Unverified Commit 94fe4357 authored by Raphaël Bleuse's avatar Raphaël Bleuse
Bump version v3.2.1
parent 55ed7c54
Tags v3.2.1
...@@ -11,10 +11,26 @@ The format is based on `Keep a Changelog`_. ...@@ -11,10 +11,26 @@ The format is based on `Keep a Changelog`_.
Unreleased Unreleased
- `Commits since v3.2.0 <https://gitlab.inria.fr/batsim/pybatsim/compare/v3.2.0...master>`_ - `Commits since v3.2.1 <https://gitlab.inria.fr/batsim/pybatsim/compare/v3.2.1...master>`_
- ``nix-env -f https://github.com/oar-team/nur-kapack/archive/master.tar.gz -iA pybatsim-master`` - ``nix-env -f https://github.com/oar-team/nur-kapack/archive/master.tar.gz -iA pybatsim-master``
v3.2.1
- Release date: 2021-12-15
- `Commits since v3.2.0 <https://gitlab.inria.fr/batsim/pybatsim/compare/v3.2.0...v3.2.1>`_
Miscellaneous
- Clean packaging:
- moved to poetry, a PEP517-compliant tool
- `pandas` dependency is now optional, use ``pip install pybatsim[tools]`` if you wish to keep previous behavior of ``pip install``
v3.2.0 v3.2.0
...@@ -41,7 +57,7 @@ Additions ...@@ -41,7 +57,7 @@ Additions
Miscellaneous Miscellaneous
- Example schedulers in the `schedulers` folder are now up-to-date, except from those in the `unMaintained` sub-folder. - Example schedulers in the `schedulers` folder are now up-to-date, except from those in the `unMaintained` sub-folder.
[tool.poetry] [tool.poetry]
name = "pybatsim" name = "pybatsim"
version = "3.2.0" version = "3.2.1"
description = "Python API and schedulers for Batsim" description = "Python API and schedulers for Batsim"
readme = "README.rst" readme = "README.rst"
keywords = [ keywords = [
