDDIR%/coverage/python.txt.
goto end
if "%1" == "xml" (
%SPHINXBUILD% -b xml %ALLSPHINXOPTS% %BUILDDIR%/xml
echo.
echo.Build finished. The XML files are in %BUILDDIR%/xml.
goto end
if "%1" == "pseudoxml" (
%SPHINXBUILD% -b pseudoxml %ALLSPHINXOPTS% %BUILDDIR%/pseudoxml
echo.
echo.Build finished. The pseudo-XML files are in %BUILDDIR%/pseudoxml.
goto end
:end
.. automodule:: python_example
[build-system]
requires = [
"setuptools>=42",
"wheel",
"pybind11-global",
"cmake",
"scikit-build",
build-backend = "setuptools.build_meta"
setup.py 0 → 100644
from __future__ import print_function
import sys
try:
from skbuild import setup
except ImportError:
print(
"Please update pip, you need pip 10 or greater,\n"
" or you need to install the PEP 518 requirements in pyproject.toml yourself",
file=sys.stderr,
raise
setup(
name="scikit-build-example",
version="0.0.1",
description="a minimal example package (with pybind11)",
author="Henry Schreiner",
license="MIT",
packages=["scikit_build_example"],
package_dir={"": "src"},
cmake_install_dir="src/scikit_build_example",
#include <pybind11/pybind11.h>
#define STRINGIFY(x) #x
#define MACRO_STRINGIFY(x) STRINGIFY(x)
int add(int i, int j) {
return i + j;
namespace py = pybind11;
PYBIND11_MODULE(_core, m) {
m.doc() = R"pbdoc(
Pybind11 example plugin
.. currentmodule:: scikit_build_example
.. autosummary::
:toctree: _generate
add
subtract
)pbdoc";
m.def("add", &add, R"pbdoc(
Add two numbers
Some other explanation about the add function.
)pbdoc");
m.def("subtract", [](int i, int j) { return i - j; }, R"pbdoc(
Subtract two numbers
Some other explanation about the subtract function.
)pbdoc");
#ifdef VERSION_INFO
m.attr("__version__") = MACRO_STRINGIFY(VERSION_INFO);
#else
m.attr("__version__") = "dev";
#endif
from ._core import __doc__, __version__, add, subtract
import scikit_build_example as m
assert m.__version__ == "0.0.1"
assert m.add(1, 2) == 3
assert m.subtract(1, 2) == -1
