Commit 830693e5 authored by NINASSI Benjamin's avatar NINASSI Benjamin
js correction for IAI template
parent acd004e0
...@@ -78,40 +78,42 @@ ...@@ -78,40 +78,42 @@
$('.iai-nav').removeClass('opened'); $('.iai-nav').removeClass('opened');
$(window).on("scroll", function() if(anchor1 && anchor2 && anchor3 && anchor4){
{ $(window).on("scroll", function()
var scrolltop = $(this).scrollTop(); {
if ((scrolltop > 0) && ! $body.hasClass('sticky')) {
$body.addClass('sticky'); if ((scrolltop > 0) && ! $body.hasClass('sticky')) {
} else if (scrolltop === 0) { $body.addClass('sticky');
$body.removeClass('sticky'); } else if (scrolltop === 0) {
} $body.removeClass('sticky');
scrolltop += 330;
scrolltop += 330;
var prevActiveMenu = $('.iai-nav-item.iai-nav-item-active').index();
var activeMenu = 0; var prevActiveMenu = $('.iai-nav-item.iai-nav-item-active').index();
var activeMenu = 0;
// console.log( $(this).scrollTop()+ 330, anchor2.offset().top );
if (scrolltop > anchor4.offset().top ) {
activeMenu = 3; if (scrolltop > anchor4.offset().top ) {
} else if (scrolltop > anchor3.offset().top ) { activeMenu = 3;
activeMenu = 2; } else if (scrolltop > anchor3.offset().top ) {
} else if (scrolltop > anchor2.offset().top ) { activeMenu = 2;
activeMenu = 1; } else if (scrolltop > anchor2.offset().top ) {
} else if (scrolltop > anchor1.offset().top ) { activeMenu = 1;
activeMenu = 0; } else if (scrolltop > anchor1.offset().top ) {
} activeMenu = 0;
if (prevActiveMenu !== activeMenu) {
$('.iai-nav-item').removeClass('iai-nav-item-active'); if (prevActiveMenu !== activeMenu) {
var activeElement = $('.iai-nav-item').get(activeMenu); $('.iai-nav-item').removeClass('iai-nav-item-active');
$(activeElement).addClass('iai-nav-item-active'); var activeElement = $('.iai-nav-item').get(activeMenu);
} $(activeElement).addClass('iai-nav-item-active');
$('.iai-nav-item').on('click', function(e){ $('.iai-nav-item').on('click', function(e){
var toScrollTop; var toScrollTop;
