GitLab
Explore
Primary navigation
Search or go to…
E
easytracker
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Container registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
CORSE
easytracker
0033b9be
0033b9be
9 months ago
Manuel Selva
Downloads
Patches
Update test_step_next.py
c0278f37
Pipeline
#1063110
failed
9 months ago
Stage: test
tests/unit_tests/test_trackers/gdb/test_step_next.py
+2
-2
2 additions, 2 deletions
2 additions
2 deletions
2
2
0033b9be
@@ -38,9 +38,9 @@ def test_step_next(gdb_tracker):
assert
gdb_tracker
last_lineno
is
None
assert
gdb_tracker
last_lineno
is
None
gdb_tracker
start
gdb_tracker
start
assert
gdb_tracker
next_lineno
11
assert gdb_tracker.next_lineno == 11
gdb_tracker
next
gdb_tracker.next()
# declarations are skipped
assert
gdb_tracker
next_lineno
13
assert
gdb_tracker
next_lineno
13
This diff is collapsed.
Loading
Save comment
