Commit cf89046d authored by NINASSI Benjamin's avatar NINASSI Benjamin
Adding confirmation for deletion
parent f938e099
...@@ -44,7 +44,7 @@ ...@@ -44,7 +44,7 @@
{% if is_granted('ROLE_ADMIN') %} {% if is_granted('ROLE_ADMIN') %}
<td> <td>
<a href="#EditCoordination" class="EditCoordination" data-coordinationstructure="{{ coordination.getStructure }}" data-coordinationclasscodepage="{{ coordination.getClassCodePage }}" data-coordinationid="{{ coordination.getId }}" data-coordinationname="{{ coordination.getName }}" data-coordinationlogo="{{ coordination.getLogo }}" data-coordinationwho="{{ coordination.getWho }}" data-coordinationemail="{{ coordination.getEmail}}" data-coordinationemails="{{ coordination.getEmails }}" data-coordinationurl="{{ coordination.getUrl }}" data-coordinationslug="{{ coordination.getSlug }}" data-coordinationregion="{{ coordination.getRegion }}" data-coordinationaddress="{{ coordination.getAddress }}" data-coordinationlat="{{ coordination.getLatitude }}" data-coordinationlong="{{ coordination.getLongitude }}" data-coordinationalert="{{ coordination.getAlert }}" data-toggle="modal" data-target="#EditCoordination" ><img src="{{ asset('images/edit.png')}}" alt="{{ 'coordination.edit'|trans }}" title="{{ 'coordination.edit'|trans }}"></a> <a href="#EditCoordination" class="EditCoordination" data-coordinationstructure="{{ coordination.getStructure }}" data-coordinationclasscodepage="{{ coordination.getClassCodePage }}" data-coordinationid="{{ coordination.getId }}" data-coordinationname="{{ coordination.getName }}" data-coordinationlogo="{{ coordination.getLogo }}" data-coordinationwho="{{ coordination.getWho }}" data-coordinationemail="{{ coordination.getEmail}}" data-coordinationemails="{{ coordination.getEmails }}" data-coordinationurl="{{ coordination.getUrl }}" data-coordinationslug="{{ coordination.getSlug }}" data-coordinationregion="{{ coordination.getRegion }}" data-coordinationaddress="{{ coordination.getAddress }}" data-coordinationlat="{{ coordination.getLatitude }}" data-coordinationlong="{{ coordination.getLongitude }}" data-coordinationalert="{{ coordination.getAlert }}" data-toggle="modal" data-target="#EditCoordination" ><img src="{{ asset('images/edit.png')}}" alt="{{ 'coordination.edit'|trans }}" title="{{ 'coordination.edit'|trans }}"></a>
<a href="{{ path('coordination_delete', { 'id' : coordination.getId } ) }}" ><img src="{{ asset('images/delete.png')}}" alt="{{ 'coordination.delete'|trans }}" title="{{ 'coordination.delete'|trans }}"></a> <a href="{{ path('coordination_delete', { 'id' : coordination.getId } ) }}" OnClick="return confirm('{{ 'coordination.delete'|trans }} ?');"><img src="{{ asset('images/delete.png')}}" alt="{{ 'coordination.delete'|trans }}" title="{{ 'coordination.delete'|trans }}"></a>
</td> </td>
{% endif %} {% endif %}
</tr> </tr>
...@@ -28,7 +28,7 @@ ...@@ -28,7 +28,7 @@
</td> </td>
<td> <td>
<a href="{{ path('group_delete', { 'id' : group.getId } ) }}" ><img src="{{ asset('images/delete.png')}}" alt="{{ 'group.delete'|trans }}" title="{{ 'group.delete'|trans }}"></a> <a href="{{ path('group_delete', { 'id' : group.getId } ) }}" OnClick="return confirm('{{ 'group.delete'|trans }} ?');"><img src="{{ asset('images/delete.png')}}" alt="{{ 'group.delete'|trans }}" title="{{ 'group.delete'|trans }}"></a>
</td> </td>
</tr> </tr>
