GitLab
Explore
Primary navigation
Search or go to…
L
LF
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
LightFieldCodingLibrary
LF
37569ad8
37569ad8
6 years ago
DIB Elian
Downloads
Patches
Perform bottom right padding in codec, remove it from write and read
d67ba3d2
5
5 changed files
codec.m
+12
-2
12 additions, 2 deletions
codec.m
pad.m
+0
-18
0 additions, 18 deletions
pad.m
read.m
+1
-8
1 addition, 8 deletions
read.m
unpad.m
+0
-17
0 additions, 17 deletions
unpad.m
write.m
+2
-11
2 additions, 11 deletions
write.m
15 additions
56 deletions
codec.m
12
2
37569ad8
@@ -63,9 +63,15 @@ if ~exist(recDir,'dir')
mkdir
recDir
mkdir
recDir
% Do padding
LFSize
size
LFRef
LFSizePad
ceil
LFSize
LFParams
padding
LFParams
padding
LFSize
LFSizePad
3
LFRef
padarray
LFRef
LFSizePad
'replicate'
'post'
% Write input yuv file
if
LFParams
encode
if
LFParams
encode
imgSize
imgRes
imgSizePad
LF
write
LFRef
LFParams
'filename'
LFParams
refFilename
imgSize
Pad
imgRes
LF
write
LFRef
LFParams
'filename'
LFParams
refFilename
% Convert inputs for HEVC
@@ -76,7 +82,11 @@ LFHEVCParams = LF.LFtoHEVC(imgSizePad,imgRes,LFParams,HEVCParams);
% Read output yuv file
if
LFParams
decode
if
LFParams
decode
LFRec
LF
read
imgSize
imgRes
LFParams
'filename'
LFParams
recFilename
LFRec
LF
read
imgSize
Pad
imgRes
LFParams
'filename'
LFParams
recFilename
% Undo padding
gv
arrayfun
x
x
LFSize
'UniformOutput'
false
LFRec
LFRec
gv
\ No newline at end of file
This diff is collapsed.
pad.m
deleted
100644 → 0
d67ba3d2
function
LFRef
imgSizePad
pad
LFRef
padding
%PAD Pad lightfield data
% [LFRef,LFSizePad] = pad(LFRef,blockSize)
LFSize
size
LFRef
imgSize
LFSize
3
imgRes
LFSize
4
imgSizePad
ceil
imgSize
padding
padding
imgSizePad
3
imgSize
3
padSize
imgSizePad
imgSize
zeros
numel
imgRes
padSizePre
floor
padSize
2
padSizePost
padSize
padSizePre
LFRef
padarray
LFRef
padSizePre
'replicate'
'pre'
LFRef
padarray
LFRef
padSizePost
'replicate'
'post'
read.m
8
37569ad8
@@ -7,22 +7,15 @@ filename = fullfile(pwd,'sequence');
% Create input parser scheme
p
inputParser
p
StructExpand
true
p
KeepUnmatched
true
p
inputParser
p
StructExpand
true
p
KeepUnmatched
true
p
addParameter
'filename'
filename
ischar
p
addParameter
'filename'
filename
ischar
p
addParameter
'padding'
isnumeric
% Parse arguments
% Parse arguments
p
parse
varargin
p
parse
varargin
%filename = p.Results.filename;
padding
p
Results
padding
% Recover frames
% Recover frames
imgSizePad
ceil
imgSize
padding
padding
frames
yuv
read
imgSize
imgRes
varargin
imgSizePad
3
imgSize
3
frames
yuv
read
imgSizePad
imgRes
varargin
% Recover LF
% Recover LF
LFRec
LF
fromSlices
frames
LFRec
LF
fromSlices
frames
% Undo padding
LFRec
LF
unpad
LFRec
imgSize
unpad.m
deleted
100644 → 0
d67ba3d2
function
LFRef
unpad
LFRef
imgSize
%UNPAD Remove padding from lightfield data
% LFRef = unpad(LFRef,LFSize)
LFSizePad
size
LFRef
imgSizePad
LFSizePad
3
imgRes
LFSizePad
4
padSize
imgSizePad
imgSize
zeros
numel
imgRes
padSizePre
floor
padSize
2
padSizePost
padSize
padSizePre
gv
arrayfun
lfsizepad
pre
post
pre
lfsizepad
post
LFSizePad
padSizePre
padSizePost
'UniformOutput'
false
LFRef
LFRef
gv
write.m
2
11
37569ad8
function
imgSize
imgRes
imgSizePad
write
LFRef
varargin
function
imgSize
imgRes
write
LFRef
varargin
%WRITE Write lightfield 4D(u,v,x,y) data to yuv file
% [LFSize,yuvSize] = WRITE(LFRef,varargin)
@@ -7,24 +7,15 @@ filename = fullfile(pwd,'sequence');
p
inputParser
p
StructExpand
true
p
KeepUnmatched
true
p
inputParser
p
StructExpand
true
p
KeepUnmatched
true
p
addParameter
'filename'
filename
ischar
p
addParameter
'filename'
filename
ischar
p
addParameter
'padding'
isnumeric
% Parse arguments
% Parse arguments
p
parse
varargin
p
parse
varargin
filename
p
Results
filename
padding
p
Results
padding
LFSize
size
LFRef
LFSize
size
LFRef
imgSize
LFSize
3
imgSize
LFSize
3
imgRes
LFSize
4
imgRes
LFSize
4
m
utils
getMat
filename
true
m
imgSize
imgSize
m
imgRes
imgRes
% Do padding
LFRef
imgSizePad
LF
pad
LFRef
padding
% Change 5D LF to a collection of 2D frames
frames
LF
toSlices
LFRef
frames
LF
toSlices
LFRef
Loading
Save comment
