GitLab
Explore
Primary navigation
Search or go to…
why3
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Monitor
Service Desk
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Why3
why3
4421df38
4421df38
8 years ago
Jean-Christophe Filliâtre
Downloads
Patches
new function Extset.print
4ead4697
Branches containing commit
Tags containing commit
3
3 changed files
Makefile.in
+2
-2
2 additions, 2 deletions
Makefile.in
src/util/extset.ml
+7
7 additions, 0 deletions
src/util/extset.ml
src/util/extset.mli
+3
3 additions, 0 deletions
src/util/extset.mli
12 additions
2 deletions
Makefile.in
2
2
4421df38
@@ -165,8 +165,8 @@ LIBGENERATED = src/util/config.ml \
lib/ocaml/why3__BigInt_compat.ml
LIB_UTIL
config bigInt util opt lists strings
LIB_UTIL
extmap extset exthtbl weakhtbl
pp
hashcons stdlib exn_printer
pp
json debug loc lexlib print_tree
hashcons stdlib exn_printer json debug loc lexlib print_tree
cmdline warning sysutil rc plugin bigInt number pqueue
LIB_CORE
ident ty term pattern decl coercion theory
LIB_CORE
This diff is collapsed.
src/util/extset.ml
7
4421df38
@@ -50,6 +50,7 @@ module type S = sig
val
contains
t
elt
bool
val
contains
t
elt
bool
val
add_left
t
elt
t
val
add_left
t
elt
t
val
remove_left
t
elt
t
val
remove_left
t
elt
t
val
print
Format
formatter
elt
unit
Format
formatter
t
unit
module
MakeOfMap
Extmap
S
struct
module
MakeOfMap
Extmap
S
struct
@@ -97,6 +98,12 @@ module MakeOfMap (M: Extmap.S) = struct
let
contains
contains
let
contains
contains
let
add_left
s
e
add
e
s
let
add_left
s
e
add
e
s
let
remove_left
s
e
remove
e
s
let
remove_left
s
e
remove
e
s
let
print
print_elt
fmt
s
if
is_empty
s
then
Format
fprintf
fmt
else
begin
Format
fprintf
fmt
"@[<hov 2>{ "
Pp
print_iter1
iter
Pp
comma
print_elt
fmt
s
Format
fprintf
fmt
module
type
OrderedType
Set
OrderedType
module
type
OrderedType
Set
OrderedType
src/util/extset.mli
3
4421df38
@@ -170,6 +170,9 @@ module type S =
val
remove_left
t
elt
t
val
remove_left
t
elt
t
(** [remove_left s x] is the same as [remove x s]. *)
val
print
Format
formatter
elt
unit
Format
formatter
t
unit
module
MakeOfMap
Extmap
S
S
module
module
MakeOfMap
Extmap
S
S
module
Loading
Save comment
