Commit 82a65841 authored by Vincent Danjean's avatar Vincent Danjean
Cleanup version handling
parent d8938831
......@@ -10,8 +10,8 @@ BEGIN {
# set the version for version checking
#$VERSION = 1.00;
# if using RCS/CVS, this may be preferred
$VERSION = do { my @r = (q$Revision$ =~ /\d+/g);
sprintf "%d."."%02d" x $#r, @r }; # must be all one line, for MakeMaker
#$VERSION = do { my @r = (q$Revision$ =~ /\d+/g);
# sprintf "%d."."%02d" x $#r, @r }; # must be all one line, for MakeMaker
@ISA = qw(Exporter);
@EXPORT = qw(NON_SIGNIFICATIF SIGNIFICATIF &chi2_significatif &definition_p_chi2 &reech_chi2);
......@@ -18,8 +18,8 @@ BEGIN {
#$VERSION = 1.00;
@EXPORT = qw();
......@@ -6,7 +6,8 @@ WriteMakefile(
NAME => 'altree',
PMLIBDIRS => [ 'ALTree' ],
DIR => [ 'CUtils' ],
VERSION => '1.2.1',
VERSION_FROM => 'progs/altree',
depend => { Makefile => '$(VERSION_FROM)' },
LICENSE => 'perl',
PREREQ_PM => {}, # e.g., Module::Name => 1.1
($] >= 5.005 ? ## Add these new keywords supported since 5.005
......@@ -10,8 +10,7 @@ use Data::Dumper;
srand(654321);
our $VERSION;
$VERSION = sprintf "0.%03d", q$Revision: 433 $ =~ /(\d+)/g;
use version; our $VERSION = qv(1.2.1);
# Positionner la variable PERL5LIB si besoin
......@@ -1195,9 +1194,7 @@ sub manage_options
) or pod2usage(2);
if (defined($options{"version"})) {
print $0, " version ", $VERSION, "\n";
print "(CUtils version ", $ALTree::CUtils::VERSION,
"; chi2.pm version ", $ALTree::Chi2::VERSION,
"; Perl version ", $], ")\n";
print "(Perl version ", $], ")\n";
exit 0;
if (defined($options{"short-help"})) {