...@@ -32,7 +32,7 @@ ...@@ -32,7 +32,7 @@
<td> <td>
<a href="#EditPartner" class="EditPartner" data-partnerid="{{ partner.getId }}" data-partnername="{{ partner.getName }}" data-partnerlogo="{{ partner.getLogo }}" data-partnergroupname="{{ partner.getGroup.getName }}" data-partnergroupid="{{ partner.getGroup.getId }}" data-partnerurl="{{ partner.getUrl }}" data-toggle="modal" data-target="#EditPartner" ><img src="{{ asset('images/edit.png')}}" alt="{{ 'partner.edit'|trans }}" title="{{ 'partner.edit'|trans }}"></a> <a href="#EditPartner" class="EditPartner" data-partnerid="{{ partner.getId }}" data-partnername="{{ partner.getName }}" data-partnerlogo="{{ partner.getLogo }}" data-partnergroupname="{{ partner.getGroup.getName }}" data-partnergroupid="{{ partner.getGroup.getId }}" data-partnerurl="{{ partner.getUrl }}" data-toggle="modal" data-target="#EditPartner" ><img src="{{ asset('images/edit.png')}}" alt="{{ 'partner.edit'|trans }}" title="{{ 'partner.edit'|trans }}"></a>
<a href="{{ path('partner_delete', { 'id' : partner.getId } ) }}" ><img src="{{ asset('images/delete.png')}}" alt="{{ 'partner.delete'|trans }}" title="{{ 'partner.delete'|trans }}"></a> <a href="{{ path('partner_delete', { 'id' : partner.getId } ) }}" OnClick="return confirm('{{ 'partner.delete'|trans }} ?');"><img src="{{ asset('images/delete.png')}}" alt="{{ 'partner.delete'|trans }}" title="{{ 'partner.delete'|trans }}"></a>
</td> </td>
</tr> </tr>
...@@ -41,7 +41,7 @@ ...@@ -41,7 +41,7 @@
<td> <td>
{% if is_granted('ROLE_ADMIN') or (app.user.userName == structure.getUpdatedBy) %} {% if is_granted('ROLE_ADMIN') or (app.user.userName == structure.getUpdatedBy) %}
<a href="#EditStructure" class="EditStructure" data-structureid="{{ structure.getId }}" data-structurename="{{ structure.getName }}" data-structurelogo="{{ structure.getLogo }}" data-structurewho="{{ structure.getWho }}" data-structureemail="{{ structure.getEmail}}" data-structureurl="{{ structure.getUrl }}" data-structureaddress="{{ structure.getAddress }}" data-structurelat="{{ structure.getLatitude }}" data-structurelong="{{ structure.getLongitude }}" data-toggle="modal" data-target="#EditStructure" ><img src="{{ asset('images/edit.png')}}" alt="{{ 'structure.edit'|trans }}" title="{{ 'structure.edit'|trans }}"></a> <a href="#EditStructure" class="EditStructure" data-structureid="{{ structure.getId }}" data-structurename="{{ structure.getName }}" data-structurelogo="{{ structure.getLogo }}" data-structurewho="{{ structure.getWho }}" data-structureemail="{{ structure.getEmail}}" data-structureurl="{{ structure.getUrl }}" data-structureaddress="{{ structure.getAddress }}" data-structurelat="{{ structure.getLatitude }}" data-structurelong="{{ structure.getLongitude }}" data-toggle="modal" data-target="#EditStructure" ><img src="{{ asset('images/edit.png')}}" alt="{{ 'structure.edit'|trans }}" title="{{ 'structure.edit'|trans }}"></a>
<a href="{{ path('structure_delete', { 'id' : structure.getId } ) }}" ><img src="{{ asset('images/delete.png')}}" alt="{{ 'structure.delete'|trans }}" title="{{ 'structure.delete'|trans }}"></a> <a href="{{ path('structure_delete', { 'id' : structure.getId } ) }}" OnClick="return confirm('{{ 'structure.delete'|trans }} ?');"><img src="{{ asset('images/delete.png')}}" alt="{{ 'structure.delete'|trans }}" title="{{ 'structure.delete'|trans }}"></a>
</td> </td>
